Welcome to the North American Subaru Impreza Owners Club Monday September 22, 2014
Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 11-15-2012, 01:21 PM   #4851
atacamar
Member#: 243637
2002 wagon v.7 sti
Originally Posted by Clark Turner View Post
Email me and I will send you to some people that have the motors. This thread was about info on the EJ207. Its turned south over the last year or so.
C
Sure thing, i'll contact you. Sorry to derail thread. If a mod can clean up and move my posts to a new thread thats fine with me. I want to figure out what is causing it.
Thanks,
Ryan
atacamar is offline   Reply With Quote
Old 11-15-2012, 01:23 PM   #4852
opey
Member#: 333285
Originally Posted by trollarc View Post
Another question- are you guys getting these fabulous deals by calling them? If so I have a list of people to call and see if I can get a better deal than $8000 for a version 7.
theres plenty on ebay in the 6000 range.
opey is offline   Reply With Quote
Old 11-15-2012, 01:33 PM   #4853
PHruska
Member#: 214589
2002 wrx wagon
Originally Posted by kpluiten
And what's it about now, Clark? Last I checked, at least 90%of the posters here have an EJ207 and come here to talk about it.
It's a good place for collaboration on swapping and help as well as info. Just dont be a JONG and search before you ask a question.
PHruska is offline   Reply With Quote
Old 11-15-2012, 01:40 PM   #4854
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
I think the 207 motor needs its own sub forum so each topic can have its own thread, it will make searching easier than the 122 page thread.
Lots of people are swapping these motors, as result lots of people have little issues without knowing how to trouble shoot or fix them. Because of this the same issues come up over and over when there should be a single thread about purchasing or AVCS troubleshooting, ect.
Old 11-15-2012, 01:44 PM   #4855
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I'd support an EJ207 sub forum...
Then the 32-bit guys can get down to business.
Old 11-15-2012, 01:55 PM   #4856
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Agreed
LIQUIDSK8S is online now   Reply With Quote
Old 11-15-2012, 02:02 PM   #4857
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
So lets make that happen, who should we pester to make it real
Old 11-15-2012, 02:09 PM   #4858
rdieder
Member#: 257818
2007 STi
agreed, it would help separate general car maintenance questions from 207 specifics.
A section with a contact list of paying and non-paying nasioc vendors for motors would be keep the traffic down for those shopping around.
rdieder is offline   Reply With Quote
Old 11-15-2012, 02:30 PM   #4859
207STi
Member#: 197062
1998 Swapped Impreza
black
I have used this thread to find the spark plug part number I should be using for my v7 ej207. Per the thread I ordered these (
NGK (7772) PFR7G-11S Laser Platinum Spark Plug, Pack of 1 : Amazon.com : AutomotiveNGK (7772) PFR7G-11S Laser Platinum Spark Plug, Pack of 1 : Amazon.com : Automotive
) When i pulled them out of the box I noticed they were gapped to .0035". I re-gapped them to .0030 . I also noticed that in the reviews on amazon they said they were the oem replacement for a honda s2000. Do I have the correct plugs or am I just being totally paranoid?
Old 11-15-2012, 04:43 PM   #4860
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
I use BKR7E #4644
I am not sure about the 7772
Old 11-15-2012, 04:51 PM   #4861
Clark Turner
Member#: 178047
02 WRX STI Spec C
Originally Posted by Fooliojesus View Post
I have used this thread to find the spark plug part number I should be using for my v7 ej207. Per the thread I ordered these (NGK (7772) PFR7G-11S Laser Platinum Spark Plug, Pack of 1 : Amazon.com : Automotive) When i pulled them out of the box I noticed they were gapped to .0035". I re-gapped them to .0030 . I also noticed that in the reviews on amazon they said they were the oem replacement for a honda s2000. Do I have the correct plugs or am I just being totally paranoid?
The -11 at the end of the plug means 1.1 mm. Or 044 gap. This is for a non turbocharged car.
The NGK book catalog was printed wrong years ago and for some reason, they dont want to fix it.
