Old 11-20-2012, 03:32 AM   #26
bpang1
Member#: 67225
2004 WRX Wagon
JBP
Originally Posted by gunz4me View Post
My only complaint about DD Head Units is the fact that they are essentially obsolete the day they hit the market. I find them painfully slow and fairly dead-ended when it comes to applications, upgrades, and all that fun stuff.
The fact that I can put my Pioneer DEH-80PRS in application mode and connect virtually any i-Device to it really has me thinking of sticking an iPad mini in front of it.
Feel the same way...every DD head unit I've played with in Navigation mode has been so slow to think stuff up.
Being able to use a HU to play the audio and a iPad or other tablet to do the thinking seems like a huge plus in my book.
bpang1 is offline   Reply With Quote
Old 11-22-2012, 02:45 PM   #27
scubynoob
Member#: 276157
2006 WRX sedan
The idea I'm working with is to gorilla glue some neodymium magnets to the back side of the left and right of the factory bezel. Get an iPad mini cover from eBay and gorilla glue some more magnets. Cover with a soft durable material and bam instant removable tablet.
Idea came from me working in a lab and wanting to take my tablet with me for music but not wanting it to be in the way. So with the magnets I can slap it the my work bench or vented hood and it's good to go.
scubynoob is offline   Reply With Quote
Old 11-22-2012, 03:35 PM   #28
rube23
Member#: 92710
2008 STi
Obsidian Black Pearl
Originally Posted by zedix View Post
Quick shot of the finished result (in 2010 impreza ltd):
can you post up some more pics and info?
how do you have it integrated into your car for music?
rube23 is offline   Reply With Quote
Old 11-24-2012, 09:38 AM   #29
zedix
Member#: 336913
2010 Impreza Ltd
I posted all the details in this thread: http://forums.nasioc.com/forums/show....php?t=2434390
If you have any more questions let me know!
zedix is offline   Reply With Quote
Old 11-27-2012, 01:36 AM   #30
naked_dave1
Member#: 301692
Well the guys that I linked a video to in my first post did an install of the iPad mini in an STI. They are definitely helping my get a better idea on how to build something as I've never worked with fiberglass or body filler. Still not a big fan of how it sticks out on top though.
Does anyone here own that STI?!
Starts at 40s and then again at 7m30s
naked_dave1 is offline   Reply With Quote
Old 11-27-2012, 02:58 AM   #31
kyletakahero
Member#: 185030
2013 STi SWP Ltd.
Slowest STi evaaaar
I definitely want something like that for my GV.
kyletakahero is offline   Reply With Quote
Old 11-27-2012, 08:14 PM   #32
sgp250r
Member#: 256882
2005 WRX Sedan
With the height (mounted sideways) you probably are not going to be able to keep it below the top unless you modify the vents.
How tall is the Mini and then how much space is there from the top of the vents to the top of the bezel?
sgp250r is offline   Reply With Quote
Old 11-27-2012, 09:08 PM   #33
naked_dave1
Member#: 301692
I plan on modifying the vents, just got a spare to mess with.
The mini is 5.3in
The top of the vents to the top of the bezel is ~4in
Need to trim down the vents ~1.3in
The new opening of the vents will be ~1.5in
Here is a very rough mockup. I took out the top three front fins on the right side vent and lowered the direction control thingy down one fin.
Old 11-29-2012, 02:59 PM   #34
V8sPFFF06sti
Member#: 236314
2013 Impreza
so your doing the magnets? and when you pull the ipad mini off thats where the head unit will be mounted, inset for the ipad to lay over top of it?
are you just going to bluetooth everything?
are you going to have way to charge the ipad whiles its in dash?
are you figuring a way out to still be able to use the steering wheel controls?
V8sPFFF06sti is offline   Reply With Quote
Old 11-29-2012, 04:37 PM   #35
V8sPFFF06sti
Member#: 236314
2013 Impreza
another question
have you heard of the ipad falling out if bump is hit hard enough?
I have ridiculously shift suspension and 35/R19 tires i feel pebbles lol
Old 11-29-2012, 07:39 PM   #36
Ish9
Member#: 210884
2008 Impreza STI
/\ Good questions. Does your Ipad have GPS capability? If not there is a product Dual Electronics makes that enables it. Also, have you thought about where your going to route you ipod cable?
Ish9 is offline   Reply With Quote
Old 11-29-2012, 08:48 PM   #37
naked_dave1
Member#: 301692
another question
Yep, going to try the magnet method. You got it exactly!
The iPad mini's audio will be connected via bluetooth rather than the lightning cord as some head units have issues with it. But, I'm most likely going to still have the lighting cable plugged it but wire it to the car so the iPad mini only receives power.
The steering wheel controls will remain via the Axxess ASWC module.
The iPad falling out is a concern I do have. I got the magnets in they are fairly strong. I also created a mock up with some thin card board to see how well the iPad held on. The magnets are only at the top, so I may create a small lip on the bottom so that part doesn't fall out.
Yes, I have the iPad mini with the data plan so it had GPS.
Old 11-29-2012, 10:00 PM   #38
V8sPFFF06sti
Member#: 236314
2013 Impreza
awesome cant wait to see it all put together.
