Old 09-23-2012, 01:38 PM   #1576
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i dont seee how its possible to have 20 psi while shifting
Bariga is offline   Reply With Quote
Old 09-23-2012, 01:52 PM   #1577
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You also have the activation delay you could set if you did see boost for a split second during a shift or if you wanted to use this with FFS.
kellygnsd is online now   Reply With Quote
Old 09-23-2012, 02:06 PM   #1578
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
yeah there is a start delay of 0.5 sec
Tested works good, had to redo map table like this 0 100 200 300 kpa
Blocked hood vent, 10 dollar mod!
some random shoots with good camera
Old 09-25-2012, 11:06 PM   #1579
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
Default Damn
What wheels are those? I would say works emotions at a glance. What is he offset/ size?
I pretty much want my car to look like yours but not as clean or as fast
BlackEyeII is offline   Reply With Quote
Old 09-25-2012, 11:14 PM   #1580
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I think those are bbs ch
Old 09-25-2012, 11:51 PM   #1581
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
bbs S204 18 / 8.5 56 offset i think
Old 09-27-2012, 12:01 AM   #1582
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Anton,
You're car is so ****ing clean and stealth. It is the **** in my book! Really what all Tarmac driven Subarus should be. So unsuspecting but relentless should some so called fast car pick on it! I'm bad but it is fun to embarrass other drivers some times. Idiots that pick on my XTI, usually regret it and I'm sure some cry
Do you really want to block off that hood scoop? That will create more drag and I think that hood scoop flow is not bad for the engine compartment even with a FMIC. Almost like a Venturi effect from the volume of both the front grill and the hood scoop. The constriction is the exit at the fire wall, the air speeds up and helps evacuate all of the air in the engine compartment.
Old 09-27-2012, 02:24 AM   #1583
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
thanks man, about the scoop i was reading that people saw improved intake temps with scoop being blocked off "some where on iwsti" i gotta find the link
Old 09-27-2012, 11:22 AM   #1584
Maxwell Power
Member#: 190729
Without a sealed tmic, the scoop adds drag. It also pressurizes the engine bay reducing cooling flow through the radiator. With a tmic, there is still a little drag, but the intercooler slows flow through the scoop minimizing the effect.
Multiple tests have been done over the years to prove this.
Maxwell Power is offline   Reply With Quote
Old 09-27-2012, 08:00 PM   #1585
thepigsti
Member#: 166215
I installed a hood vent from KSTech along with a custom plate a few years ago with the idea that it would help vent the positive under-hood pressure and increase airflow through the radiator/FMIC. Obviously doesn't look stock though so if that is important to you perhaps running an RS or painted carbon one would suit your needs, and might be marginally better than forcing air into the engine compartment with the scoop.
thepigsti is offline   Reply With Quote
Old 11-21-2012, 03:59 PM   #1586
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
so I got mine, I hope you ("got yourself a pump")
will plug it to stock fuel controller do a test, and then will hard wire it to 100% duty with fat wires and then do test again!
I think ill prove everyone that different wires wont do ****
new toy for quick logging
Old 11-21-2012, 04:15 PM   #1587
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
those pumps are awesome. I swapped an aeromotive 340 out for the Walbro 416 (or 460?) E85, my old fuel system was so taxed, the AFRs richened up 2 POINTS!
Z0rr0 is offline   Reply With Quote
Old 11-21-2012, 04:39 PM   #1588
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i have feeling that the WD300 and aeromotive 340 and new aem's pump is overclocked walbro 255
Old 11-21-2012, 04:43 PM   #1589
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Originally Posted by Bariga View Post
As i have 1 available table left thinking to use it for AFR limit under boost, does it make sense?
this table actually kicked in many times because i was leaning out at redline to 12 afr due to weak fuel pump This map is good safety!
