Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 11-12-2012, 12:51 AM   #1
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Default Where is my oil going? Turbo seal or motor issue?
Hey all,
I spun a bearing on my RAW Street Series block. I recently put in a new Vigilant Motorsports Street block to replace it, along with a new timing belt, oil pump, water pump, etc. I had the car tuned about a month ago and it makes great power and pulls very hard. However I've noticed recently that when I start a WOT pull, quite a bit of smoke comes out of the exhaust. It's a bit hard to tell from my rear view mirror what color it is, but it appears to be a white / blueish color. After a 300 mile road trip this weekend, I burned almost 1 full quart of oil, according to my dipstick.
I followed the break-in procedure from my builder, but I did add some boost here and there because I wanted to ensure my rings were seated properly. To be clear, I don't think this is the problem at hand. I haven't done a compression test yet, but I think the motor is OK. I suspect however that the turbo might be on it's way out, since I've read smoke when starting a WOT pull can be turbo seals. To be clear, the car does *NOT* smoke during idle or cruise, at least from what I can see, only under hard boost / WOT. I'm running the stock VF-43 on my 2007 STI. It was replaced a few years ago when I cracked a stock block, so it has about 60-70k miles on it being run @ 21psi on my old tune. The car is my daily driver, but I autocross it heavily during the summer months, and I'm currently running Rotella 15W-40 oil.
I took the downpipe off last week but didn't find any noticeable wetness on hot side of the turbo. I took a few pics which can be found below. Sorry for the iPhone 4S focus/quality. (my point and shoot battery died) Does this hot side look out of the norm? There is it a tiny bit of side-to-side shaft play, but I have read this is normal. There is no "in and out" shaft play at all.
Any thoughts? I am actually hoping it's the turbo since I'd really like to keep this motor in the car.
Thanks,
Josh
PS: You can see some smoke during one of my dyno pulls in the video below. Notice how the smoke goes away after the car gets into boost / upper RPM.
Acejam2k is offline   Reply With Quote
Old 11-12-2012, 04:19 AM   #2
bako
Member#: 226211
2002 impreza WRX JDM
blue
subscribed.
I burn 1 quart per 600 mile. pcv is disabled, breathers are vented to atmosphere, no smoke at all, no weakness of engine, great compression, turbo hot side looks like this. and I ahve shaftplay, the impeller is almost touching housing. completely oil free coldside.
5000 miles after proper break in...
using Delvac 15w40.
bako is offline   Reply With Quote
Old 11-12-2012, 01:11 PM   #3
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Originally Posted by bako View Post
subscribed.
using Delvac 15w40.
What turbo are you running? Stock?
Old 11-12-2012, 02:37 PM   #4
bako
Member#: 226211
blue
yes, stock td04 with 70k miles. my car is 02 jdm
Old 11-12-2012, 04:13 PM   #5
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
That hot side looks coked. It should be rusty red to gray color.
fastblueufo is offline   Reply With Quote
Old 11-12-2012, 05:50 PM   #6
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Just tested my #4 cylinder for compression. It's making a healthy 140-145psi warm, which is pretty good.
Old 11-12-2012, 05:54 PM   #7
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
Are you running an AOS by chance?
findurpath is offline   Reply With Quote
Old 11-12-2012, 06:34 PM   #8
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
Do a leak down test by chance?
timeXlost is offline   Reply With Quote
Old 11-12-2012, 06:48 PM   #9
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Yes - Crawford V2 AOS.
Old 11-12-2012, 06:48 PM   #10
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
I don't have a leak down tester or compressor.
Old 11-12-2012, 07:20 PM   #11
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
I went out for a drive and had my friend follow me. The smoke was grey/black and very thick. I'm sure there was some blue in there, but it was a bit dark. I also read that oil can be white if there is a lot of it and its not combusted in the cylinder. (Ie: coming from turbo)
I think I'm going to order a new turbo before I pull mine, so I have a new one on hand in case I need it. I will have to check the dealers return policy.
Old 11-15-2012, 01:56 PM   #12
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
I put a new VF43 on last night. I primed it this morning and took it out for a drive. On the first pull there was a ton of smoke, but after that, pretty much none. My guess is that it was all residual and probably clogged/burned off from the cat in my downpipe.
