Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 11-19-2012, 11:17 AM   #1
BrendanTheGreat408
Member#: 271207
Default What the F%$* just happened???
I was just driving my car (2011 wrx, catless dp, perrin exhaust, forge bpv, perrin tmic with torqued performance stage 2 tune) and went to pass someone on the freeway at about 60-70% throttle after building boost for a matter of a few milliseconds my car stop pulling and slowed down and i heard a banging sound (i felt as if my tmic had came unbolted and smacked against my hood to try and explain the sound) then milliseconds later my CEl light came on and the car began to pull again but of course i let off completely. The CEL remained on for the rest of my 5 mile drive. I got to work and popped the hood and everything looked and sounded fine so i turned off the car and turned it back on again with the CEL. Any idea what the *&^$ just happened?
Note* I just installed the TMIC yesterday and had sent in two 3rd gear pulls to Eric who then returned with a new map (still stage 2 tuned).
BrendanTheGreat408 is offline   Reply With Quote
Old 11-19-2012, 11:22 AM   #2
DNut
Member#: 151739
First thing I'd do is identify what code is triggering the CEL.
Get a lift from someone at your work to the local parts store and pick up a cheap reader?
DNut is offline   Reply With Quote
Old 11-19-2012, 11:31 AM   #3
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
#1 is to check the CEL.
My guess is either a boost leak or an overboost code.
Did you remove the rubber end caps from both ends of the throttle body to TMIC hose? If not, I would definitely do that (both ends).
Old 11-19-2012, 11:36 AM   #4
swpshgnwgn
Member#: 150494
17 WRX Limited
Yeah, my bet from what has been said is the p0244. Scared the living **** out of me the first time it happened.
swpshgnwgn is offline   Reply With Quote
Old 11-19-2012, 12:10 PM   #5
BrendanTheGreat408
Member#: 271207
Rubber throttle body thing? Idk i just took off the oem tmic and bolted up the front one.
its scarred my ****less right now lol,
I think it might be an over boost code, i actually had the accessport running at the time and it was showing boost, after it happened i noticed i boosted 21psi when it only should have been 19
Old 11-19-2012, 12:12 PM   #6
Tripintaz
Member#: 245218
2013 STI Limited
Most likely thing would be you over boosted.
Or you might have popped the TB to intercooler hose.
Or both.
Old 11-19-2012, 12:54 PM   #7
mackeymx
Member#: 258525
2004 STi-BW7670
R6-Red/White
If you have an accessport then check the code!
mackeymx is offline   Reply With Quote
Old 11-19-2012, 01:00 PM   #8
Joshz400_03
Member#: 198844
2004 WRB STi
haha this!! I'm guessing this is it too..After going to a hybrid boost setup and ewg I hit fuel cut on my way home from tuning (high gear boosting) Over boosted thought I blew the motor lol
Joshz400_03 is offline   Reply With Quote
Old 11-19-2012, 01:05 PM   #9
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Could have been a intercooler hose popping off, but you would be able to notice that now if that were the case. So it was more likely a big backfire from improper tune/timing. If that is the case..... id be asking for my money back and finding a new tuner.
Old 11-19-2012, 01:57 PM   #10
Tripintaz
Member#: 245218
2013 STI Limited
Your reading comprehension score must have been on the low side. He has an OTS tune from TP. That map did not cause a big backfire due to poor tuning or timing. Most likely he hit boost cut or popped the TB hose.
Old 11-19-2012, 02:41 PM   #11
dsmtweaker
Member#: 265405
2013 Audi
If his car backfired, he would not be driving home, as he would have destroyed many things. if it was after fire(which I believe is what you meant) then it would have been an exhaust pop(not under the hood) and would not throw a cell, as that happens post cat, where there are no more alarm sensors.
Also, over boost would through the cell, but not make the noise OP has described.
99% sure you will find, as others have suggested, that your TB hose came off. The factory ones are notorious for doing this, even with stock TMIC. Either take off the glued on end pieces, or order a replacement like the AVO.
dsmtweaker is offline   Reply With Quote
Old 11-19-2012, 04:44 PM   #12
BrendanTheGreat408
Member#: 271207
After doing some research and reading the code it was P0244 aka the over boost code. I checked the hoses and they were all still mounted. it looks like the engine over boosted and shutdown to prevent damage.
