Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 11-26-2012, 12:35 AM   #1
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Default The perfect set up
I am on my 6th motor, 5th turbo and 6th tune. So my question is who has the perfect set up (for you) and what make it so good?
Im running a 2.1 stroker, kelford 272's, modded stock injectors, fp 20g, tomei el header, tvg deletes, meth and a cbe. It pulls hard after 4k and I think i like it. I might even run this one for awhile.
Old 11-26-2012, 01:16 AM   #2
Rymaster
Member#: 296277
2002 Impreza WRX
jeez that's a lot of motors for one chassis to see.... I have yet to find the "perfect setup" =/
Rymaster is offline   Reply With Quote
Old 11-26-2012, 01:17 AM   #3
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
<-- The one that I'm not blowing up motors on.
bushflyr is offline   Reply With Quote
Old 11-26-2012, 04:28 PM   #4
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Yea that is alot but i'm looking for a combo that I really like.
Old 11-27-2012, 04:09 AM   #5
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Carbon Bronson
I'm very content with just a vf34 and support mods. It's plenty quick for me, really reliable, and a very usable power band for the street.
There's obviously much faster cars, but for a DD it's tough to beat. I get a little over 20mpg city, 26.5mpg on freeway, and can hold my own on the track. I've run the turbo setup on the car for 80k+ miles with no issues.
Sure more power would be fun, but the 6spd does a lot to cover up the lag. It's pretty easy to keep it in the meat of the torque curve. And honestly, triple digits come so quickly it's more than enough power to get in to trouble.
575rider is online now   Reply With Quote
Old 11-27-2012, 01:44 PM   #6
Stangy
Member#: 329676
1999 GC8 R-STI
This is the engine posted on the front page- white STI. Pretty much S$#% mky pants when i saw it!
Dream Mod List:
Engine:
JE 925SD Custom Forged Pistons 99.75mm
Maxwell Power Services Super H-Beam +2mm Long Rods
Factory STI 79mm Crankshaft
Dan Benson Racing Darton Sleeved Block
Engine Fully Blueprinted and Balanced
ACL Race Rod and Main Bearings
Kelford 276/272 AVCS Cams
5-Angle Intake Valve Job
3-Angle & Radiused Exhaust Valve Job
Ferrea +1mm SS Intake Valves
Ferrea +1mm Super Alloy Exhaust Valves
Supertech Dual Valve Springs
Supertech Titanium Retainers
ARP Custom Age 625+ Head Studs
ARP Case Bolts
STI 11mm Oil Pump
Gates Racing Timing Belt
Gates Racing Alternator/PS Belt
Mocal 19 Row Oil Cooler -10AN Fittings
Mocal Sandwich Adapter w/ Thermostat
Koyo R2704 53mm Racing Radiator
Custom Twin-Scroll Header and T4 Up-pipe
Custom 3.5" Catless Downpipe
Borgwarner S300sx 83-75 .91AR T4 TS Turbo
Dual Tial 38mm V-band Wastegates w/ external dump tubes
MAC 3-Port Boost Solenoid
AEM 3.5Bar MAP Sensor
Cobb MAP Adapter
Custom 4" Aluminum Intake
Boost Logic Turbo Blanket
JIC Titanium Exhaust
APS DR725 FMIC with Custom Pipes
Tial Q BOV
TGV Port and Delete
Ported Intake Manifold
Ported Throttle Body
Rotated Intake Manifold
A/C System Removed
Crawford Performance V2 Air/Oil Separator
GrimmSpeed 8mm Phenolic Spacers
Walbro 255LPH Fuel Pump Intank
Bosch 044 External Fuel Pump
Canton Racing 8 micron Fuel Filter
Custom Fuel Surge tank
Aeroquip -8AN Feed and -6AN Return Fuel Lines
Injector Dynamics 1000cc Fuel Injectors
Aeromotive Top Feed Fuel Rails
Aeromotive A1000-6 Fuel Pressure Regulator
Aquamist HFS-5 Meth Injection System 2x1.0mm nozzles
Spec C STI 12L Intercooler Spray Tank
Vi-Pec V88 Standalone ECU with Anti-Lag and Launch Control
Odyssey PC680 Battery
Stangy is offline   Reply With Quote
Old 11-27-2012, 08:01 PM   #7
johnfelstead
Member#: 856
2005 JDM STi
This works for me in my daily driver MY05 JDM STi.
johnfelstead is offline   Reply With Quote
Old 11-27-2012, 11:53 PM   #8
OK Houston
we have an Uncle
now THAT is a sweet dyno plot for a daily driver
Old 11-28-2012, 01:00 AM   #9
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
^^^thats pretty awsome!
