Old 11-22-2012, 07:43 PM   #1601
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i just hard wired the pump,
and will do test tomorrow! At idle the fuel pressure did went up a bit its about 43 psi now, used to be like 35
Old 11-22-2012, 07:54 PM   #1602
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
also with fuel pump control box installed in trunk my relay wont switch off because the voltage was slowly bleeding down. So i had to remove that 400 dollar part
Old 11-22-2012, 07:58 PM   #1603
Layvon
Member#: 195711
STi 04/05/06/07
Dual 044s and never worry again :-)
Layvon is online now   Reply With Quote
Old 11-22-2012, 11:04 PM   #1604
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I want to do everything I can to avoid putting in a surge tank until I make it a full blown track car.
Old 11-22-2012, 11:53 PM   #1605
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by manitou View Post
I do stand corrected on Bernoulli's principle.. Thanks for the reminder!I do not refute this. I guess based on the manufacturer provided charts based on fuel pressure changes that the DW 1100's may be underrated as to their size. I will post up the pressure corrected chart from these injectors to compare. I'm just do not have that info at hand right now.
Old 11-23-2012, 12:52 AM   #1606
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Based on your first image/report, your actual injectors DW's only show a ~12.04% increase (814 @ 3bar & 14v to 912 @ 4 bar & 14v) -- not spectacular. Their datasheet (the second image) shows an increase of 15.44% from 3.06 to 4.08 bar of pressure...which would make their flow/pressure relationship only marginally worse than ID
lancelucas is offline   Reply With Quote
Old 11-23-2012, 03:28 AM   #1607
Layvon
Member#: 195711
STi 04/05/06/07
Lance - that is what manutou was referring to. Him and I have talked about that on the phone before .
Bernoulies was good **** though!
Old 11-23-2012, 10:05 AM   #1608
CatfaceType-R
Member#: 81102
Why does a surge tank make it any less street'ish?
Old 11-23-2012, 11:21 AM   #1609
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I don't want to loose my trunk to a tank, a pump, and fuel lines just yet especially without a legit firewall.
Old 11-23-2012, 12:26 PM   #1610
CatfaceType-R
Member#: 81102
Just do it in the spare tire spot. Those tanks are awesome.
Old 11-23-2012, 01:13 PM   #1611
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
looks like i have to bump the fuel pressure a bit, close to 75 psi should bring the duty down a bit.
Right now with pump at 100% and stock fuel pressure i'm at 98 duty at 69 psi peak fuel pressure
I really like this idea
Mounts in place of charcoal canister but 1000 bucks for a ****ing peace of metal wttf...
Old 11-23-2012, 01:52 PM   #1612
kellygnsd
Member#: 32669
LINK G4 hybrid STi
You got a link?
Old 11-23-2012, 02:35 PM   #1613
CatfaceType-R
Member#: 81102
You got a link?
I'll look (hard to search for), I've seen a few people do that. A bad virus killed my pic collection.
Rough one, I've seen much better.
Old 11-23-2012, 03:00 PM   #1614
kellygnsd
Member#: 32669
LINK G4 hybrid STi
That's exactly what I'm trying to avoid. I still would like to put a set of golf clubs or a dead hooker in my trunk every once and a while.
Old 11-23-2012, 03:03 PM   #1615
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
My personal car. Spare tire well cover sits down flush over it. Radium surge tank with twin Aeromotive 340's, new -6 feed to the engine bay.
Old 11-23-2012, 03:05 PM   #1616
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
I wouldn't run a surge tank behind the rear strut towers in any kind of street car for safety reasons.
Md05STI is offline   Reply With Quote
Old 11-23-2012, 03:08 PM   #1617
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
If they punt my car hard enough to get to the surge tank, they've also hit the car hard enough to get to the actual fuel tank. Same mentality would say that I should have stopped driving the car as soon as I removed the green brackets.
For whatever reason, Subaru people make a big deal about surge tanks and fuel lines inside of the car. It's not like the fuel lines run the length of the car and right past your feet, straight from the factory...oh wait
Old 11-23-2012, 03:23 PM   #1618
CatfaceType-R
Member#: 81102
Cool
I want dis. ^^^
This is what I was speaking of, Kelly.
Carmi
Old 11-23-2012, 03:38 PM   #1619
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Have you ever seen a stock tank damaged in a wreck? I havent.
But if something happens where you back your car into a tree or something on a road late at night with no help, its your choice to have the surge tank in that location where it can be destroyed and start a fire. Its unsafe to have them in the trunk period on the street, but even more so that far back. Thats why i had mine mounted like this with a firewall, and it saw limited street time.
Old 11-23-2012, 03:38 PM   #1620
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
id like to see some one make this setup but to be mounted on top of the trunk where some people mount amps
Old 11-23-2012, 04:11 PM   #1621
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Isn't this to your liking then?: a surge tank and fuel pump (044) in one :
http://www.034motorsport.com/fuel-in...k-p-21527.html
Beetspeed is offline   Reply With Quote
Old 11-23-2012, 04:25 PM   #1622
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
And have you ever seen an in-car surge tank damaged to the point of causing a fire hazard in a wreck? I havent.
I respectfully disagree with your opinion and believe it no more dangerous than a stock vehicle. You likely have zero actual examples to back up your statements. I have a far greater fear of a fire originating from the engine bay than from anything behind the firewall.
Old 11-23-2012, 04:37 PM   #1623
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
I have seen the frame-rail puncture a gas tank, the lines right next to the driver broken in 2 by a side impact.... on stock oem auction cars
Its all the same **** IMO, you hit a stock car or modded one in the right place and your screwed. Honestlly this is the reason if you do any sort of modded fuel setup you SHOULD have a aluminum fire wall built, and wont be allowed to race at a track with a modded fuel setup anyway.
I can 100% agree with Lance though, I am more worried about a dumptube lighting something in front on fire.. lol.. kicked rod oil everywhere.. FIRE FIRE FIRE.. lol
Old 11-23-2012, 06:24 PM   #1624
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
I agree the engine bay is a way more likely to start a fire. I've experienced this with a dump tube burning through a power steering line.
I've also seen a friends car catch fire from a surge tank being mounted that far back in a wreck. I personally feel the further back the fuel goes the more dangerous it gets, it's much more likely to get hit back there then in the stock tank location.
Old 11-23-2012, 07:54 PM   #1625
manitou
Member#: 193757
2006 XTI Limited
You guys probably don't remember the Corvair....a guy named Ralph Nader had issues with rear mounted gas tanks
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
