Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 10-21-2012, 07:36 PM   #176
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Originally Posted by scoobyboobys View Post
I wonder what kind of effects cool tape/gold tape have on temps. If you ever go in that direction please let us know. Currently running ptp blanket, heatshield, tmic cool taped, and my airbox gold taped.
Check out infrared testing volume 2 for this.
Old 11-17-2012, 08:16 PM   #177
hutch959
Member#: 267463
ok... have the ptp blanket. DP wrapped and i put the perrin dp blanket on today.
just left the wrap on and put the blanket over it.
install went fine.
One question.... the blanket rubs the firewall. There was only around 1/4 inch between the dp and the firewall and i had to work the blanket into position.
the blanket touches the firewall...
im thinking that will be ok. May rub the paint off the firewall, but i would think thats it.
any other opinions?
hutch959 is offline   Reply With Quote
Old 11-18-2012, 01:04 PM   #178
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
install went fine.
any other opinions?
Got any pics? From what it sounds like you will be fine, but it would help out a lot to have pics and to know what year and make of turbo subaru you have
Old 11-18-2012, 08:46 PM   #179
hutch959
Member#: 267463
yea... had a pic.. photobucket was messed up last night so i couldnt post it.
it works nows.
http://i1022.photobucket.com/albums/...rinblanket.jpg
2012 sti, cobb dp
Old 11-18-2012, 08:52 PM   #180
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
it works nows.
2012 sti, cobb dp
Don't worry about that, it won't even wear paint off. Its just material coming in contact.
Old 11-21-2012, 03:28 AM   #181
0BlueSTi4
Member#: 98955
2011 WRX Hatch
HeroCrank, any chance you could take a pic of hot air exiting the side fender vents with the car warm and radiator fans on? Curious to see just how functional those are. Thank you!!!
0BlueSTi4 is offline   Reply With Quote
Old 11-21-2012, 06:57 PM   #182
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Take some sample pics and lay out exactly what you want to see.
Old 11-21-2012, 08:16 PM   #183
hutch959
Member#: 267463
install went fine.
any other opinions?
after driving awhile, the diffrence is amazing. the tmic is cool to the touch after a long drive. the firewall is cool to the touch (i couldnt hardly touch it before). its a big difference.
i dont know if it helps or not, but i do know under my hood is cooler now.
Old 11-21-2012, 08:19 PM   #184
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Nice thread.
sackytar is online now   Reply With Quote
Old 11-22-2012, 12:13 PM   #185
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Originally Posted by sackytar View Post
Nice thread.
Thanks for stopping by
Old 11-22-2012, 09:52 PM   #186
0BlueSTi4
Member#: 98955
2011 WRX Hatch
This is the thread that got me thinking about the thermal image: http://www.iwsti.com/forums/gr-exter...rformance.html
I was basically thinking of a side shot of the front half of the car after it was driven hard and while the radiator fans are on - should be able to see if any of those side vents are functional. Thanks!
Old 11-24-2012, 08:52 PM   #187
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
I see what you are saying, I will poke around the car with the camera. This colder weather will make it easier to see if any heat will be escaping.
Old 05-26-2013, 11:27 AM   #188
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
I've been seeing a lot of new faces around here with new cars the past few weeks. The thermal questions are starting up again and I encourage you all to research before you buy and ask as many questions as you can. Ill bump the infrared testing threads and please contact me if you have any questions.
Old 12-29-2013, 10:09 AM   #189
G-WREX
Member#: 352340
2008 WRX Sedan
Gray Metallic
Bump for updates!?
G-WREX is offline   Reply With Quote
Old 12-29-2013, 10:50 AM   #190
nomoreshanks
Member#: 369799
2010 997 Turbo
Carrera White
I put a PTP Lava blanket on my new dom1.5xtr when I did the install. The one I got was for T3 sized turbo and wasn't the best fit I don't think... Its wedged on such that I really didn't need to use the included wire as its not going anywhere (I still tied one side together though).
Coupled with the GS heatshield my intercooler is MUCH cooler after a drive than without. Not very empirical but the blanket does make a noticeable difference. I get full spool (22lbs) by just shy of 3600RPM on stock UELH and I have to imagine this blanket is helping it happen.
nomoreshanks is offline   Reply With Quote
Old 12-29-2013, 06:51 PM   #191
G-WREX
Member#: 352340
2008 WRX Sedan
Gray Metallic
Nice no more shanks! What's she put Down now?
Old 12-30-2013, 05:55 PM   #192
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Originally Posted by G-WREX View Post
Bump for updates!?
There is no further testing with these products that is planned.
