Old 09-07-2011, 11:53 PM   #1
heathcote
Member#: 157875
Default Jdm Ej205
So i came accros a jdm ej205 to replace my broken engine in my 02 wrx and i am trying to find some info on the engine.
From the pics i was sent the engine looks the same as my stock engine and there is a barcode with ej205d and some other letters and numbers that are hard to make out.
Complete engine turbo intercooler ecu for $1250.
I was told the engine is from a 1999 and up exact year is unknown.
heathcote is offline   Reply With Quote
Old 09-08-2011, 01:40 AM   #2
rexblake
Member#: 178426
2010 S4
Gray
Check Wikipedia, they have a whole write up about the wrx and what model year has what engine.
Old 09-08-2011, 10:49 AM   #3
heathcote
Member#: 157875
I checked out wiki and it had some info. Jdm market had the ej205 in some wagons from 1999-2001 and then all wrx had the ej205 from 2001-current. What i cannot find is whether they all came with avcs.
Old 09-08-2011, 01:54 PM   #4
ogboot
Member#: 170906
psm
ej207 is your overseas 2L with AVCS if i'm not mistaken. Not an older subie engine guru so take it with a grain of salt. Might want to check when AVCS was first implemented, if it was post 2001 then there you go.
ogboot is offline   Reply With Quote
Old 09-08-2011, 03:36 PM   #5
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
the ej205d did not have avcs.
Mr.Chow is offline   Reply With Quote
Old 09-09-2011, 12:26 AM   #6
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
both of these posts above me are incorrect. the ej205 *DID* come with AVCS. and the ej207 was only the overseas *STi* engine. the jdm WRX used an ej205, but i don't know when AVCS started with those.
Old 09-12-2011, 01:41 PM   #7
heathcote
Member#: 157875
So no one knows if it will have avcs or not?
What will i have to consider when swapping this engine into my car? Will all the sensors from the jdm engine work with my usdm harness or will i have to change the harness?
What would be the best way to run the engine, use the jdm ecu or use the stock ecu and get it re tuned also i have a cobb accesport will i be able to use it with the jdm ecu?
Old 09-12-2011, 02:02 PM   #8
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
The first year JDM GD WRX did have AVCS, 9.1 CR, and a catless uppipe. Should be similar to a EJ207 swap. Direct bolt in with the AVCS wiring harness that IA Performance sells.
Ref.
http://www.rs25.com/forums/f128/6967...ml#post1222218
illmatic is offline   Reply With Quote
Old 11-24-2012, 08:35 PM   #9
BMWtech
Member#: 338561
2004 WRX
OK, back from the dead, I know...I have a popped motor in my 04 WRX (USDM EJ205), and after a lot of research on here an other forums, I have decided against hybrid build, and just want to get a stock motor back in it until I save up for a V8 EJ207. However, in lieu of getting a reman shortblock and putting on my heads, I found an EJ205D. To swap this into my 04 WRX, I would need:
1. my USDM wiring harness
2. the AVCS wiring harness adition
3. the JDM ecu...which is not included in the auction...
Any idea if this would work as I understand, or can you not swap the EJ205D into an 04 USDM WRX that easily?
BMWtech is offline   Reply With Quote
Old 12-01-2012, 07:56 PM   #10
vf22Bugeye11
Member#: 272096
2002 6Speed swap wrx
Function Warrior!!
Bump on this I have same ??
vf22Bugeye11 is offline   Reply With Quote
Old 12-12-2012, 04:53 PM   #11
BoostinSaurusREX
Member#: 340334
03 WRX Wagon
I am having the exact same issue haha, and started my thread here
http://forums.nasioc.com/forums/show...1#post38690657
So take a look and I'm sure more useful information will come our way in both threads
BoostinSaurusREX is offline   Reply With Quote
Old 12-13-2012, 06:30 AM   #12
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
jdm ej205 does come with avcs..how do I know I got back from
okinawa this past august. and when i was there I built or rebuilt 2 wrx and 2 sti
ej207 came in sti
ej205 came wrx
Part numbers for EJ257/ JDM EJ205/207 breather hoses? crazyhorse Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-07-2015 05:22 PM
Warehouse Clearance - JDM STI V7 EJ207, JDM STI V7 Hybrid, JDM EJ205 AVCS!! Gruppe-S Engine/Power/Exhaust 24 01-09-2007 10:07 PM
Any experience with the JDM EJ205??? skiblur Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 10-03-2005 09:00 AM
tips for USDM EJ205 to JDM EJ205 swap? Chuck H Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-16-2005 08:37 PM
Very little lag with 9:1 CR jdm EJ205 Suberman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 07-27-2005 08:51 AM