You should never try to gap -11 plugs down to 030. The reason is the top ground strap (the part the spark jumps to) will then be at an angle leaning down. This distorts the spark and shields the leading edge of the electrode.
The correct and best plug for these engines is the NGK 2667. Never order plugs by the BKR7EIX number. Its very possible you will then get BKR7EIX-11 plugs in the mail.
Each weak I find several cars I am tuning have the wrong plugs in the 2.0 and 2.5 subarus. -11's will reduce the output power in a huge way due misfire under boost. In fact, they wont support more then about 12 to 13 psi before they start to act up.
Clark
Old 11-15-2012, 05:04 PM   #4862
207STi
Member#: 197062
black
Clark
Thanks for the prompt informational response Clark.
Old 11-17-2012, 01:14 PM   #4863
WrexTi
Member#: 225723
2002 Wrx ej207 stg 2
Hey guys, I'm wrapping up my v9 sti swap into my 02 wrx. The passenger side timing belt cover on the v9 engine was cracked really bad, so I figured no biggie I'll just use the cover off of my 02 wrx engine. Problem is that the v9 sti cover has a bigger top cam gear, so the mold of my 02 wrx cover doesn't come out far enough to go over it. And to the question, Will the usdm 06 sti cover work? Is it molded for the bigger top(intake) cam gear? Thanks.
WrexTi is offline   Reply With Quote
Old 11-17-2012, 01:21 PM   #4864
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
USDM Sti cover should work yes.
Ben
PHATsuby is offline   Reply With Quote
Old 11-17-2012, 01:25 PM   #4865
WrexTi
Member#: 225723
Thanks bud! I'm gonna go ahead and order, from looking at pictures of the usdm engine, it does seem it will work, just wanted a second opinion.
Old 11-17-2012, 02:25 PM   #4866
207STi
Member#: 197062
black
Anyone have any idea what this is and why it is capped? Is it a coolant passage?
Old 11-17-2012, 06:01 PM   #4867
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
i believe that comes off the water pump
found this pic here
todeswalzer is offline   Reply With Quote
Old 11-18-2012, 02:27 PM   #4868
WhatTurboLag?
Member#: 243992
2006 WRX TR
will a version 7+ EJ207 (twin scroll) pass US emissions?
in illinois they just check for CEL's but i dont know if the OBD2 port works/is recognized on these???
Old 11-18-2012, 03:04 PM   #4869
amroof
Member#: 211224
2005 Mystical
UniCorn FXTi
In theory they will all pass emissions, But we need to know the car the engine is going into. And if they only check codes and you can make them go away you will pass.
I passed CO emissions with flying colors on my 32bit v9 engine that supposedly doesnt run
Our emissions out here is consist of sniffer and dyno and cel check.
Old 11-18-2012, 03:43 PM   #4870
opey
Member#: 333285
with jdm ecu or a usdm?
Old 11-18-2012, 04:46 PM   #4871
kpluiten
Member#: 120273
06 WRBWRXWGN
USDM ECU on his car.
Old 11-18-2012, 04:50 PM   #4872
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
see this is the point of the sub threads. this question has been covered tons of times. i do no personally know but if you go in and fail come back and tell us what they said and someone who had the same problem should be able to help. we are not the testers bro!
Old 11-18-2012, 07:04 PM   #4873
WhatTurboLag?
Member#: 243992
2006 WRX TR
I'm asking because my buddy's about to do a swap and I suggested he do a ej207 Jdm ecu and all. But idk if itmhas obd2? Or like the same way they check if that makes sense.
Old 11-18-2012, 07:35 PM   #4874
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Different states use different scanners, some have no issues connecting to JDM ecus others do it just depends on where you are.
Old 11-18-2012, 07:38 PM   #4875
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Attachment 69680
The early 02-03 shortblocks have that fitting and they are capped as well, It went away on the 04+ shortblocks. No idea what it was ment for but I have seen it before.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain 10 06-03-2010 04:53 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain 21 10-17-2005 01:56 AM
