Old 11-24-2012, 07:09 PM   #1
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Default Does throttle tip in affect learning view? Dialling in Injectors?
Ok so I have FIC 1100cc injectors and a stock maf scale and stock maf housing. Now I'm trying to dial in my injectors via learning view (rough guessing). I was wondering if tip in affects column C? It's the only column that's lower from the rest or depending on my latency higher.
Original Latency for these injectors are 1.00 @ 14v (if I use this value column A rises to +14 easily)
1.10 Latency @ 14v
1.09 Latency @ 14v
So clearly if I lower the latency further the more fuel it will add to compensate in Column A but remove fuel in column C. How can I lower my column C value? I know my A/F is rich at slight throttle, my map calls for 14.7 and it goes to the 12's. That's why I ask if tip in affects learning view. I'm thinking yes but it would be nice to get some more info if possible.
OC_Nooby is online now   Reply With Quote
Old 11-25-2012, 09:07 PM   #2
OC_Nooby
Member#: 311781
2003 WRX w STI V8
I guess get it as close as I can then tune the rest with the MAF scale.
