#1 |
Member#: 100300
MWSOC
Vehicle:06 WRX CGM |
Put a window screen (standard aluminum stuff) over the TMIC. I don't think it impedes airflow much at all. Am I wrong? I don't have Amy way of knowing if the IC isn't working 100%.
#2 |
Member#: 314408
Tri-State
Vehicle:2011 WRX Stage 2 SWP |
I probably would've went with something with a little heavier mesh and a little bigger openings. Birds and rocks are about all you gotta worry about, most non-Amazonian bugs won't damage your tmic too bad or at all. Take it out and put it in front of a decently powered fan and see how much air flow you get through it. Not real world driving conditions but it'll give you an idea.
#3 | |
Member#: 6697
MWSOC
Vehicle:2011 WRX 5-door Look-At-Me Red |
#4 |
Big Ron
Moderator Member#: 18062
MAIC
It will impede airflow, how much no one knows. Take it off and live your life. Will the screen work better than a few bent fins caused by bugs....who knows...who cares....if there was a need, the 79 engineers at Fuji Heavy Industries would have put one there.
#5 |
Member#: 100300
MWSOC
The car is totally stock. I've had a screen on there since I bought the car. Just replaced it for the first time. The fins are in great condition probably from the protection the screen gave them.
#6 |
Member#: 181298
MAIC
Vehicle:02 , Vf43 Inside.. 12 seconds at a time |
This thread is ridiculous... are you just bored and wanted something to do so you added a screen over your tmic because you dont want bent fins? Did you do the same for your radiator while you were at it?
#7 |
Member#: 100300
MWSOC
F yeah I don't want bent fins!
#8 |
Vehicle:OK Houston we have an Uncle |
#9 | |
Member#: 131379
MAIC
Vehicle:2003 354 ftlb@3k rpm justablue hatch |
use hardware cloth (at any home supply place) $5 buys enough for your tmic and radiator. i tripled over my tmic. air flow is not an issue. i clean when anough bugs/rocks/debris shows. paint the radiator screen flat black and no one will know its there. andrew at andrew tech endorses this. only noobs think no protection is safe ![]() |
#10 |
Member#: 254958
I like the idea but I don't want a restriction.
I have a tweezers in the door pocket, I use it to straighten out fins while filling with gas. |
#11 |
#12 |
Member#: 294328
South East
Vehicle:2011 WRX SWP |
Did you put a 20lb ballast in the trunk and an intake restrictor on too?
If you're going to mod the car, MOD the car. Otherwise, leave the engineering to the engineers. |
#13 |
Member#: 131379
MAIC
