Old 11-24-2012, 02:58 PM   #1
Jamaal
Member#: 135979
2006 STi
obp
Default Rcommend a micrometer
Had a machine shop mishap and now I've got to get new bearings. Going to check the clearances myself. Need to find a decent micrometer that won't cost me a kidney.
Thanks for any recommendations.
Jamaal is offline   Reply With Quote
Old 11-24-2012, 03:11 PM   #2
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
You will need a mic and a bore gauge.
For the mic you cannot go wrong with Sunnen or Mitutoyo. 2-3" for the main and rod bearing journals on the crank.
A Fowler 1.4-6" bore gauge was recommended to me but I have not compared it to others. Seems to work well for the money. You will need this to check the bearings once installed then subtract the size of the journals. Most folks calibrate the bore gauge using the mic since the calibration rings are $$$
aboothman is offline   Reply With Quote
Old 11-24-2012, 05:16 PM   #3
Jamaal
Member#: 135979
2006 STi
obp
Sounds good. Thanks Alot for the info.
Old 11-24-2012, 06:36 PM   #4
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
After the research Ive done they seem like decent affordable tools. On amazon that bore gauge is like 190 and a mitutoyo mics set 0-4 is 80ish
Old 11-24-2012, 09:02 PM   #5
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Mitutoyo mics can be had for 80-100$ EACH used. Dunno about 80$ for a set...
Old 11-24-2012, 10:52 PM   #6
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
best price i found was etooldirect.com
Im not affliated with the site, guy ships fast and his prices are cheapest I could find.
He has both fowler electronic bore gauge and micrometers
bswilmington is offline   Reply With Quote
Old 11-24-2012, 11:28 PM   #7
Paul
Member#: 56203
00 RSTI Coupe
Your are correct. I goofed they were fowler brand and a 100
Old 11-25-2012, 12:35 AM   #8
Jamaal
Member#: 135979
2006 STi
obp
Thanks Alot for the link to etooldirect. I found the set you guys were talking about.
Old 11-25-2012, 12:58 AM   #9
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
Thats who I got my bore gauge from, it should be to me by tues/wed. I found a 0-3" set of used mitutoyo digital mic's on ebay for 200 so now I just need a 3-4 for checking ptw clearance.
spackyscooby is offline   Reply With Quote
Old 11-25-2012, 10:40 AM   #10
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
This!!
I spend about 2-300 a piece on each digital mic I have from mitutoyo!! So much $$
Old 11-25-2012, 02:38 PM   #11
Paul
Member#: 56203
00 RSTI Coupe
is there anything wrong with fowler mics? Cause they cost a 1/3 less than mituyoyo
Old 11-25-2012, 03:08 PM   #12
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I wouldn't use anything other than fowler or mitutoyo. Those are the best really. At the least you should look for tools with accuracy of .0005
Old 11-25-2012, 03:15 PM   #13
bswilmington
Member#: 217563
I bought these year ago and this is cheapest I could find, there is code on main page that will give you pretty much free shipping (10.70 shipping -10 off code on main page = 0.70 to ship)
Fowler standard outside mic
http://www.etooldirect.com/Fowler-FO...&searchSize=12
electronic mic
Old 11-25-2012, 03:47 PM   #14
Paul
Member#: 56203
00 RSTI Coupe
electronic mic
Both of those were what I was planning to buy. Any issues?...would you recommend them?
Old 11-25-2012, 05:12 PM   #15
Subikid90
Member#: 239233
1998 LGT
I also own both of these had have had great results with them!
electronic mic
Subikid90 is offline   Reply With Quote