Old 11-19-2012, 09:36 PM   #13
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
OTS?
boost cut?
sure
No, I meant backfire.... Ive herd and seen it happen on subarus. Most common on N/A subarus or EJ20 WRX's with TGV deletes and no tune for them, it will happen. If small enough it wont hurt, there are many other ways to get back fires on EFI engines. OP has AVCS and if the timing was not properly adjusted for many things that I really dont want to get into, it could have done that in the higher RPM that he had this happen at. Yes it would have to be pretty damn far off, but being it was E-tuned..... you never know what is going on. Remember, OP says "the car started slowing down then POP", all while at 60%-70% throttle. Sounds timing related to me. Further, op never said anything about the car running like $hit after it happened. Not having a intake related hose connected will cause engine stall, poor idle, and Zero boost. Where did op state any of that additional info!?!
OP, if youre car boosted fine after this happened, then it was something else. But you never stated it didnt boost after or didnt idle correctly. If you blew off a hose the car would have almost shut off and would be falling on its face when you gave it throttle after it happened. But you have yet to say this also occurred. This is WHY im left with saying it may have been a serious backfire and you may have been lucky it didnt cause major engine damage.
Old 11-19-2012, 11:36 PM   #14
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
What gear were you in when you went to pass? If you were mashing on it in 5th along with the catless DP...I would also say over boosted.
DurtyB is offline   Reply With Quote
Old 11-20-2012, 12:07 AM   #15
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think UK-Wagon is way off base here. You're better off talking to Eric about the issue. He'll be a lot more capable of diagnosing and resolving it.
Old 11-20-2012, 08:21 AM   #16
NoGraffix
Member#: 276209
I am Rub
Function>Form
It was a simple over-boost. It sounds like you attempted to go WOT in too high of a gear (5th?) where you had a high load situation. Since you didn't mention you had an EWG I'm assuming you dont and your IWG was unable to compensate for the amount of air the car was flowing. This caused the turbo to pressurize an excess amount of air. The MAP sensors saw you reached a certain defined limit and cut the fuel in order to stop the over boosting.
You learned a lesson; don't go WOT in high gears, always down shift. You can also inform eric of this happening and he can likely adjust the WGDC and TD tables to help prevent this (possibly even raise the limit since 21 psi isn't all that high). It's likely he wuill tell you to stay off WOT when in a high gear situation.
NoGraffix is offline   Reply With Quote
Old 11-20-2012, 08:56 AM   #17
jthatch12
Member#: 321715
03 Big 16G WRX
The pop was fuel cut (scary experience, i know) from..... you all guessed it. Overboosting
Old 11-20-2012, 09:17 AM   #18
Tripintaz
Member#: 245218
2013 STI Limited
OTS?
boost cut?
sure
Go back and read the post right before your heavenly words. OP posted already and said he checked the codes and it was the overboost CEL.
So looks like I was right again. .... MR GURU
Old 11-20-2012, 09:19 AM   #19
Tripintaz
Member#: 245218
2013 STI Limited
He has been way off base on multiple threads lately. Maybe hes thinking at a far too advanced level...or something...
Old 11-20-2012, 09:22 AM   #20
Fitzy06
Member#: 246645
2006 Impreza WRX
Another +1 for P0244 Wastegate control solenoid valve malfunction (Over Boost). Just google that CEL code and you'll see other posting very similar details.
Fitzy06 is offline   Reply With Quote
Old 11-20-2012, 09:37 AM   #21
Ignored281
Member#: 202011
10 WRX Sedan
305hp/355tq
Same thing happens in my 2010 with similar mods, P2044. Mine will do it in 4th around 5k rpms.
Is there a common fix for this?
Ignored281 is offline   Reply With Quote
Old 11-20-2012, 09:48 AM   #22
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
External wastegate or porting the stock wastegate helps.
Old 11-20-2012, 10:19 AM   #23
Ignored281
Member#: 202011
10 WRX Sedan
305hp/355tq
thanks...
Old 11-20-2012, 10:38 AM   #24
Tripintaz
Member#: 245218
2013 STI Limited
Putting the stock intake back on will help. But the most common fix is an EWG.
Old 11-20-2012, 10:47 AM   #25
NoGraffix
Member#: 276209
I am Rub
Function>Form
An EWG is the only fix for a true boost creep/spike. If its poor tuning or the stock bcs issue those can be fixed with well proper tuning and a 3-port solenoid. Porting the IWG can help, but often you will still experience creep if your running an excess of 21 psi (as me how I know). Sounds to me like the OP has a case of unfinished tune. He put a new top mount on, the tuner turned up the boost a bit (since he can now, no more crappy plastic end tanks) and hasn't fully adjusted the WGDC or TD tables to properly achieve targeted boost.
