Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 11-18-2012, 12:49 AM   #1
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Default Oil Consumption Under Boost?
Ok, So I have researched and looked and need an answer.
If I hammer on the car I get pretty bad oil consumption. I'm currently using Kandall 5W40 Synthetic (apparently highly regarded). Before the Catch Can I noticed my intercooler was caked with oil, as well as my turbo. All coming from blow by. So I added a Catch Can (no more oil in intercooler). Now that the can is in I'm still losing a lot of oil (1 quart) in about 1000km's or less. But here is the catch, it's not in the can, but to be frank I have put those metal scrubbing pad so Its probably gunked up in there).
So...Can the oil be crappy and deteriorating/burnt up (I have no clue)?
Anywho I'm going to switch to T6 5w40 tomorrow.
-My car fires up very fast on a cold start (0°c, coldest so far)
-No Smoke from the Oil Cap
-No white smoke from the tail pipe after condensation disappears (no cats)
-If I don't go into boost, I don't consume.
I should do a compression/leak down test and possibly cry.
What do you guys think?
OC_Nooby is offline   Reply With Quote
Old 11-18-2012, 02:44 AM   #2
Uncle Scotty
OK Houston
we have an Uncle
change the pcv valve
Old 11-18-2012, 09:21 AM   #3
OC_Nooby
Member#: 311781
2003 WRX w STI V8
PCV has been removed from the motor.
Old 11-18-2012, 06:46 PM   #4
Uncle Scotty
OK Houston
we have an Uncle
well then...i guess you figured out the issue, then didnt ya
Old 11-18-2012, 09:03 PM   #5
OC_Nooby
Member#: 311781
2003 WRX w STI V8
What I ment to say was that from the vacuum/boost source from the manifold in which the PCV system hooked up to has been bolted shut. Then the PCV valve was removed and also bolted shut. I have a breather hose from the block routed near the radiator (needs a can seteup there) and have a hose coming from the collector of the heads going to a catch can. So my intake doesn't have any oil being routed back in incase of blow by.
Old 11-18-2012, 09:18 PM   #6
Uncle Scotty
OK Houston
we have an Uncle
you are gonna blow something up doin that
really
ya dont know what you are doing
Old 11-18-2012, 09:23 PM   #7
eg33GC
Member#: 206851
99 V4
EJ20K RS
you really need to stop what youre doing and replace the system back to its config
Old 11-18-2012, 10:36 PM   #8
OC_Nooby
Member#: 311781
2003 WRX w STI V8
I was told to do it this way. Whats wrong with this setup. I may not have worded it correctly.
Crankcase venting (eventually will go to catch can) and head breathers to catch can. At vacuum since the PCV valve has been removed the crankcase fumes are not being sucked back into the motor but venting.
Old 11-19-2012, 09:43 PM   #9
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Still wondering?
Old 11-20-2012, 05:32 PM   #10
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Uncle Scotty? eg33GC? Can you explain why? You both seem to have the same opinions and id just like to hear why.
Old 11-20-2012, 06:42 PM   #11
Ferris1977
Member#: 311629
Default oil
Crawford would be the best to get?
Ferris1977 is offline   Reply With Quote
Old 11-20-2012, 07:31 PM   #12
OC_Nooby
Member#: 311781
2003 WRX w STI V8
My issue isn't with the catch can, I'm curious as to why its bad to just remove the pcv valve and keep everything else in tact.
Old 12-06-2012, 06:43 PM   #13
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Well I ran the car for 400km's and would say I consumed about 100 ml - 200 ml. I was driving the car slowly but there where moments where it was under heavy loads going uphill but not going into boost. I've been driving the car now under boost for 50km's and I can't get a very accurate reading, I'm sure its down. Tomorrow I'll be doing the leak/compression test and get this over with.
eg33GC/Uncle Scotty if your going to say not to do something why not explain why not to do it? I've been reading around and I really don't know why the stock PCV system can't be routed the way I have it, minus the emissions...
Old 12-06-2012, 06:51 PM   #14
Frank-i-e
Member#: 316463
2005 STi
Obsidian Black Pearl
It is bad because you're building pressure in the crank case and there is nothing the motor can do to release pressure because it's valve is missing!
Frank-i-e is offline   Reply With Quote
Old 12-06-2012, 07:10 PM   #15
bhinak
Member#: 300026
2005 SWP Legacy GT
Symmetry Tuned
^wrong. He is venting it to atmosphere.
bhinak is offline   Reply With Quote
Old 12-06-2012, 07:11 PM   #16
bhinak
Member#: 300026
2005 SWP Legacy GT
Symmetry Tuned
No valve means constantly relieving pressure. So no buildup.
Old 12-06-2012, 08:09 PM   #17
Frank-i-e
Member#: 316463
2005 STi
He said it was bolted shut...?
Old 12-06-2012, 10:37 PM   #18
Uncle Scotty
OK Houston
we have an Uncle
yeppers
people dont know what they are doing and get it all wrong and blow their **** UP
Old 12-07-2012, 06:10 PM   #19
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Crankcase to atmosphere, heads to catch can. Crankcase is not bolted SHUT!, THE PCV hooks up to the manifold and the T in the crankcase. So the PCV is removed and the manifold has a bolt and the T has a bolt.
Message Board Statistics All times are GMT -4. The time now is 07:40 AM.
