#1601 |
Member#: 179846
NWIC
Vehicle:07 STi MPS Build EFR 7670 TS |
i just hard wired the pump,
and will do test tomorrow! At idle the fuel pressure did went up a bit its about 43 psi now, used to be like 35
#1602 |
Member#: 179846
NWIC
also with fuel pump control box installed in trunk my relay wont switch off because the voltage was slowly bleeding down. So i had to remove that 400 dollar part
#1603 |
Member#: 195711
MWSOC
Vehicle:STi 04/05/06/07 JBP / OBP for now |
Dual 044s and never worry again :-)
#1604 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
I want to do everything I can to avoid putting in a surge tank until I make it a full blown track car.
#1605 | |
Member#: 193757
MWSOC
Vehicle:2006 XTI Limited OBP, Junior tuned |
#1606 |
Member#: 124282
NWIC
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
Based on your first image/report, your actual injectors DW's only show a ~12.04% increase (814 @ 3bar & 14v to 912 @ 4 bar & 14v) -- not spectacular. Their datasheet (the second image) shows an increase of 15.44% from 3.06 to 4.08 bar of pressure...which would make their flow/pressure relationship only marginally worse than ID
#1607 |
Member#: 195711
MWSOC
Lance - that is what manutou was referring to. Him and I have talked about that on the phone before .
Bernoulies was good **** though! |
#1608 |
Member#: 81102
MWSOC
#1609 |
Member#: 32669
SCIC
#1610 |
Member#: 81102
MWSOC
Just do it in the spare tire spot.
Those tanks are awesome. |
#1611 |
Member#: 179846
NWIC
looks like i have to bump the fuel pressure a bit, close to 75 psi should bring the duty down a bit.
Right now with pump at 100% and stock fuel pressure i'm at 98 duty at 69 psi peak fuel pressure I really like this idea ![]() Mounts in place of charcoal canister but 1000 bucks for a ****ing peace of metal wttf... Last edited by Bariga; 11-23-2012 at 02:37 PM. |
#1612 |
Member#: 32669
SCIC
#1613 |
Member#: 81102
MWSOC
#1614 |
Member#: 32669
SCIC
That's exactly what I'm trying to avoid. I still would like to put a set of golf clubs or a dead hooker in my trunk every once and a while.
#1615 |
Member#: 124282
NWIC
My personal car. Spare tire well cover sits down flush over it. Radium surge tank with twin Aeromotive 340's, new -6 feed to the engine bay.
#1616 |
Member#: 76974
MAIC
Vehicle:2005 CGM STI 10.03 @ 135 |
I wouldn't run a surge tank behind the rear strut towers in any kind of street car for safety reasons.
#1617 | |
Member#: 124282
NWIC
For whatever reason, Subaru people make a big deal about surge tanks and fuel lines inside of the car. It's not like the fuel lines run the length of the car and right past your feet, straight from the factory...oh wait ![]() |
#1618 |
Member#: 81102
MWSOC
#1619 | |
Member#: 76974
MAIC
But if something happens where you back your car into a tree or something on a road late at night with no help, its your choice to have the surge tank in that location where it can be destroyed and start a fire. Its unsafe to have them in the trunk period on the street, but even more so that far back. Thats why i had mine mounted like this with a firewall, and it saw limited street time. ![]() |
#1620 |
Member#: 179846
NWIC
id like to see some one make this setup but to be mounted on top of the trunk where some people mount amps
#1621 |
Member#: 166264
Vehicle:1974 VW 2.2 BW8475 396 WHP @ 25psi |
Isn't this to your liking then?: a surge tank and fuel pump (044) in one
:http://www.034motorsport.com/fuel-in...k-p-21527.html |
#1622 | |
Member#: 124282
NWIC
I respectfully disagree with your opinion and believe it no more dangerous than a stock vehicle. You likely have zero actual examples to back up your statements. I have a far greater fear of a fire originating from the engine bay than from anything behind the firewall. |
#1623 |
Member#: 64908
Tri-State
Vehicle:10.8 XT+ Real stock turbo record holder 11.4 |
I have seen the frame-rail puncture a gas tank, the lines right next to the driver broken in 2 by a side impact.... on stock oem auction cars
Its all the same **** IMO, you hit a stock car or modded one in the right place and your screwed. Honestlly this is the reason if you do any sort of modded fuel setup you SHOULD have a aluminum fire wall built, and wont be allowed to race at a track with a modded fuel setup anyway. I can 100% agree with Lance though, I am more worried about a dumptube lighting something in front on fire.. lol.. kicked rod oil everywhere.. FIRE FIRE FIRE.. lol |
#1624 |
Member#: 76974
MAIC
I agree the engine bay is a way more likely to start a fire. I've experienced this with a dump tube burning through a power steering line.
I've also seen a friends car catch fire from a surge tank being mounted that far back in a wreck. I personally feel the further back the fuel goes the more dangerous it gets, it's much more likely to get hit back there then in the stock tank location. |
#1625 |
Member#: 193757
MWSOC
You guys probably don't remember the Corvair....a guy named Ralph Nader had issues with rear mounted gas tanks
![]() Last edited by manitou; 11-23-2012 at 08:03 PM. |
| Thread Tools | |
| Display Modes | |
| Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band | Maxwell Power | Proven Power Bragging | 563 | 05-16-2012 08:28 PM |
| Maxwell Power Services aka GetaDomTune | AwaySooner | Vendor Reviews | 7 | 03-11-2010 03:54 PM |
| +1 for Dom/Maxwell Power | Jeff54 | Vancouver Impreza Club Forum -- VIC | 22 | 09-02-2009 02:22 PM |
| My new Maxwell Power Services engine is almost in !!! | leonbmx | North West Impreza Club Forum -- NWIC | 13 | 03-23-2009 10:28 AM |
