Old 11-08-2012, 02:11 PM   #1526
sc00by4life
Member#: 97135
Originally Posted by JAMM0N
make sure tires arent on a RWD also. FYI be safe dude you dont want to ruin your car because those tires were on a RWD and Tire depth dont match. you'll end up wearing whichever one out first before the season is over or up
This has nothing to do with anything.
Old 11-08-2012, 02:32 PM   #1527
my name is joe
Member#: 171412
Sme of you guys are saying you can't run a 17x9 +45 with proper sized tires, but I almost bought wheels in that size with 245/40 v710 which came from a wagon. He said he just rolled it and cambered a little. It didn't look like he had rubbing problems. It's an autox setup so the tire will be abused. If I ran a small tire you'll see me roll over the sidewall and the rim would be turning me instead of the tire. I wouldn't be lowered to the floor. Half to an inch from finder to tire. So can I run it or no? I'm not afraid of having camber, the more the better (front) it'll help my transitions and turn in. Don't care about tire wear either since it'll be done in less than 3000 miles.
my name is joe is offline   Reply With Quote
Old 11-08-2012, 03:49 PM   #1528
sc00by4life
Member#: 97135
On a sedan, you can easily run 17x9 +42 with a 245 and 0 fender mods.
Old 11-08-2012, 04:07 PM   #1529
my name is joe
Member#: 171412
Not talking about sedans.
Old 11-11-2012, 08:04 PM   #1530
bicho_ojo
Member#: 268847
2005 35r'd STI
Looking to buy some RPF1's I really do not want to roll my fenders but I may have to for the sizing I want...
I am looking at 18x9 with an inset of 35 these would be wrapped in a 235/40/18 or a 225/40/18...
Also a 18x8.5 inset 40 I may be willing to do the 30 wrapped in a 225/40/18
Will either of these clear brembo's? What fender mods if any? What is a deeper look if I do not need to roll my Fenders, I ma new to the wheel fitment side of things.
I'm lowered on BC coils so I do have the ability to adjust height according to fitment issues.
bicho_ojo is offline   Reply With Quote
Old 11-11-2012, 09:59 PM   #1531
nikemullen
Member#: 289573
2003 wrx
hey guys, i'm looking at getting rota torques for my 02 wrx as she sits now she's completely stock body and suspension wise. I found some 17x9's that i'm looking at, would i have any kind of issues with fitment? i really don't want to roll the fenders and plan on a different suspension in the future.
nikemullen is offline   Reply With Quote
Old 11-12-2012, 11:45 AM   #1532
sc00by4life
Member#: 97135
If you don't want to roll fenders, don't look at wheels any wider than 8" and an offset lower than 45.
Old 11-12-2012, 11:57 AM   #1533
nikemullen
Member#: 289573
2003 wrx
thanks for the help, i only wanted 17x7.5's but i found a pretty good deal on the bigger ones, i'll just stick to the 7.5"
Old 11-12-2012, 12:48 PM   #1534
tenchi_wrx
Member#: 37469
03 WRX, EFR7670 TS
6MT R180 WRB
year: 2003
model: WRX
wheel model: Gramslight 57DR
wheel size/offset: 17x9.0 +35
tire size: Up to recommendation
suspension: Tien Flex Coilover
alignment: Rear adjustable camber bolt
fender mods: Will roll fender if needed.
spacers: no
Hi, looking to get a new set of wheels for summer for daily and track. Will I be able to run this wheel setup?
tenchi_wrx is offline   Reply With Quote
Old 11-12-2012, 02:37 PM   #1535
bicho_ojo
Member#: 268847
2005 35r'd STI
Can anyone please answer this?
Old 11-15-2012, 12:19 AM   #1536
coolerthanafan
Member#: 303215
2008 STi
2008 STi
BR/BC Coilovers
Stock non-BBS wheels
I am thinking about 18x8.5 e44 Rota DPT with a 255/40/18: Will this be ok without modification and camber to as straight as possible?
Or I have contemplated staying with stock wheels and going with 255/40/18: Will I be ok here too?
coolerthanafan is offline   Reply With Quote
Old 11-16-2012, 12:43 AM   #1537
littlewhitewagon
Member#: 103068
11 STI sedan
245/40R17 will fit easily. 255/40R17 can fit without much issue. Rolling the fenders is necessary.
