Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 07-27-2008, 11:03 AM   #1
SEEC
Member#: 54200
Default How to Remove Turbo Oil Drain Tube on Head?
Hello,
I need to remove the engine side of the turbo oil drain so that I can modify it. This is the part I am talking about:
I have removed the bolt holding the bracket in place and applied as much force as I am comfortable applying w/o damaging anything. It will not budge in any direction. I would think that it should be light press fit with an o-ring in there someplace for sealing but I can not find any information about it in the factory manual. Has anybody here personally removed this? Is there some trick to this?
If you are interested in why I have to modify the oil returnůsee here:
PorSTi Conversion
I am transplanting an '05 Sti engine into a '73 Porsche 914.
Regards
Scott
SEEC is offline   Reply With Quote
Old 07-27-2008, 11:46 AM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
guess what kind of engine this car has?
good luck with the swap!
Old 07-27-2008, 01:24 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Hot!!
Old 07-27-2008, 09:14 PM   #4
SEEC
Member#: 54200
That is awesome...any build photo's of it?
Nobody has any ideas on the oil return fitting??? This is the last thing that I need to do to button up the turbo.
Scott
Old 07-27-2008, 10:28 PM   #5
gtasti
Member#: 152036
2004 Sti
try alittle more force that should only be in there with a O ring
and great build hope u got more pics coming
gtasti is offline   Reply With Quote
Old 07-29-2008, 10:43 PM   #6
SEEC
Member#: 54200
Well I finally got it out and it required a bit more than a little force. It is press fit in with no o-ring.
With a ring of glue for good measure.
So now we know and will not have to speculate next time....
Scott
Old 11-18-2012, 07:05 PM   #7
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
Good info to know...
THE DRAIN TUBE DOES NOT REQUIRE GASKET/O-RING
I was gonna post a thread asking, because I just took a head apart that someone used gasket maker on, so i needed to make sure they werent bypassing a o-ring and jerry rigging it together,
Hayaboosted is offline   Reply With Quote
how do you guys remove the oil drain tube on the head? ownnij Built Motor Discussion 14 12-10-2009 10:07 PM
Turbo oil return tube on RHS head? epoth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-15-2006 04:28 PM
How to remove the oil drain plug at the very end (before it drops) ImportVenom Service & Maintenance 22 11-12-2003 09:24 PM
WTB STock wrx turbo Oil Drain Tube Imprezd Private 'Wanted' Classifieds 0 08-17-2003 08:12 PM
ANybody know how to get a oil drain pan bolt out when it is stuck? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-28-2002 01:08 AM
