Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 09-17-2012, 02:00 AM   #101
redzfit
Member#: 191518
2010 EvoX<--H8Mitsu
2011 Mini S<-- Now
Any updates within the last 9 months?
redzfit is offline   Reply With Quote
Old 10-02-2012, 10:19 PM   #102
xreign
Member#: 123859
06 STI 330hp/357lb
Yea been beating my sti all day every day still no problems been almost 4 years now still 331 whp. great compression so i'd say its fine
xreign is offline   Reply With Quote
Old 10-05-2012, 12:14 AM   #103
wayoutwest
Member#: 14379
2005 GT30R STI
white, 360/360 @ 20PSI
Default ..
Running 360/360 @ 20 PSI on my stock block (was 385/370 @ 22 PSI before i added a cat) with a .82 GT30R ... alot depends on what safety mods you have in addition to your power mods. Never had a hiccup. I have a lot of safety mods though. Keep in the intake temps cool and boost under control and that helps a lot. So I am not too much over 350, but have had a compression test and Blackstone labs test and both came back perfect.
good luck,
dave
wayoutwest is online now   Reply With Quote
Old 11-19-2012, 03:30 AM   #104
coolerthanafan
Member#: 303215
2008 STi
I know this thread says 350+ but my question is geared toward 295-300 whp. I have 55k miles, Cobb stage 2 and want to get a stronger bov or bpv, a Cobb up pipe and intake & air box and possibly an ets tmic. I'd like to keep boost at 18.5 with a custom 92 octane tune. I'll be doing this before the end of the year. Should I replace pistons? Should I replace head gasket? What gauges should I add? I don't want to add gauges to look cool, just for safety.
coolerthanafan is offline   Reply With Quote
Old 11-19-2012, 03:56 AM   #105
GrumpyPitbull
Member#: 313311
2012 WRX 5 Door
Plasma Blue
good luck,
dave
The bold/underlined part of his statement is the key to reliability.
As you add power increasing mods, you must also upgrade other supporting components that do not add power to keep it reliable. Many people neglect mods that are for safety/reliability because they do not add horsepower, and they would rather spend that money on more power.
Hence, reliability suffers and stuff eventually breaks ... then they come on NASIOC and yell about how Subaru sucks.
GrumpyPitbull is online now   Reply With Quote
Old 11-19-2012, 08:10 AM   #106
Syndr78
Member#: 336966
2013 WRX
Although I'm not intending to pursue 350whp anytime soon, I had inquired in this thread http://forums.nasioc.com/forums/show....php?t=2433692 about the merit of a supportive mod like a TMIC upgrade even at just stage 1 levels.
I guess my soobie noobie thought process was that bigger TMIC/cooler temps would prolong life/reliability at ANY increased power levels. Kinda like a "give back what you take out" mentality. I already got the PTP turbo blanket, and am debating what intake to go with (cobb sf w/box or AEM).
I totally subscribe to the power mod:supportive mod idea...
Syndr78 is offline   Reply With Quote
Old 11-19-2012, 07:33 PM   #107
ProfessWRX
Member#: 323379
06 WRX
Having a bigger intercooler on a stage 1 car is not necessarily going to give any reliability, but it can certainly make sure you are always at optimal timing. You can also possibly add some. Scanning is the #1 key to reliability. If you aren't scanning, you don't care about reliability.
Can 400+ whp be safer than 350 whp? drfrink24 Factory 2.5L Turbo Powertrain 22 01-24-2008 02:47 AM
Most reliable way to reach 300 - 350 whp on a STi? trail*of*dead Factory 2.5L Turbo Powertrain 16 09-15-2004 02:25 PM
Over 350 whp on stock ecu? WRC WRX Factory 2.0L Turbo Powertrain 9 12-16-2002 03:49 AM
what is needed for at least 350 whp WRX IS HOT Factory 2.0L Turbo Powertrain 2 10-28-2002 09:46 AM
So If Im going to push 350 WHP?? EneMy X Transmission (AT/MT) & Driveline 17 01-29-2002 08:31 PM
Message Board Statistics All times are GMT -4. The time now is 03:02 PM.
