Old 11-18-2012, 08:42 PM   #26
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
turbo lag is not and can not be the same as deylayed throttle response
no
no ****ing way
and the throttle CAN BE TUNED a bit to reduce this...but.....
Old 11-18-2012, 09:58 PM   #27
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
no
no ****ing way
But more volume means more delay. period.
Old 11-19-2012, 01:47 AM   #28
PlanetGranite
Member#: 156635
2005 Sti
CGM
It's a change in throttle response. NOT turbo lag. Same volume of air is flowing through the turbo at the same velocity as it was before the FMIC install. The difference now, as many have stated, is that the distance between the compression point (turbo) and throttle plate has grown by eleventybillion feet. Making for less responsive throttle inputs.
A new tune will account for the change in pressure drop across the old TMIC and new FMIC, and maximize the charge cooling gain with the FMIC. But you won't see a magically noticeable increase in throttle response. Just something to get used to.
BUT, do yourself a favor, and do a leak check at all the FMIC pipe couplers. Most often you'll find a leak somewhere that is making the throttle response even worse than it should be.
PlanetGranite is offline   Reply With Quote
Old 11-19-2012, 02:33 AM   #29
Uncle Scotty
OK buy Nates beans
delay aint lag...its delay
and i said tuned, not eliminated
too many kiddie boiz thnk that fmic's are just the only bestest thing in the world
they aint
Old 11-19-2012, 08:44 AM   #30
voltic
Member#: 310385
Chapter/Region: HIIC
2016 BRZ Limited
Series.HyperBlue
I don't really give a crap what your opinion is on my setup. That's how it is. I asked for reasons this might be causing a delay in throttle response, not for a lecture on reasons you don't like a FMIC., but instead you feel the need to take subtle stabs at me as you do in half the threads you post in. I'm done reading this thread, I'll ask my tuner.
voltic is offline   Reply With Quote
Old 11-19-2012, 09:38 AM   #31
Badler
Member#: 133597
Originally Posted by RoadKillDMD View Post
Get a tune... ASAP. You can drive around, but stay off the throttle and out of boost. There's a reason you're feeling this 'delay'. Your fueling is tuned for a TMIC. With the FMIC, boost takes a little longer to get to your engine, so it's creating a 'choppy' section in your power band that can be smoothed out with a tune. Resetting your ECU will not magically fix this...
It's a MAF based system. Fueling stays the same. A tune will help, but not for the reasons above.
Badler is offline   Reply With Quote
Old 11-19-2012, 10:00 AM   #32
Tripintaz
Member#: 245218
2013 STI Limited
Originally Posted by voltic View Post
Despite my insatiable need for approval from people I don't know, I was looking more for answers as to whether this was a problem or a common thing.
It can be greatly improved with the right tune...and an aftermarket EBCS.
Originally Posted by sense of nature View Post
^ This makes me
Oh really? why so? I'm absolutely sure I am right. I'd like to know how you think otherwise simply for amusement.
no
no ****ing way
It can be improved, but it will never feel the same as the stock TMIC. However without a doubt the so called "laggy feeling getting into boost" can be greatly improved with the right tune and an EBCS.
Old 11-19-2012, 10:35 AM   #33
rocketperson7
Member#: 283968
2003 WRX
MBP
Pro Fact: Every turbo Subaru comes stock with an EBCS already included
rocketperson7 is offline   Reply With Quote
Old 11-19-2012, 11:07 AM   #34
Tripintaz
Member#: 245218
2013 STI Limited
OK so since I need to spell it out. I'm referring to an aftermarket 3 port interrupt style EBCS.
Old 11-19-2012, 04:51 PM   #35
WhatTurboLag?
Member#: 243992
2006 WRX TR
What?
WhatTurboLag? is offline   Reply With Quote
Old 11-19-2012, 05:03 PM   #36
Badler
Member#: 133597
When did an EBCS start becoming a fix all around here? Lots of stupid in this thread.
Old 11-19-2012, 06:07 PM   #37
Groundup
Member#: 294682
02 wrx
Sedona Red
You just gave yourself the best advice about what you should do to make it better.
Groundup is offline   Reply With Quote
Old 11-19-2012, 07:00 PM   #38
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
^ It was Sunday at the time, man.
Old 11-19-2012, 07:04 PM   #39
Tripintaz
Member#: 245218
2013 STI Limited
Fix all? I did not say that at all. Read again and I said there would be improvements when you combine the EBCS with some specific tuning changes. Don't get me mixed up with some of the people here that are not talking from knowledge and experience.
Old 11-19-2012, 07:15 PM   #40
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
I'm pretty sure I read somewhere that not nitpicking semantics solves these confusing thread problems.
Old 11-19-2012, 11:56 PM   #41
FLEX'N WRX
Member#: 163672
GV
Same color as veneers
Quit reading, you do not comprehend appropriately.
No semantics are involved in this thread. There is a technical difference with the incorrect term and correct term used to describe what the OP was feeling.
Do not post in threads you cannot offer insight to. It'll make threads confusing.
FLEX'N WRX is offline   Reply With Quote
Old 11-20-2012, 12:07 AM   #42
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
It is shockingly apparent you don't know what semantics are. But by all means, continue the bitchfest. I hear acting like a little girl online actually makes your Epenis longer.
Old 11-20-2012, 12:11 AM   #43
FLEX'N WRX
Member#: 163672
GV
Playing semantics with semantics...
Have fun
Old 11-20-2012, 02:32 AM   #44
kenlee
Member#: 49341
^ This makes me
Not sure whats so funny....Alot of magician tuners can tune out 5+ feet of piping
kenlee is offline   Reply With Quote