Checking with my tuner now to see if it requires any changes. I'll keep an eye on the oil level as well.
Old 11-16-2012, 02:06 AM   #13
bako
Member#: 226211
blue
please, report back after 500 miles.
Old 11-16-2012, 08:41 AM   #14
biodude
Member#: 271720
I'm having similar issues, I've lost almost 2 1/2 qts in the past 3K miles
I get occasional heavy puffs of smoke on warm restarts, and I've recently noticed smoke on hard accel, similar to your dyno vid.
I'll be checking compression and stuff this weekend, I hope its my VF
anyway, in for updates.
biodude is offline   Reply With Quote
Old 11-16-2012, 09:45 AM   #15
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
That's excessive, who built the motor, more importantly who set the ring end gaps? What pistons/rings
How did you break the motor in?
Is your pcv system functioning properly? I.e. hoses routed correctly?
-Phil
Flat 4 Motorsport is online now   Reply With Quote
Old 11-16-2012, 09:59 AM   #16
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
After some more driving yesterday I noticed a tiny bit of smoke under WOT. I'm betting its just unburnt fuel, since I'm tuned rich to be safe. It's MUCH MUCH less smoke than before. It could be old oil burning off too, since I'm sure there is a quart or more of oil cake up inside my downpipe and exhaust. Hopefully my cat isn't clogged with it. (Car pulls fine)
Old 11-16-2012, 10:21 AM   #17
biodude
Member#: 271720
Phil
all was fine until the last 3k miles. (no noticeable oil loss or burning until the weather change)
the motor is a MPS built EJ22. Running V7 heads. For the break in I did this (quoted from a PM from Dom):
10-40 conventional oil with a break in additive. We use ZDDPlus. others are out there. Any V8 machine shop should have them.
change oil at 100miles and 700miles.
maintain 10-40 until you are ready for synthetic (around 4k miles)
during the break in: 7-10psi and 5k rpm for 700 miles.
my break in seemed to go well, I get about -20inHg warm at idle so I'm thinking the rings seated nicely.
PVC is in the stock 2.0 configuration, however, I don't not have the 2 extra ports on the V7 valve covers connected to anything (capped off) since the ej22 doesn't have the 2nd crank case port. Its been this way the whole time.
Besides checking compression, I plan to add a catch can or two and get those two other breathers tied in, if I've read right, they are more for pressure balance and to aid in oil drain back in the heads, but being blocked cant be helping. I'm also going to pull the top mount and see if its swimming.
Old 11-16-2012, 11:00 AM   #18
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Sounds like it was broken in properly, MPS builds quality motors, i would definitely start looking at the crankcase vent system.
Check the pcv itself, when was the last time it was replaced?
Old 11-16-2012, 11:02 AM   #19
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Not good at all. Do a compression/leak down test, have you smelled burning oil at all.
Old 11-16-2012, 11:09 AM   #20
biodude
Member#: 271720
yup, things do happen, but I don't think its a motor issue
its new with the build , which now has about 7500 miles on it.
thanks for your input, i do appreciate it.
Old 11-16-2012, 11:12 AM   #21
biodude
Member#: 271720
under normal conditions nope and with that amount lost, I would think I'd see a smokescreen. I just have the puff burned off on the warm restarts, or under heavy accel I've been able to see some.
either way, I'll be doing a comp and leak down test this weekend
Old 11-24-2012, 05:37 AM   #22
bako
Member#: 226211
blue
anu news herE?
Old 11-24-2012, 11:30 AM   #23
biodude
Member#: 271720
no updates from me other than the fact that I can do a pretty good spy hunter impersonation under hard acceleration in 1st or 2nd gear.
screeching, cel flashing, and a light smoke screen under boost
Old 11-24-2012, 11:38 AM   #24
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
uhh that's not good.
Old 11-24-2012, 12:01 PM   #25
scooBeeWRX
Member#: 316916
2007 WRX
Isn't a flashing CEL usually a clear indicator that there's something catastrophic about to happen
scooBeeWRX is offline   Reply With Quote
