#401 |
Member#: 273795
NWIC
Vehicle:2007 wrx tr urban metallic grey |
So I'm waiting on the shortblock. Should be done this week.
07 wrx tr Ej255 bored 20 over Wiseco coated hd pistons Eagle h beam rods Acl race bearings Sti polished crank Arp rod bolts Arp head studs 07 wrx heads(stock) Matched cosworth head gaskets Phenolic spacers Tgv deletes Air pump delete Fp red 8 cm hotside APS 3" turbo inlet Blitz huge short ram intake and big maf housing with custom intake piping Air intake temp sensor relocate Turbo xs front mount intercooler 920 cc injectors Walbro 255lp fuel pump Snow performance methanol injection 05 sti drivetrain with 04 brembo brakes Act six puck clutch kit All Samco hoses Will be tuning at MPS in Arlington Washington Dyno dynamics dyno I live in Wenatchee, Wa What do you think? Also more wondering what she's gonna do at the drag strip??
#402 |
Member#: 273795
NWIC
Oh and 93 octane btw :-) and 780 ft elevation here in Wenatchee.
#403 |
Member#: 325634
great thread.
#404 |
Member#: 293159
South East
Vehicle:2005 WRX CGM |
1) 300whp.
2) Dyno Dynamics 3) Forged Performance, Atlanta, GA. 4) Cookeville, TN Elev. 1,200ft 5) 93 octane 6) Yes, I'm opposed to a FMIC. I've been thinking about a 16gxt plus whatever else the tuner recommends for supporting mods. Would that get me close? How is 300whp for reliability? I've got a new OEM exedy clutch and the stock 5spd, I don't plan on doing any drag racing or hard launches; mainly just a DD with some rallyx and autox tossed in. |
#405 |
Member#: 279219
NWIC
Vehicle:2002 wrx wagon psm |
~300whp
Don't know the dyno.. COBB Surgeline Portland, OR 92 oct tmic 2002 wrx wagon with 130k cobb ots stage 2 invidia catless dp hks hi power catback ptp turbo blanket |
#406 | |
Member#: 178426
Vehicle:2010 Evo X MRt Silver |
#407 |
Member#: 178426
If your goal is 300whp, you need a bigger turbo. Call them and ask what they would recommend. With that high of mileage, don't mod till you can afford an engine build, a new clutch, and prolly synchros at least for the tranny.
#408 |
Member#: 291681
MAIC
Vehicle:'04 STi PSM - 340whp/340wtq |
~320whp
Dynapack TurboXS Gaithersburg, MD 93oct FMIC 2004 STi VF48 APS 650 FMIC 820cc injectors Walbro 255lph pump Turbo inlet Short ram intake TXS 4in downpipe TXS RFL cbe Tial 38mm ewg Worx Tuning bov ACT street/strip clutch ACT streetlite flywheel |
#409 |
Member#: 262692
MAIC
Vehicle:1999 GC ej217 WRB 22b widebody built fp red |
1. HP at the WHEELS- looking for around 350whp...ish, happy with 320whp
2. What type of dyno- dynojet 3. what shop it is- All Aspects , probably going to have a guy Shad tune it, he has always pulled great RELIABLE numbers out of our track cars. 4. Where do you live- Hampton Roads, sea level 5. octane level- Shell 93...always, and will drive 20 miles to get it over bp sludge, bp always tests out lower octane here by the local college ODU, shell typically tests out about 96 to 97 octane ![]() 6. Are you opposed to a FMIC? I have a front mount now. some more info, its is a version 6 ej207 sti swap, no ac, fmic, 2.75" TBE, intake is fabbed. currently has vf28 turbo running 19psi self tuned (i know what im doing somewhat it is running on an AEM EMS-4 standalonei know i will have to upgrade turbo and the 440cc injectors, got a td05 turbo sitting on the shelf at the shop tight now, been debating if it is a waste of time. I have a TON of experience modding cars, this is my first endeavor in subaru though, typically honda, nissan, cobras and toyota inlines (2j,1j,7m) you get the point. this boxer is harder to rebuild than my rotary was lol thanks for the input guys.Last edited by SlowTrackImpreza; 12-17-2012 at 11:42 PM. |
#410 | |
Member#: 23676
NESIC
Vehicle:. |
TD05-20G 8cm with a 44mm EWG, run about 19 maybe 20 PSI. Should put you where you want to be with reasonable spool up. As for swapping from a vf28 to a td05, depends on a few things. 1. If you are good at swapping turbos and have gaskets (in other words if it wont take you long, like I can swap turbos in ~20 minutes) and can adjust your own tune, go for it. EVen a 16G will be minorly better. Not better peak, but a little more responsive. If you have to pay ANYTHING< then don;t bother if its a 16G 2. What Td05 is it? 16/18/20G all come in TD05 versions. If its an 18G or larger, then its worth doing if you can do it CHEAP. If its a 16G, see above. If its a 20g, yes, do it, its the turbo you want. And it sounds like you have already figured this out, but take what you know about tuning on all those other cars, and basically throw it out the window. Subies are pretty unique in their tuning needs fuel/timing wise. |
