Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 11-25-2012, 07:41 PM   #1
bluestone
Member#: 36583
2004 WRX sedan
Default 02-07 WRX heat shield with clearance for AEM UEGO sensor
Have a Cusco heat shield and ERZ downpipe with a bung just behind the bellmouth. I believe I can use the bung for the UEGO sensor, but doesn't look like there is enough clearance with the heat shield (about 1"). Is there another heat shield that would provide adequate clearance?
bluestone is offline   Reply With Quote
Old 11-25-2012, 08:31 PM   #2
jbulls93
Member#: 315840
2000 2.5rs
Could go with a turbo blanket instead. Mine has been very effective so far,and is very compact.
jbulls93 is online now   Reply With Quote
Old 11-25-2012, 08:38 PM   #3
SubieWolfSti
Member#: 331579
2006 Impreza WRX STi
Gray
You could use the SPT heat shield, im using a cobb down pipe with a O2 sensor for the AEM failsafe. I have the SPT heat shield along with the factory heat shield and a turbo blanket.
SubieWolfSti is offline   Reply With Quote
Old 11-25-2012, 08:54 PM   #4
bluestone
Member#: 36583
2004 WRX sedan
Oh yea, I am getting a turbo blanket so would like a shield that can fit the blanket underneath as well.
Cool I'll check out the SPT heat shield. Don't have the factory shield anymore but that's cool that you can keep that too.
Here it says 06-07 but I don't see any reason it can't fit 04:
http://www.rallysportdirect.com/Exhaust-Heat-Shield
How about the Cobb? It looks open at the rear also. The Grimmspeed looks like it has a sloped face that will probably get in the way like my Cusco.
Old 11-30-2012, 04:03 PM   #5
bluestone
Member#: 36583
2004 WRX sedan
Anybody know about the Cobb heat shield?
Old 11-30-2012, 04:14 PM   #6
cmiovino
Member#: 134005
2004 WRX Premium
Overkill?
And I'm sitting here trying to figure out if running just a blanket will overheat the turbo. There are a few posts about it ruining seals and bearings.
Old 11-30-2012, 04:51 PM   #7
ogboot
Member#: 170906
psm
Originally Posted by cmiovino View Post
Overkill?
NEVAAAARR!!!
Link to those posts? Is there any proof? It seems to be an urban legend, really. "I know this guy who knew this guy that's turbo melted down because of a blanket." Some of the gurus around here have firsthand knowledge of wrapped/blanketed turbos that have gone 100k with no failure.
Now, is the blanket a possible fire hazard? That's another story. I have a blanket but my TD04 is pretty tired (assuming 170k, i'm not the original owner). My seals aren't completely blown, but they "sweat" some oil so I'm holding onto the blanket for my turbo upgrade.
ogboot is offline   Reply With Quote
Old 12-01-2012, 01:13 PM   #8
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
I have the cobb and it works great, but I would have to see if it would fit or not. I mean its pretty open, but my O2 is welded 4 inches down on the DP.
BoboTheMonkey is offline   Reply With Quote
Old 12-01-2012, 06:37 PM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Modify it to fit..... It's only metal.
Old 12-01-2012, 09:38 PM   #10
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Err... wat?
Keeping the turbo cool is the job of the coolant that runs through the turbo.
The stock heatshield is pretty effective and fits tight to aftermarket turbos. I've run that with a blanket underneath it on an 18G for many miles.
You just need to trim away some of the bottom of it so it fits with an aftermarket downpipe. It's really better than most aftermarket heat shields, I don't get why people spend money on new ones when they don't have to.
