Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 11-18-2012, 07:54 PM   #1
Chobo
Member#: 295276
Default Turbo heatsheild w/ DP wrap adequate?
Just wanted to get some second opinions on this. I recently installed a new DP and plan to use a PTP blanket on the turbo. I had also intended on installing a heatsheild, but realized I goofed and left off a bracket that heatsheild needs to mount.
Will I be OK with just a DP wrap and blanket? I'd rather not fight that DP again for a few months if I don't need the HS right now. Still kicking myself for forgetting that bracket... Thoughts?
Chobo is offline   Reply With Quote
Old 11-18-2012, 08:46 PM   #2
ya fine...no worries
and the bracket for the heatshield only requires that ya take off the 2 bolts on the top of the terbo to put the bracket on
take ya 10 minutes mebbe....
Uncle Scotty is online now   Reply With Quote
Old 11-18-2012, 08:48 PM   #3
hutch959
Member#: 267463
if you want more heat protection from the dp, you could install a dp blanket also....
hutch959 is offline   Reply With Quote
Old 11-18-2012, 09:40 PM   #4
Chobo
Member#: 295276
Thanks, I thought it would require one of the mount points on the lower stock heatsheild as well, but it looks like you're right. I'll go ahead and re-install that top bracket and all should be well.
Old 11-19-2012, 11:08 AM   #5
car_freak85
Member#: 13530
EA63 , EA81T, EG33,
EJ205
If you DO plan on pulling the dp in the future, I would suggest getting the pupe Swain Tech white lightening ceramic coated. Do a quick search, it's the only legit coating on the market.
Wrapping can promote rust, depending on dp material, driving habits and climate.
car_freak85 is offline   Reply With Quote
