Old 11-18-2012, 06:15 PM   #1
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
Default Slight oil leak from breather hose on 12 wrx
Usually once a week I check my fluids and go over my engine bay for a few minutes to see if anything needs attention. I'm not sure if this is even a concern but I noticed a small amount of oil being pushed out of the 2 breather hoses right next to the turbo with a small amount that worked it's way onto the block. Not very noticeable but I took a few pics to show this to see if anyone has some information and could even take a look at your car if you have a newer wrx model to see if you find anything similar.
Old 11-18-2012, 06:44 PM   #2
quick sell the car...its just about to blow
Old 11-18-2012, 06:59 PM   #3
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
$3,500 and it's yours. Cash only
Old 11-18-2012, 08:43 PM   #4
i come give ya $3500 for it right now...get the title ready for me...be there in the morning
Old 11-20-2012, 09:28 PM   #5
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
Looking for a more useful reply if possible..
Here is a pic of the hose under the white sensor that also has some oil leaking out. I'm not too concerned about the oil but why it is pushing out makes me wonder.
Old 11-20-2012, 10:14 PM   #6
d0000000000000d....is the oil level in the crankcase ok???
that is the pcv valve hose...ya worried about nuffin
yes = fergetaboutit
no = ya likely need a bit heavier oil in it
Old 11-20-2012, 10:40 PM   #7
tank the ek
Member#: 295911
2015 WRX
LR
Well, it's being pushed out due to blowby, the natural occurance in a turbocharged engine when boost seeps past the piston rings during your engine building/ sustaining boost and therefore creates positive crankcase pressure instead of vacuum.
Due to the style of those hoses and clamps, it's possible for a slight amount of oil to seep, not leak, from those lines. Without completely secure connections with o-rings, or the use of screw type clamps, the compression of those lines at time is compromised in the slightest fashion by the blowby.
It is nothing to loose sleep over or freak out about. You can change all of your squeeze style clamps on your breather hoses to a screw style. But you may still achieve the same result due to the multiple connections of hoses and components. An AN style breather hose would be less susceptible to this seepage, but again, it is not of major concern since the oil seepage is not a large detrimental amount at all.
tank the ek is online now   Reply With Quote
Old 11-21-2012, 01:03 AM   #8
PleiadesSTi
Member#: 194132
2009 WRX Sedan
SSM
Get a Moroso AOS and call it a day.
PleiadesSTi is offline   Reply With Quote
Old 11-23-2012, 12:12 AM   #9
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
yes = fergetaboutit
Oil level is good, car rarely needs oil added between changes. I'm using German Castrol so all should be good in that area.
Thanks for the information. I cleaned them off and will keep an eye on it to see if it becomes more of an issue.
I'm currently doing some research on getting an AOS to prevent any issues down the road.
Car is protuned, I data log it every few weeks and everything looks good to date.