Old 11-28-2012, 05:04 AM   #10
Tenament
Member#: 246813
'02 WRX
WRB ::
What's your build John? incredible powerband.
Tenament is offline   Reply With Quote
Old 11-28-2012, 08:30 AM   #11
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
http://forums.nasioc.com/forums/show...&postcount=817
Old 11-28-2012, 04:53 PM   #12
johnfelstead
Member#: 856
2005 JDM STi
It's a JDM STi built as a forged 2.1 with an Owen Developments Bolt on Twin Scroll Turbo, now running 2.0BAR peak, 1.7BAR at 7000rpm. It will pull over 2.2BAR, but 2.0BAR is a safe peak to use long term. Engine is mostly stock JDM, no mods to the heads or cams, stock exhaust headers. EcuTek 800cc injectors, Stock ECU using EcuTek MegaRom mapped by Bob Rawle. Still using the stock MAF in a large bore inlet with K&N filter. Still on a TMIC, made by Chevron Motorsport from F1 spec heat exchanger material.
Car is a full weight 1460Kg JDM STi, 4th gear acceleration shows
40 - 60mph = 1.7 seconds
50 - 70mph = 1.5 seconds
60 - 80mph = 1.6 seconds
70 - 90mph = 1.9 seconds
Old 11-30-2012, 12:30 AM   #13
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
800cc injectors at 100% duty makes less than 475chp using witchhunters calculator. So what am I missing?
Old 11-30-2012, 12:36 AM   #14
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
current setup on a 20% mix of methanol and the spool is identical, the current setup actually spools 100rpm faster on plain 99RON fuel.
Probably the good gas.
Old 11-30-2012, 12:45 AM   #15
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
^that must be it.
Old 11-30-2012, 08:13 PM   #16
johnfelstead
Member#: 856
2005 JDM STi
If you meant BHP, then the calculator is wrong.
I am using 84% injector duty when running 20% methanol mix at circa 490BHP, and you need 8% more fuel flow compared to the equivilent pump fuel only, when running with a 20% Methanol mix.
99RON fuel is the equivilent of the USA 95PON fuel, it's nothing special, normal everyday super unleaded pump fuel over here.
These are well tested injectors and have been used to produce 600BHP on normal pump fuel.
Old 12-01-2012, 09:45 PM   #17
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
I was hoping more people would like the combos and post up what they have and why they like it. It doesn't have to be the fastest or the most powerful. Just fun dd's.
Old 12-02-2012, 10:16 AM   #18
rexblake
Member#: 178426
2010 Audi S4
I've had multiple set ups on my 02 wrx. Tdo4 full bolt ons and E85, 16g full bolt ons E85, 68hta built motor full bolt ons E85, dom3 xtr built motor full bolt ons e85. All with brake upgrades, built tranny, coilovers, sway bars, etc.
My fave setup so far? Evo X stage 2. By far, hands down, the best set up I've ever had.
Old 12-02-2012, 10:40 AM   #19
johnfelstead
Member#: 856
2005 JDM STi
Well thats helpfull on a Subaru BBS LOL
Old 12-02-2012, 11:10 PM   #20
rexblake
Member#: 178426
2010 Audi S4
Lol he asked favorite setup! Never said it had to be a Subaru. Quite frankly, after all the cars I drive before I bout the X, I'll prolly never own another soobie. Unless the BRZ STI is just amazing, as in, significantly better than a boss mustang 302 or Porsche cayman. At least on par with those two and significantly cheaper.
Old 12-08-2012, 08:09 PM   #21
droned23
Member#: 330606
2003 wrx
The ESX 1000hp build:P
droned23 is offline   Reply With Quote
Old 12-11-2012, 12:30 AM   #22
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Not alot of ideas being posted?
Old 12-11-2012, 01:26 AM   #23
Andrew04WRX
Member#: 340271
Wow I only dream
Andrew04WRX is offline   Reply With Quote
Old 12-11-2012, 12:37 PM   #24
claythrow
Member#: 283663
2004 STI
Root Beer
You aren't married are you…
My dream setup is what I'll be running shortly
04 WRX
Strong 2.0 motor,
Tomei UEL
STi oil pan
3" DP
Totally Catless
STI exhaust
VF39
STI pink injectors
Just enough to have fun with. Ok, it's not my dream setup but it's what I got and it makes me happy.
claythrow is offline   Reply With Quote
Old 12-12-2012, 12:59 AM   #25
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
[quote=claythrow;38679466]You aren't married are you…
Yes I am married but I own a shop.
