Welcome to the North American Subaru Impreza Owners Club Saturday November 22, 2014
Old 10-30-2012, 10:59 AM   #1
pur
Member#: 335631
2011 WRX Premium
SWP Protuned/Turboback
Default slight whine when clutched is pushed all the way in
Hi all,
I have not had any time to research but this morning when my car was cold, i noticed with the clutch all the way in i have a slight whine. Perhaps just the last inch of travel. Once the engine is warm its gone.
What might this be? The car is a 2011 wrx. 12,000 miles, no damage.
pur is offline   Reply With Quote
Old 10-30-2012, 12:33 PM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Throwout bearing. Ask me how I know. Seems about the same milage mine started at as well.
drewvdw is online now   Reply With Quote
Old 10-30-2012, 12:49 PM   #3
tunertype
Member#: 335033
2009 wrx
Dark Gray Metallic
Yup sounds like throwout, but it isn't usually a problem to have alittle noise. very expensive fix laborwise. parts wise probably under $10? Usually a new clutch comes with one as a spare part.
tunertype is offline   Reply With Quote
Old 10-30-2012, 01:15 PM   #4
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
$40 for a new TOB or a clutch comes with one, at least my SPEC clutch did. The sound will get worse as the temp drops. You might be able to get SOA to repair it under warranty if you're willing to leave your car overnight.
Old 10-30-2012, 01:56 PM   #5
pur
Member#: 335631
2011 WRX Premium
Yeah I should also note that I just picked up the card about a month ago. So this will be my first winter with it. From what I read about it, it is not a big deal if you don't mind the noise?
Old 10-30-2012, 01:59 PM   #6
kabob.master
Member#: 258791
2011 wrx 5dr lmtd.
299awhp / 322tq @ 17.6psi
Mine did this as well. Over time the pedal became stiffer and made a squeak when depressing.
Took it to dealer, they said they can open up the tranny to take a look but if it's not covered under warranty then I have to pay for inspection (>$500).
It was covered under warranty & they replaced the whole clutch at ~35k.
kabob.master is offline   Reply With Quote
Old 10-30-2012, 02:06 PM   #7
pur
Member#: 335631
2011 WRX Premium
So I should have this looked at now or later? IMO the throwout should not be making noise quite this soon.
I can not say how the previous owner drove it, but from what the car looks like I doubt it was driven hard. I've pretty much been granny shifting it since its been raining for weeks here.
I am kind of thinking I will keep an eye on it. Today was pretty warm so I do not know why it would not make the noise a few days ago when it was below 40. If anything I could get it fixed if it gets worse or before warranty is up. Correct me if I am wrong?
Old 10-30-2012, 02:26 PM   #8
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
When my clutch was changed out, the guy that did it called me and made a point to tell me to stop riding my clutch. I never do and explained it to him. The clutch or TOB was most likely to blame for all the clutch wear. I don't know for sure, but if the dealership suspects you or the previous owner of riding the clutch, they may not cover it under warranty.
Old 11-01-2012, 04:16 PM   #9
Pacheco17
Member#: 336724
Slight whine is most likely a throw out bearing its supposed to be replaced every clutch job
Pacheco17 is offline   Reply With Quote
Old 11-01-2012, 09:23 PM   #10
RedRex2012
Member#: 322638
Thats weird cuz my car does that and i only have 8k on my car and never beat on it or ride the clutch ... My cars apparently is a POS .. Lol
RedRex2012 is offline   Reply With Quote
Old 11-01-2012, 11:58 PM   #11
gurusan
Member#: 258165
2006 WRX Wagon
I get a whine in cold temps when clutch is depressed around 90%....and when it's totally disengaged and in gear I get a very fast "chirp chirp chirp".
06 WRX
gurusan is offline   Reply With Quote
Old 11-19-2012, 09:41 PM   #12
Ghostwhite
Member#: 254958
Make sure the clutch fork spring is still there. I didn't install mine when I had the motor out for a rebuild and it whined like described until I put it back in.
Edit, my noise was with clutch released, your noise would be throw-out related.
Ghostwhite is offline   Reply With Quote
Old 11-20-2012, 12:41 AM   #13
eronenris
Member#: 262992
2009 WRX - Stage 2
mine does the same thing, going to take into dealership next month and see if they will warranty it, iv'e only got 39k miles.
eronenris is offline   Reply With Quote
Old 11-20-2012, 12:03 PM   #14
johnmkv
Member#: 300848
LR
Throwout for sure.
Drive the car if its only while cold and goes away after warm up youll be fine if it happens after operating temp are reached then go to the dealership
johnmkv is offline   Reply With Quote
