#1 |
Member#: 123574
MWSOC
Vehicle:2005 2.6L 9:1 425WHP CGM STi |
I've had a small oil leak for about a month now, after putting 13K miles on this engine. I had investigated it earlier and determined it was almost certainly coming from behind the timing belt tensioner... Decided to fix it during the long weekend. After removing the tensioner, I was presented with what you see below.
Seems like it could be the access bolt, but I know of no way to pressurize the oil system and actually check it without starting the engine. So, should I pop this out, replace the seal, and hope my problem is solved, or could there be something else leaking in this area? Oil leak from the top of the water pump? Never heard of it. Something leaking oil further back or higher up? Anything else to check? ![]()
#2 |
Member#: 198281
MAIC
Vehicle:2005 WRX/STi WRB of course |
Not uncommon. I would find the torque spec and snug her down. Thew wrist pin access plugs on the front of our 05 were all loose and leaking at 50K miles :/
#3 |
Member#: 123574
MWSOC
Thanks, I will do that. I've got some new seals for them on hand just in case. Could there be anything else in this area that's leaking? It doesn't look like it but I'm not sure if there's something behind the bracket that the tensioner mounts to.
#4 |
Member#: 300551
SCIC
Vehicle:2002 DD wgn 6 spd 2.1 kel 272's meth 2.5xtr |
No nothing else, that looks like your leak.
#5 |
Member#: 123574
MWSOC
Found this in the FSM, posting it here for future reference in case someone is searching... Wrist pin access bolt torque spec is 51.4 ft-lb, and you are supposed to apply fujibond to it, and use the metal gasket/ring.
#6 |
Member#: 110994
MAIC
Vehicle:2004 WRX STi something good on the way |
Like killerB said, it is a pretty common issue, I see many cars that come into the shop with oil leaking from there, pull it off, fujibond it up and re-torque
#7 |
Member#: 123574
MWSOC
Well ****... I don't know how this could have been the source of my leak... The damn thing stripped when I tried to remove it. No idea how I'm going to get it out now.
#8 |
Member#: 123574
MWSOC
Maybe we were wrong... Can the case bolts leak oil? I noticed that the tensioner bracket gasket to the top right of the access bolt had started to fail, degrading because of oil. It was hanging down, the adhesive had failed. When I realized it was only 4 quick bolts to remove the tensioner bracket, I popped it off and found the back of it, above the failing gasket, coated with oil. Looked around and the only thing I found was the case bolt to the left. It was coated with oil and grime, and actually looked a bit loose. Checked it and... It was loose! I tightened it back to spec.
I pulled my old block out and checked this out. It doesn't really seem like oil should be getting into this case bolt hole. Should I be worried if it turns out this was the source of my leak? |
#9 |
Member#: 123574
MWSOC
I've got everything back together now, after tightening both the access bolt (after attempting to loosen it, just in case), and tightening the case bolt. So far no leak, but now my car is idling at ~17:1. Dammit! I've either got a leak somewhere, or the timing belt is off.