Originally Posted by tenchi_wrx View Post
year: 2003
model: WRX
spacers: no
littlewhitewagon is offline   Reply With Quote
Old 11-18-2012, 12:33 PM   #1538
TRSCobra
Member#: 181009
`12 MZ3 Skyactiv
'12 C300 4matic Sport
http://www.frsport.com/Rays-Wheels-G...l_p_37632.html
Will these fit on a 2012 WRX sedan? I can't find this size and offset anywhere for WRX, but BRZ and FRS stuff is all over.
I know rolling the rear fenders is required.
TRSCobra is offline   Reply With Quote
Old 11-18-2012, 12:40 PM   #1539
VDCOFF
Member#: 263628
Impreza WRX Ltd
those should easily fit on your wrx
VDCOFF is offline   Reply With Quote
Old 11-25-2012, 02:39 PM   #1540
Johnold
Member#: 322797
Ice Silver Metallic
So I have a 2012 WRX sedan completely stock and I don't mind keeping the dark stock 17x8 wheels they come with but I'd like to buy some wheel spacers for them so I was thinking of putting 10mm in the front and 5mm in the rear. Just the slip on disks. Would this work? I like the stock wheels but didn't wanna get the the stock wheels too far out and didn't wanna get the spacers with the welded integrated wheel studs since I don't wanna go too far out. Thanks.
Johnold is offline   Reply With Quote
Old 11-25-2012, 02:44 PM   #1541
sc00by4life
Member#: 97135
you'll need to purchase and install extended lugs, as well as purchase extended/open ended lug nuts in the event you ever want to remove the spacers.
Old 11-25-2012, 06:07 PM   #1542
fakechow
Member#: 338879
2002 Wrx
black
OMGHi2U 2002 wrx aggressive fitment
I'm trying to figure out a functional not just form wheel size and Im looking for something aggressive I looked through a lot of the thread and seems like a 18x9 et30-39 would be flush maybe slight poke. Open to ideas trying to stay away from spacers as much as possible. Cheers
fakechow is offline   Reply With Quote
Old 11-25-2012, 07:28 PM   #1543
sc00by4life
Member#: 97135
You have conflicting wants.
Figure out what you want THEN ask questions.
Old 11-25-2012, 07:51 PM   #1544
fakechow
Member#: 338879
2002 Wrx
black
OK then what would you reccomend for aggressive fitment wheel/tire size as a whole?
Old 11-25-2012, 09:52 PM   #1545
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
18x9.5 +38 255/35
Coilovers, rear camber adjustment, roll and slight pull all around.
That's a very popular wheel size and will look aggressive without requiring too much fender work.
Old 11-26-2012, 05:55 PM   #1546
Dragon_Ski
Member#: 178153
1996 555 Sti
blue
Just bought 2010 wrx .. think the stock tire size is 225/45/17 . How wide can you go without rolling the fenders ( been there done that and makes tires very expensive ) Can I go to 8" rims as I believe they did for 2011 wrx ..
For winter . how small a rim will clear 2010 wrx brakes . Can you get 15" rims over the brakes
Dragon_Ski is offline   Reply With Quote
Old 11-26-2012, 07:37 PM   #1547
curtisboes
Member#: 280395
04 WRX (STI Swap)
im looking to buy a set of rims but im not sure they will fit, what do you guys think?
04 wrx
Stock struts with Tien S tech springs
stock fenders no rolling
possible rims are
18x8.75 +35, 5x100/5x114.3 wrapped in Michelin Pilot Sport PS2's (245/40/18)
if i cant fit stock and have to get the fenders rolled will it clear the suspension?
any thoughts?
curtisboes is offline   Reply With Quote
Old 11-26-2012, 08:05 PM   #1548
sc00by4life
Member#: 97135
04 wrx
possible rims are
any thoughts?
it'll clear the suspension but to run that much tire you might need a slight pull in the rear.
Old 11-26-2012, 08:13 PM   #1549
curtisboes
Member#: 280395
04 WRX (STI Swap)
But not on the front? Im a nood when is comes to rolling fenders, so please be patient with me...is this something most body shops do? And is it expensive?
Old 11-26-2012, 08:22 PM   #1550
PeteJM
Member#: 244836
2012 Legacy 3.6R LM
Anyone have experience with the 2012 Legacy? Just purchased a 3.6R Limited and I am looking into changing it up a bit
PeteJM is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
