Old 11-18-2012, 12:25 AM   #1
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Event: dyno tuning at IAG Performance
Dyno: dyno jet
Temp: 50 degrees
Elevation: n/a
Tuner: Jorge
Baseline Wrx: n/a
Car: 2005 Wrx
Target boost: 21psi
Hp: 367whp
Tq: 363wtq
Fuel: 93oct
Engine:
Ej257 short block
Nitride crank
Weisco 99.5mm piston
Stock, unported 2.0 heads
Dom 1.5xtr 10cm Hotside
ID1000cc injectors
IAG TGV deletes
IAG 38mm ewg
Gt-spec uel header
Invidia catless dp
Tial 50mm bov
TXS rma cbe
TXS fmic
Grimmspeed ebcs
Perrin 2.4" turbo inlet
TXS shorty intake
Iat sensor (for speed density)
Trans:
Jdm ver.9 Sti 6spd
R180
Dss axles
Sti drive shaft
South bend stage 2 clutch
Kartboy front and rear shifter bushings
Kartboy short shifter
Suspension:
Bc br+ coilovers
Cobb 25.4 front sway bar
Kartboy front and rear end links
White line front shifter stay bushings
White line rear subframe lock down bushings
Others not listed because they are not needed for this thread.....
Dyno:
http://m.youtube.com/watch?feature=plcp&v=zgNHPopTRBA
http://m.youtube.com/watch?feature=plcp&v=8bYyrY8XfYM
shadowmd is offline   Reply With Quote
Old 11-18-2012, 03:12 AM   #2
stu
Member#: 25768
35R bugeye
Slowbaru
Looks real nice. Any plans for race gas
stu is online now   Reply With Quote
Old 11-18-2012, 03:41 AM   #3
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
I am going with a very similar setup.
looks like a fun setup and nice numbers.
renegadeSTi is offline   Reply With Quote
Old 11-18-2012, 08:28 AM   #4
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
With speed density you're only allowed one map so no race gas for me lol but all I can say is that compared to my old setup (vf34/maf tuned) this is night and day
Old 11-18-2012, 08:31 AM   #5
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Thanks and this car surprised IAG and Jorge. They originally thought that because of the stock 2.0 heads I would be limited to 16-18psi, but my car was able to run 21 just fine. In fact, it could of ran more. This tune was conservative. They also said that they have never seen an Sti (car with 2.5 heads) make more than my car. So I'm super happy with the results!
Old 11-18-2012, 09:33 AM   #6
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Nice numbers man I bet you are enjoying that.
I have a very similar setup , same block and head combo but with a blouch 20gxt 8cm and iwg that made identical numbers by Dan over at mach v in sterling. He also was very suprised to get those numbers out of my setup.
mrjcotten is offline   Reply With Quote
Old 11-18-2012, 09:45 AM   #7
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Yeah man! The tq on the hybrids is awesome
Old 11-18-2012, 10:43 AM   #8
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
Yeah I was thinking about upgrading the cams in the 2.0 heads to the STi cams but right now they are just stock heads. I think I will go with a more conservative 21 psi as well for my 91 tune. I may try and do 24 psi on E85 though see if I can make 400 AWHP at altitude.
Hybrid 2.5/20 is definitely beastly.
Old 11-18-2012, 10:59 AM   #9
snake32
Member#: 167338
02 Silver dollar
those are very impressive numbers, my car put down 398whp with the perrin 30r on stock heads but was dropping to 320at redline also! stock wrx cams
probably you make more power tnah an sti but the sti will hold till redline and that is a big plus.
snake32 is online now   Reply With Quote
Old 11-18-2012, 11:19 AM   #10
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Yeah I need cams in my life
Old 11-18-2012, 10:29 PM   #11
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
great power, you have stock heads and he pushed it to almost 7500 rpm?
Str8Gone is offline   Reply With Quote
Old 11-18-2012, 10:33 PM   #12
Netrisk032
Member#: 84995
Interesting.... I'll be getting a similar setup tuned at tpg sometime in the near future.... I'm running a 2.1 though and a 8 cm housing.... Crower 272 cams on stock wrx heads
Netrisk032 is offline   Reply With Quote
Old 11-18-2012, 10:46 PM   #13
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Yeah man lol but I never go past 7. Usually shift at like 6800. The vid I posted, I think I went a lil over 7, but that's because it's hard to vid and drive lol
Old 11-19-2012, 05:03 PM   #14
prashanth
Member#: 123534
2012 Evo X MR
Grey
Didn't u have ELH? When did you change to UEL?
prashanth is offline   Reply With Quote
Old 11-19-2012, 05:35 PM   #15
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
I DID but traded them for a brand new set of gt-spec UEL's
Old 11-19-2012, 06:40 PM   #16
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Those are great numbwra for.that turbo and only 21psi. Seems nice ands safe and powerful. its must rip on the street
Old 11-19-2012, 06:44 PM   #17
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
It's mean lol at least to me. There was more to be made but it's super safe and I'm definitely ok with that.
Old 11-19-2012, 06:56 PM   #18
Slimsti
Member#: 155696
Yeah I also would rather make less power and not have to worry about something breaking. I have a dom 3 and meth and am only making 375/368 cause I'd rather have piece of mind that its crazy conservative. Still plenty fast to. Ur spool is nice too. That's like instant power always on tap
Old 11-19-2012, 07:35 PM   #19
Netrisk032
Member#: 84995
Best to run the smallest turbo to meet your goals... Worst case add meth in the future to waken the turbo up even more!!!
Old 11-19-2012, 07:43 PM   #20
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
The spool is def nice and with the jdm 6spd, being close ratio, shifts always land nicely in the power band
Old 11-19-2012, 07:44 PM   #21
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Yeah I'm pretty sure I could of run more boost and of made, but Jorge and I were happy and it's safe lol
Old 11-19-2012, 08:51 PM   #22
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
Great Setup, I am looking to put together something very similar to yours.
Which South Bend Stage 2 do you have and how do you like it?
WagonGGA is offline   Reply With Quote
Old 11-19-2012, 09:00 PM   #23
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
I have the Sti stage 2 daily clutch and it's not bad. Have an issue where if your at a light and leave the clutch pedal depressed like you're waiting for the light to change, it smells. And it's not like I'm riding it, never had a clutch do it before.
Old 11-19-2012, 10:02 PM   #24
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
^ you may be able to fix that with a simple pedal adjustment.
Old 11-19-2012, 10:08 PM   #25
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
I'm planning on doing that, but it feels "right" so I don't know lol