Old 11-30-2012, 07:48 PM   #39
V8sPFFF06sti
Member#: 236314
2013 Impreza
i have researched the wifi only ipads using a mobile hotspot and driving around using the navigation app...
basic answer is it wont work that way.
ways it will work, if you have an cellular enabled ipad and pay for the data service like through verizon or att. That works perfect
or if you already have or buy a cellular enabled ipad WITHOUT the data service activated. Then have a mobile hotspot, then the navigation apps will work.
The wifi only ipads dont have the GPS chip/antenna in them.
you can get a external GPS modular, a wifi only ipad, and a mobile hotspot and that will work.
so after all the different scenarios and some math...
I'm gonna get an ipad mini.
so it would be more cost effective to purchase a new ipad mini with 4g service and add it to my current verizon plan.
but say you already have a ipad or ipad mini wifi only.. it prob be cheaper to buy the external GPS modular and get a mobile hotspot
the mobile hotspots are fairly cheap unit and 20 bucks a month add on to existing plan (verizon)
vs buying a 16 gig ipad mini 4G LTE is lots of monies, but its only 10 bucks a month to add to existing plan (verizon)
so xmas gift to my self = ipad mini
Old 11-30-2012, 08:29 PM   #40
garudatwo
Member#: 322385
2006 Civic LX
Stage a lot 140BHP
Reminder: the iPad mini uses the lightning adapter, and there's no guarantee that the GPS modules for the last gen connectors will even work.
garudatwo is offline   Reply With Quote
Old 12-05-2012, 03:42 PM   #41
cb41
Member#: 215053
2009 WRX
Spark Silver
Quick question (probably a retarded one, I am not an electronics guru)
So if I want to rig up something similar would I be able to just hook the iPad Mini to an AUX cable to my double din receiver and then plug the power cord from the iPad Mini to the USB of the receiver to charge it while it's in use?
I ask because whenever I plug my iPhone into my USB to listen to music it takes over the screen and says "Accessory Connected" so I am assuming if I plug an iPad into the USB it will do the same thing so it would be pointless in even having it. So I need to find a way to get around this so I can still use the iPad as the functioning screen (so I don't have to buy a new deck too). Any tips or advice?
Thanks, Chris
cb41 is offline   Reply With Quote
Old 12-05-2012, 06:45 PM   #42
Ish9
Member#: 210884
2008 Impreza STI
Thanks, Chris
Some head units have an "app mode" that allows you to have control of your device while it's connected to your radio.
Old 12-05-2012, 09:07 PM   #43
naked_dave1
Member#: 301692
Got all my supplies ready. Now, just need to find time to make it...
Having never worked with fiberglass or body filler I'm going to make a "test" tray to see how things go before I actually start the final build. I can also use that test to see how things are going to fit within the car, the radio bezel, and see where/how I need to mount the stereo.
Old 12-05-2012, 09:53 PM   #44
sgp250r
Member#: 256882
2005 WRX Sedan
Damn...looks like it! Post your test process with some pics....might be able to give a few pointers.
Old 12-05-2012, 10:50 PM   #45
949
Member#: 58906
im lost, but what is the fascination about the ipad mini/ ipad as a stereo? vs. a traditional dedicated head unit.
can someone fill me in.
949 is offline   Reply With Quote
Old 12-05-2012, 11:09 PM   #46
garudatwo
Member#: 322385
2006 Civic LX
Stage a lot 140BHP
Speed of the OS for one.
Old 12-05-2012, 11:22 PM   #47
naked_dave1
Member#: 301692
gunz4me had an explanation I agree with.
I wont be losing the "stereo" completely as it will be behind the iPad. The iPad will act like the user interface to the radio and how I control audio and navigation.
Why I like the iPad mini over a double din touch screen:
  • Better UI and screen, also larger screen
  • Maps will always be up to date and free (most cases will be free)
  • Navigation apps will be constantly updated and get better
  • Cost the same or less than a high quality double din touch screen
  • The iPad is removable so I can use it for multiple purposes as I can use it anywhere.
  • Have your music collection and internet radio (I know you could use your phone or other media player.)
  • And last, it's just plan cool. At least to me it is.
Old 12-06-2012, 01:00 AM   #48
tangodown2001
Member#: 339822
This is indeed a very cool idea but I dont understand why an Ipad requires an internet connection to use navigation. Is the GPS that week that it is not reliable without web assistance? My Toshiba Thrive links up and navigates just fine on the open road with no hotspot
As a side note, some DD headunit Navis are not so bad such as the Pioneer AVIC units, especially after a little assistance (AVIC 411), and some even include features not available on google maps such as 3d rendering of buildings and a useful POI display (with logos).
Good luck with your mod I hope all goes well!
tangodown2001 is offline   Reply With Quote
Old 12-06-2012, 01:29 AM   #49
949
Member#: 58906
but doesnt the physical ipad unit change in a couple of years time after its been release? i have seen those big ones installed in some wrx and sti's and now they are considered outdated. plus they are huge with lots of time and money in the bezel. new bezel and redo it with the ipad mini?
ok, you got my attention. im am interested in seeing this in action. what apps are available for use in the car?
Old 12-06-2012, 02:02 AM   #50
needforsleep3
Member#: 339825
Ipad Mini Size is suitable!!
needforsleep3 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 02:15 PM.
