Old 11-18-2012, 10:52 PM   #1
Gev_ISMwrx
Member#: 338122
2012 Impreza WRX
Ice Silver Metallic
Default Exhaust leak? Hissing?
Hey guys I have a 2012 wrx, open source tuned on 91, with an cai and cattless 3" dp. Today as I was driving the car, I thought I heard a hissing noise coming from under the car, and now when I shut off the engine, the car makes a hissing noise it never made before. I was thinking it's an exhaust leak?.. I know it's not a boost leak or anything, but I wanna find out what it is so I can get it fixed asap. Any of you have this problem before?
Gev_ISMwrx is offline   Reply With Quote
Old 11-20-2012, 07:19 PM   #2
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Yes. Hissing from the midpipe to dp. Was a bad new gasket when i replaced it. I used a regular donut with a 3" two bolt graphite gasket around it to seal the extra bits from the 3 " to 2.5" connection. The 2 bolt fit perfectly around the donut gasket.
The gasket it came with was still leaking even torqued past max specs.
Retorque your midpipe and axelback connections and put the top of your hand all around the flanges to check for a slight feeling of escaping gasses thru the gasket. (Right after cold starting) dont burn yourself!
Scoobiesdoobies is offline   Reply With Quote
Old 11-22-2012, 12:55 PM   #3
Gev_ISMwrx
Member#: 338122
2012 Impreza WRX
Ice Silver Metallic
Yea it ended up being a bad gasket, I used the oem one. & I got the flange changed on the midpipe to flat, so there's absolutely no hissing or escaping gasses, runs like a champ now! Thank you!
Old 11-22-2012, 01:16 PM   #4
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
no problem mon
Old 11-22-2012, 01:28 PM   #5
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
If it comes back high temp silicone (orange) is your best friend, for a quick fix
~Evil
EvileyeZ88 is offline   Reply With Quote
