#1 |
Member#: 152176
MWSOC
Vehicle:2001 2xImpreza 2.5RS BRP/SRP |
I have 2001 RS.
Finally test fitted my autopower race roll bar. I did specify that car has sun roof (I think, it was long time ago) What are some of my options for delete if I can't make it work? I'm asking in this section because I'd like to take this car out on a road corse next year. thanks for all the help -slava
#2 |
Member#: 733
MWSOC
Vehicle:'13 Focus ST '85 GTi rally/road race |
So does it fit or does it not fit? You don't really say.
If you're looking to delete the sun roof, you can weld in a blanking plate. If you want to keep the roof, you could cut down the hoop and re-weld the mounting plates. |
#3 |
Member#: 84181
NESIC
Vehicle:NASA #530 PTC |
Or you could do what I did and rivet a piece of aluminum down to the roof
#4 |
Member#: 152176
MWSOC
It didn't fit, but I didn't try making it fit yet either. I do want to delete all that, thought of a manual pop up option of some sort.
Want to stay away from welding at this point. |
#5 |
Member#: 152176
MWSOC
Rokkit, I like your rs. I want to flare mine but don't know what would be a good wheel size set-up. Don't want to go too heavy. Car will see auto-x and some track. Some weekend driving.
#6 |
Member#: 91562
Vehicle:1995 impreza,awd reddish |
what form of racing is that car set up for?
#7 | |
Member#: 84181
NESIC
I also run a +45 enkei with a 15mm spacer... so it's a bit of offset. (just for some tire reference) |
#8 |
Member#: 634
TXIC
Vehicle:2000 Impreza 2.5RS DSP#195/ZzyzxMotorsports |
I just took the door from the moon roof assemble and bolted in down to the opening. There are studs on the door and body that you can use with a small bracket to hold the door in place.
#9 |
Member#: 152176
MWSOC
![]() Patrick: you make brackets to hold the skin down? I have no idea what type of racing it will be for. This car was swapped and built years ago, back when I was younger and a big dreamer. Now I just want to get it back on the road and enjoy it. Probably will auto-x and hope to go to gingerman raceway a few times. |
#10 |
Member#: 152176
MWSOC
I was thinking of 17x9.5 or 18x9.5 with low offset. Maybe +15 up to +30. With 255 or 265 tire for now.
#11 |
Member#: 152176
MWSOC
Thinking of 240 flares or trying these:
http://www.aptuning.com/index.php?pa...mart&Itemid=14 Rokkit, how much cutting you do and did you weld in the rear? |
#12 |
Member#: 105104
VIC
Vehicle:1979 BRAT / 01 RSTI 99 2.5TS (DEAD) / 87 GL |
as far as I know most racing series won't let you have a functional moon/sun roof installed. It needs to be blocked off and disabled. So making a spec cage that fit with the moon roof would be odd.
#13 | |
Member#: 84181
NESIC
#14 |
Member#: 152176
MWSOC
What you do to front fenders? I just got an EF2 turbo for it
#15 |
Member#: 152176
MWSOC
Maybe I'll get L roof and do roof scoop
