Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 11-18-2012, 11:49 AM   #1
voltic
Member#: 310385
Chapter/Region: HIIC
2016 BRZ Limited
Series.HyperBlue
Default FMIC installed, now throttle delay?
Hey guys, I just did a Perrin FMIC install on my 12 STi, and now have a small issue I'm not really sure about. When I'm taking off, it seems like I have to add more throttle than usual, and it feels like there's a short delay. Anyone have any thoughts?
Other than that, I checked all connections and did a log while I drove it around the block. Everything looked good.
voltic is offline   Reply With Quote
Old 11-18-2012, 11:59 AM   #2
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
Turbo lag?
From Unabomber's FMIC FAQ:
What about the additional lag of a FMIC? This topic is highly debated. The two general trains of thought are:
1. FMICs increase turbo lag.
2. FMICs decrease throttle response.
findurpath is offline   Reply With Quote
Old 11-18-2012, 12:07 PM   #3
jthatch12
Member#: 321715
03 Big 16G WRX
Originally Posted by findurpath View Post
Turbo lag?
^this
Old 11-18-2012, 12:08 PM   #4
brutnus
Member#: 257195
2004 WRX
2.1L
Turbo lag bro. The air has to travel much further so there is a slight delay.
brutnus is offline   Reply With Quote
Old 11-18-2012, 12:12 PM   #5
findurpath
Member#: 277487
Exactly. Think about using a straw to sip a drink. What if you used a 2' long straw and threw some bends in it also?
Old 11-18-2012, 12:16 PM   #6
brutnus
Member#: 257195
2004 WRX
2.1L
Granted it will work fine. You can also not have to worry about heat soak. Also if you ever plan on running more boost it won't be a problem.
Old 11-18-2012, 12:20 PM   #7
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Professionally tuned?
Old 11-18-2012, 12:46 PM   #8
subieguy87
Member#: 153412
1998 Impreza wrxRS
Exactly. Think about using a straw to sip a drink. What if you used a 2' wide straw and threw some bends in it also?
Fixed it
Width not length
subieguy87 is offline   Reply With Quote
Old 11-18-2012, 03:59 PM   #9
FLEX'N WRX
Member#: 163672
GV
Same color as veneers
Turbo lag is not the correct term.
No variables have changed causing the turbo to spool any slower. The correct term would be delayed throttle response. The air is compressed at the same rate, but the air has to travel a longer distance.
FLEX'N WRX is offline   Reply With Quote
Old 11-18-2012, 04:26 PM   #10
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Originally Posted by subieguy87
Fixed it
Width not length
Both matter. I would've made a bong comparison (may get some points here ) bigger the bong the more fresh air you suck up before you get to the...er...tobacco smoke
Old 11-18-2012, 04:41 PM   #11
opey
Member#: 333285
which is just a fancy way of saying turbo lag
opey is offline   Reply With Quote
Old 11-18-2012, 04:58 PM   #12
FLEX'N WRX
Member#: 163672
GV
False... The turbo is not lagging
Old 11-18-2012, 05:00 PM   #13
Ballistic1350
Member#: 156877
04 sti
someone else said it... is it tuned for the fmic? my guess would be no
Ballistic1350 is offline   Reply With Quote
Old 11-18-2012, 05:01 PM   #14
LastResort
Member#: 99289
Turbo lag is the time required to change power output in response to a throttle change, noticed as a hesitation or slowed throttle response when accelerating from idle as compared to a naturally aspirated engine.
turbo lag
LastResort is offline   Reply With Quote
Old 11-18-2012, 05:07 PM   #15
FLEX'N WRX
Member#: 163672
GV
You're misinterpreting the variables.
The turbo will naturally have characteristic lag. The lag that the OP is describing is not turbo lag. It is delayed throttle responses from the variable that did change. The longer pipes of the intercooler.
Your quote is irrelavant.
Old 11-18-2012, 05:07 PM   #16
1wrxtra
Member#: 316364
Did you reset the ECU? Any time I do this my gas pedal's sensitivity changes. Your issue may be related your your FMIC but the way you describe it sounds exactly like what happens when you reset the ECU.
Old 11-18-2012, 05:36 PM   #17
Tripintaz
Member#: 245218
2013 STI Limited
You need a tune for a FMIC to remove the laggy throttle response.
Old 11-18-2012, 05:52 PM   #18
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
Turbo lag when I shouldn't be producing boost? I'm going to guess the delay is just because of the longer piping as some have already said... this is also what I had assumed but wasn't sure. I'm pro-tuned with the stock TMIC, by the way.
It's not going to hurt anything if I run it like this for the next few weeks is it? Trying to delay a new tune until I get the rest of my goodie box under the hood.
Old 11-18-2012, 05:57 PM   #19
LastResort
Member#: 99289
The quote is completely relevant, because it treats turbo lag as a characteristic of the system. Which includes the motor, piping, etc and is based on actual output vs. your metric which isn't really realistic. Which is pretty much the only relevant metric, because a turbo doesn't have lag, it has an inertia and frictional losses. The same turbo in two different applications, will have different lag.
Old 11-18-2012, 06:47 PM   #20
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Get a tune... ASAP. You can drive around, but stay off the throttle and out of boost. There's a reason you're feeling this 'delay'. Your fueling is tuned for a TMIC. With the FMIC, boost takes a little longer to get to your engine, so it's creating a 'choppy' section in your power band that can be smoothed out with a tune. Resetting your ECU will not magically fix this...
Old 11-18-2012, 07:12 PM   #21
FLEX'N WRX
Member#: 163672
GV
Youre on a tangent now...
The quote compares a turbocharged application to a NA application.
The OP described an issue. The relevant parts of the system that alter the spooling characteristics have not been touched. The natural lag associted with the system is still present. The turbo is not lagging anymore than it did prior to his fmic install. To say the cause is turbo lag is incorrect. The culprit is throttle response, and the need for a tune to account for the pressure drop in the system.
Old 11-18-2012, 07:45 PM   #22
i guess you figured out why a fmic may not be the best idea, didnt ya??
Old 11-18-2012, 08:13 PM   #23
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
Despite my insatiable need for approval from people I don't know, I was looking more for answers as to whether this was a problem or a common thing.
Old 11-18-2012, 09:08 PM   #24
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
^ This makes me
Old 11-18-2012, 09:32 PM   #25
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
It seems to me throttle response (engine responding to the throttle petal being pushed) and turbo lag (the time it takes the turbo to build boost) are two different things. Is the op complaning about the off boost response or the delay in boost? It does need a tune ether way.