Old 11-21-2012, 05:39 PM   #1590
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
A lot of people have already proven than there is a voltage drop through the controller, even under low amperage/load. Go throw a DMM on the pins at the top of the pump hanger. You'll save yourself time from trying to prove the world wrong
lancelucas is offline   Reply With Quote
Old 11-21-2012, 11:37 PM   #1591
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
installed the pump! Went smooth had to trim the plastic tip of the pump tiny bit and bend the bottom bracket! Soldered the wires and used 2 layers of shrink wrap.
Using stock FPC for now, and just tested it at idle sounds little quieter than DW300, and makes noise like old CRT monitor
Old 11-22-2012, 01:32 PM   #1592
reid-o
Member#: 103631
2004 STI
How is the direct port running?
Old 11-22-2012, 04:42 PM   #1593
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
so far no problems, just did some pulls and AFR seems to be stable at redline 11.2 with meth, but still injectors at 101% maybe raise fuel pressure? i'm at 70 psi peak
Old 11-22-2012, 05:14 PM   #1594
manitou
Member#: 193757
2006 XTI Limited
What injectors are you using? I know that ID's do not have good response to fuel pressure changes. I know this because I chose to run older disc style DW 1100's because they respond to fuel pressure changes. My 1100's will flow 1300cc's at 4 bar/ 60 psi which will give me the fuel requirements for 500WHP on E85. Along with a Walbro 400 E85 pump direct wired with 12 gauge wire.
Old 11-22-2012, 05:41 PM   #1595
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
ID1000's and ID2000's perform great all the way up to 100psi base pressure, WITH correct latency and flow data all the way up there. You are misinformed.
Old 11-22-2012, 05:45 PM   #1596
manitou
Member#: 193757
2006 XTI Limited
No, what I am saying is their flow does not change as much as other injectors at different fuel pressures. I know they flow well at all pressures. What I was saying is that you can get higher flows from higher pressure with some DW injectors.
Old 11-22-2012, 05:48 PM   #1597
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Incorrect. Bernoulli's principle. Read it learn it love it.
Bernoulli is the guy who discovered that for the flow of an incompressible fluid through an orifice to double, the pressure must quadruple. Put another way, the change in flow is proportional to the square root of the pressure ratio. I think it's safe to say that all of us who play with fuel injectors get this, and in fact a quick Google search will bring up numerous injector flow rate calculators that are based on this exact principle.
http://www.injectordynamics.com/size14.html
Basically, your 1100's -- assuming the 1100cc rating is accurate -- can only flow at a very theoretical max of 1283cc with the stated pressure increase. 3 bar to 4 bar is a 33.3% (1/3) increase in pressure, which means a 1/6th (16.6%) increase to flow rate, or 1100 * (1 + 1/6) = 1283.33. All injectors are subject to the same principles of fluid dynamics
Because I love math -- note that the ID1000 and ID2000 flow goes up by ~16.26% and ~15.73%, respectively, when pressure is increased from 3 bar to 4 bar. The theoretical increase should be 16.6%. Not a coincidence
Old 11-22-2012, 06:05 PM   #1598
reid-o
Member#: 103631
2004 STI
I'm sorry I didn't catch this earlier, but how are you verifying fuel pressure during the run again? Do you have a sensor or a gauge in cockpit? It seems easy to just wire in a relay from the battery tied to the meth pump. You just need to tee into that 8 gauge to the meth pump and splice the fuel pump wires temporarily.
If you use taps you can just remove it. If the duty cycle goes down then its likely not the pump.
Old 11-22-2012, 06:29 PM   #1599
manitou
Member#: 193757
2006 XTI Limited
I do stand corrected on Bernoulli's principle.. Thanks for the reminder!I do not refute this. I guess based on the manufacturer provided charts based on fuel pressure changes that the DW 1100's may be underrated as to their size. I will post up the pressure corrected chart from these injectors to compare. I'm just do not have that info at hand right now.
Old 11-22-2012, 07:30 PM   #1600
alcoolaid
Member#: 134949
'07 SWP STi
Still 101%? Damn. I'm in the 8x% range with a little more boost.
Is fuel pressure dropping up top?
I'm running 40-42 psi base with engine running.
Time for a Bosch 044?
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
