Old 11-18-2012, 03:50 AM   #1
brett192
Member#: 274252
2002 WRX Sedan
6 speed PSM
Default Disconnecting stock BPV recirc tube
I don't want to buy a BOV since they are so frowned upon, but would kind of like to experience the sound for a little while. Never been in a vehicle with one.
If I were to disconnect my recirc tube and plug it, would it be any worse than running a BOV? Would I be able to hear anything or would it be dulled down since it's pointed downwards?
Not super serious, just curious, not some ricer swagboy.
brett192 is offline   Reply With Quote
Old 11-18-2012, 05:22 AM   #2
sc00by4life
Member#: 97135
disconnecting the recirc tube is just like running an atmospheric BOV.
and makes your car run just as ****ty.
Old 11-18-2012, 10:26 AM   #3
424wrx
Member#: 171948
08 wrx prem sedan
vf52 swap. bilstein susp
you want sound? get a decent intake and a good bp valve. you will hear the blowoff sound AND the car will still run like it should.
Old 11-18-2012, 10:36 AM   #4
Lindyn11
Member#: 326221
WRBP
I imagine if you plug it, no "good" sound would be produced. Imagine Siamese elephant twins joined at the ends of their trunks.
Lindyn11 is offline   Reply With Quote
Old 11-18-2012, 10:58 AM   #5
emazz104
Member#: 281811
04 WRX
If you remove the silencer on your intake you can hear the stock BPV. Only at higher RPMs though.
emazz104 is online now   Reply With Quote
Old 11-18-2012, 05:12 PM   #6
brett192
Member#: 274252
2002 WRX Sedan
6 speed PSM
You mean the stock intake scoop/snorkel? My car came without one so it's just the airbox, can't hear anything really though.
Old 11-18-2012, 05:14 PM   #7
meat_WRX
Member#: 96919
2004 sti
black
yea just remove the snorkel.
meat_WRX is offline   Reply With Quote
Old 11-18-2012, 05:17 PM   #8
424wrx
Member#: 171948
08 wrx prem sedan
look under the aibox.its is a milkjug looking thing. its an intake silencer. you can remove it and cap off the opening.
Old 11-18-2012, 05:21 PM   #9
sc00by4life
Member#: 97135
actually on OP's car its in the fender....
Old 11-18-2012, 06:33 PM   #10
Heedlessone
Member#: 254130
2004 STI
Hurr hurr
It will run like poop. Loss in power and quite a bit of hesitation.
Heedlessone is offline   Reply With Quote
Old 11-18-2012, 07:44 PM   #11
424wrx
Member#: 171948
08 wrx prem sedan
wouldnt that be under the airbox? i know where it is.
Old 11-18-2012, 08:44 PM   #12
emazz104
Member#: 281811
04 WRX
You can hear the stock BPV with the silencer gone, definitely not as loud as BOV, but you can hear it.
Yeah, it comes off the airbox but it's tucked under the fender.
Old 11-18-2012, 08:50 PM   #13
DoogieSTi
Member#: 247023
2007 STi
Negative. It connects TO the airbox on the passenger side. It is hidden away inside the fender. There is no room for anything under the airbox.
DoogieSTi is offline   Reply With Quote
Old 11-18-2012, 08:51 PM   #14
brett192
Member#: 274252
2002 WRX Sedan
6 speed PSM
I dont have anything in my fender at all, I see the holes where the snorkel would be and got the block off plate from Subaru, the hole in the airbox is not blocked but there is never any debris in the airbox.
I will be able to borrow a friend's bov for a couple days in mid december so that'll have to do. Gonna be ricey but it'll turn heads, not many modded cars around here. Haha
Message Board Statistics All times are GMT -4. The time now is 08:16 PM.
