#1 |
Member#: 309638
RMIC
Vehicle:2011 wrx premium dark metallic grey |
Hi all I'm currently running stage 2 set up on my 2011 wrx. Current power mods are
Turbo back turboxs exhaust And Cobb sf intake I am currently in the process of deciding what mods I want to add before protune. As of right now I want a Dw65 265lph fuel pump Pw TMIC Grimmspeed ebcs Now my question . . . Is an air/oil seperator worth getting. Also I anybody recommends another mod or replacing one of these mods with something else let me know. Thanks
#2 |
Member#: 171948
Vehicle:08 wrx prem sedan vf52 swap. bilstein susp |
i think you mean an air oil seperator. i have a grimmspeed aos. it helped with oil in my intercooler issues.
#3 |
Member#: 309638
RMIC
#4 |
Member#: 171948
i was getting blow by issues. my perrin tmic was geting alot of oil inside and making the lower tmic hose loose. it wasnt enough oil to need a top off between changes. its just not good to have too much oil in there cause it can lower the octane and cause detontation.
#5 |
Member#: 112759
Vehicle:02 Srp STi... R ur Boltz to long???? |
Good stuff!
Our set ups whether stage 1 or 4 should have 1 installed IMO |
#6 |
Member#: 309638
RMIC
Well thanks for the info guys looks like I will as it to my list. Any other mods I should possibly add? I don't think injectors are necessary until turbo upgrade am I right?
#7 |
Member#: 268931
Vehicle:2012 wrx ice silver |
I've been debating on getting an air/oil separator myself. From what I've read the Crawford is the way to go but so far I haven't had any problems without one. I do drive the car pretty conservative.
Mods.. Invidia tbe, AEM intake, Forge bpv, Grimmspeed ebcs, Process West tmic, protune. |
#8 | |
Member#: 171948
#9 |
Member#: 268931
It's all in what you want and your future plans. A fuel pump and injectors wouldn't be a bad idea but not "needed" if you never plan on running an E85 tune or upgrading the turbo. My IDC was at 95% with stock injectors on pump gas so it's pushing the limits. You could always do an EWG before the tune also.
#10 |
n00b Moderator
Moderator Member#: 140114
Vehicle:06 18G Semi Built SGM WRX |
AOS's are fairly useless.
#11 |
Member#: 156877
Vehicle:04 sti |
Proof to said statement?
#12 |
Member#: 276425
#13 | |
Member#: 309638
RMIC
#14 |
Member#: 171948
#15 |
n00b Moderator
Proof is the MILLIONS of cars that have blow by (hint all of them in the past 40+ years) that not once needed an AOS or catch can. Blow by still happens. Blow by is not a horrible thing. Where is the evidence showing an AOS/Catch can has extended the life of a motor? I trust car engineers, if it was needed there would be one.
#16 |
Member#: 255776
Vehicle:2010 LR WRX MPS and PAR powered. |
Hinshaw, there is one built into your engine...it just isn't a very good one when you add power and mods. It's like saying you trust the engineers did a good job on the pistons and therefore will never have to worry about them.
#17 |
Member#: 136314
Vehicle:2014 Grand Cherokee |
#18 | |
Member#: 168101
Vehicle:07 STi Limited COBB Tuned GT35R |
#19 | |
n00b Moderator
I've always been against AOS's. And as much as most people like to say it, my opinions have stayed the same since becoming a MOD, and being one has nothing to do with them. ![]() Simple fact is, one can be MADE for cheaper then bought, and the money can be used for better needs. |
#20 |
Member#: 171290
SCIC
Vehicle:2008 STi Aspen White |
#21 | |
Member#: 298231
Vehicle:2011 Subaru WRX WRB |
#22 | |
Member#: 309638
RMIC
And as far as the aos goes i dont know what to do about it know. Im starting to think ill do that down the road. I had just read somewhere that it was a good safe mod when running 91 oct. Thats all i can get here in nevada it sucks. and no e85 here. My friends evo is now running on meth at 430whp its insane. The meth made a huge difference besides having to refill it all that time haha. Once again thanks for the replies guys much appreciated. I may just call a well known tuner i may go to. . . if i can find one in slc or reno and ask what he thinks. |
#23 |
Member#: 268931
It was a nice gain in power. Not a lot on top end but huge gains in the midrange. The car is smooth and very fun to drive now. Every car and dyno is a bit different but I ended up with 315whp/342wtq @ 20.5psi on 93 octane. I can PM you the graph if you want to check it out.
#24 |
Member#: 136314
#25 |
Member#: 171290
SCIC