#411 |
Member#: 280177
Vehicle:2011 wrx DGM |
WHP Goal: 350+
EFI's Mustang dyno in CT. 93 oct. TMIC Mod List Built Shortblock wiseco pistons turbo tuff rods arp bolts acl bearings tgv deletes process west tmic ks tech 65mm intake.....thinking of upgrading to 73mm cobb uppipe and downpipe spt exhaust invidia el headers ebcs 850cc injectors DW 65 fuel pump 1.5xt-r 8cm So can this get me to 350+whp on 93 oct? Currently at 285hp/340tq. Thanks for your opinions and thoughts. Last edited by J wrx11; 12-27-2012 at 02:26 PM. Reason: adding info |
#412 |
Member#: 279870
HIIC
Vehicle:2005 WRX Wagon Black |
1. 280 hp at wheels
2. Dynojet 424x 3. Rads Motorsports in Hawaii 4. Honolulu Hawaii so sea level. 5. 91 Octane 6. Opposed to FMIC 2005 WRX Wagon 85xxxmi My Mods vf39 PLANNING ON A Bloush 16g-xt wrx dark blue injectors grimmspeed ebcs aem cai perrin light crank pulley helix bellmouth downpipe custom catless piping from downpipe to borla hush muffler Megan Unequal headers/ uppipe combo Godspeed TMIC stock fuel pump As far as i know Stock block and internals 5MT (how this is still alive I dunno) OEM clutch Street tuned by PDX Havent dyno'd becaust ****s $140 out here |
#413 |
Member#: 343242
Uh, what kind of car methodically
#414 |
Member#: 67181
2002
Catless Up-pipe Catless TBE ProTune 180K What would the HP/tQ be? Chris |
#415 |
Member#: 330696
NWIC
Vehicle:05 Saabaru 92xAero |
2005 Saabaru 9-2x
Engine Mods:
What am I looking at on a conservative tune with 92 octane gas. Thanks for your input! Last edited by JLD13; 02-19-2013 at 12:40 PM. Reason: oops... changed from 91 to 92 octane |
#416 |
Member#: 330695
Vehicle:2005 WRX STi WRB |
One of the best posts here on NASIOC
#417 |
Member#: 348396
Factory 5 818
Looking for 220 HP at the rear wheels 05 2.0 WRX with 70,000 miles power steering and AC delete Ceramic coated unequal length header and catless up pipe very short exhaust (mid engine) AEM intake lightened flywheel Cobb or open source tune longer term TGV delete |
#418 |
Member#: 345599
Great post Thanks!
#419 | |
Member#: 178426
You don't need tgv deletes with the stock turbo. You should be pretty close to your goal. The only real factor is the dyno it certainly helps that you have no AWD drivetrain, power steering, or ac sucking power. Also, pics and a build thread need to be up for this. It sounds like a fun setup. |
#420 |
Member#: 350085
300 HP on dynojet
2002 WRX on 93 octane Ported and polished heads Brian crower titanium valves 1mm oversized Brian crower copper valve guides Super tech dual valves springs Catless up pipe Big 16g turbo Big TMIC Dw 750cc injectors Dw 255lph fuel pump 4 ply silicon turbo inlet pipe Cobb short ram intake Invidia Catless dp Straight piped Catless exhaust (will be coming off and switched for catback exhaust) |
#421 |
Member#: 339781
About a year ago my WRX dyno'd at 306WHP and 316TQ.
This seems low to me. I run E85 with a number of mods at 18 boost psi. My mods are 890cc Injectors Walbro 255 Fuel Pump Aftermarket (Brand unknown) Fuel Pressure regulator at 40-45 psi Short Ram Intake w/K&N OBX Headers and bell mouth downpipe Unknown Brand Uppipe SPT 3'' Exhaust w/High Flow Cat TGV Deletes Grimmspeed Phenelic Spacers FP 68HTA Turbo HKS SSQV BOV Hallman Pro Boost Controller Front Mounted SPT Vishnu Intercooler Perrin 22mm Front Sway Bar Open Source Tuned by Harvey at The Boost Creep Ltd - Dyno Tuning and Automotive Services in Longmont Colorado Does 306 sound low to you?? I know running here in Colorado Springs saps my numbers a bit too but still.... Also what would you do next? Was considering a clutch kit but dont have the cash in hand to do that just yet. Anything i can do for $100-$200 for now? Thanks in Advance! |
#422 |
Member#: 147839
MAIC
Vehicle:2003 WRX SRP |
#423 |
Member#: 339781
You mean without a previous number, before the mods...?
#424 |
Member#: 147839
MAIC
Optimally, yes.
#425 |
Member#: 339781
Gotcha. Well thats annoying
| Thread Tools | |
| Display Modes | |
| I’m flying to Orlando. What do I need to do in the airport and what to bring home? | KingGalantVr4 | Off-Topic | 37 | 01-14-2010 11:49 PM |
| what do I need to hit 250whp? | juvenescence | Newbies & FAQs | 27 | 10-07-2009 10:47 PM |
| What do I need to hit 350-375 HP? | pipchick | Newbies & FAQs | 49 | 08-15-2009 04:04 PM |
| I want to do my own 30,000 mile service, what do I need to do? | Drav | Service & Maintenance | 12 | 06-20-2005 06:43 AM |
| ('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! | SuBaRu-ImPrEzA_RS | Impreza Forum | 2 | 06-03-2001 10:11 PM |
