Welcome to the North American Subaru Impreza Owners Club Sunday July 13, 2014
Go Back   NASIOC > NASIOC General > Warranty Issues & SOA Problems
Old 09-02-2012, 08:55 PM   #176
FFMirby
Member#: 196808
2014 STi limited
Just FYI if anyone is interested I called SOA complaining about my rear view mirror falling off twice already and the blinker issue twice already and having to replace my clutch after 10,000 miles cause the spring in the clutch disc broke. Told them I was disappointed couple days later they called back and asked what I wanted, told them to extend my warranty and they did without hesitating to their max coverage. Hopefully that helps some of you...
FFMirby is offline   Reply With Quote
Old 09-29-2012, 11:56 PM   #177
Yeeman19
Member#: 8
Chapter/Region: HIIC
Ice Silver Metallic
1) 2012 WRX
2) around 3200 miles
3) Right side
4) N/A
5) Fiddled with bulb and wiring today and blinker is back to normal
Yeeman19 is offline   Reply With Quote
Old 09-30-2012, 12:47 AM   #178
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
2011 STI Hatch
17,xxx miles
Right blinker
Did a quick google search and found multiple people say its the wires. Got under the car and removed the two front push clips for the fender liner to the bumper. Reached my hand up and the wires were wrapped up and being pulled. Fiddled with them and made sure they were away from anything to tangle them and made sure the bulb connector was in correctly.
500 miles and no more problems.
JSchell1309 is online now   Reply With Quote
Old 09-30-2012, 11:40 PM   #179
RM_2
Member#: 163058
2011 Impreza WRX
SWP Hatchback
6xxx miles and now after the first frost last week, BOTH my blinkers started up again.
My passenger side blinker was just fixed by dealership by replacing the headlight assembly but that clearly didn't do squat because that "fix" they made lasted a good...5 minutes. As soon as I merged onto the highway, there it was again.
I'm going to give the dealership one more go. Third time's the charm, right?
RM_2 is offline   Reply With Quote
Old 10-01-2012, 07:24 AM   #180
bottles
Member#: 311522
Icy Silver Metallic
12,XXX
Passenger Blinker
Its not only a problem in 08-11 years, but my 2012 WRX is experiencing the exact same thing. Its my passenger side blinker it only does it intermittent though.
bottles is online now   Reply With Quote
Old 10-01-2012, 05:53 PM   #181
cineris
Member#: 263329
2011 Impreza WRX
My 11 used to do it. I changed the bulb and all is well now.
cineris is offline   Reply With Quote
Old 10-02-2012, 12:04 PM   #182
crackerbarrellSTI
Member#: 333251
2005 STI
Purp
its because the new bulbs SOA uses are s**t
crackerbarrellSTI is offline   Reply With Quote
Old 10-02-2012, 03:00 PM   #183
Jive Turkey
Member#: 219492
no. its not.
i've had this happen to me atleast 6 times already. the first handful of times they replaced the bulbs. then i asked a few friends who are techs, and they told me the ONLY fix is toe replace the harness. also i know its not a bulb because it would sometimes work when i hit a big bump, and then stop when a bump was hit again, thus the bulb is CLEARLY still working fine its the connection thats messed up.
from factory they come twisted, angled and sometimes pulling on the bulb/headlight thus it causes a bad connection, bad ground, etc etc.
if you want to fix it yourself cut you wheel, unclip the fender liner and look at the harness, it will be at a weird angle. in one instance for me the passenger side was being crushed and pressed against something metal.
the problem is with position and sometimes quality of harness, not cheap bulbs. please dont spread wrongful information if you can't back it up.
Jive Turkey is offline   Reply With Quote
Old 10-19-2012, 11:28 AM   #184
Nawratil
Member#: 306659
2012 Impreza WRX
Obsidean Black Pearl
First at 3000 miles. Replace bulb
Second at 7500 miles. At my service right now, so we will see...
Nawratil is offline   Reply With Quote
Old 11-04-2012, 03:58 PM   #185
RM_2
Member#: 163058
2011 Impreza WRX
SWP Hatchback
Just did both of mine today. I made a guide for it as well for any of you with this issue. See guide posted HERE.
Old 11-10-2012, 01:01 AM   #186
mostlystock
Member#: 313069
1) 2012 WRX
2) 900
3) right turn signal
4) Additional Subaru dealer quotes
5) Resolved at Dealer ordered a whole new headlight assembly, replaced the wiring harness.
mostlystock is offline   Reply With Quote
Old 11-15-2012, 02:13 PM   #187
Kroller2012
Member#: 306284
2008 Impreza
Default Blinker
You need a new bulb for sure
Kroller2012 is offline   Reply With Quote
Old 11-26-2012, 01:30 PM   #188
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
Fooled with mine a few times and the problem would go away, then come back maybe a day later. Took out the battery and really moved the wires around so they would stay. Problem has been fixed for at least 6 months.
dcorn is offline   Reply With Quote
Old 01-22-2013, 01:03 PM   #189
Nawratil
Member#: 306659
2012 Impreza WRX
It's happend twice on each side for me now... Gettin old
Old 01-25-2013, 10:54 AM   #190
joostin04
Member#: 266226
2012 wrx sedan
dark gray metallic
2008 wrx ~48,500
first occurrence happened a year and a half ago. dealership fixes the issue free of charge, warns me that if it happens again they will need to replace the headlight assembly.
fast turn signal came up again a few days ago, dealership tells me they have to swap out the headlight assembly which costs $500+, not covered under extended warranty. contacted SoA, they're looking into it and will get back to me.
joostin04 is offline   Reply With Quote
Old 01-25-2013, 11:13 AM   #191
veener79
Member#: 204304
2008 WRX 4D Stage 2
Did you get in there and try to straiten out the wire so it is not pinched against the fender? That fixed it for me.
veener79 is offline   Reply With Quote
Old 01-25-2013, 11:37 AM   #192
joostin04
Member#: 266226
2012 wrx sedan
dark gray metallic
I haven't tried but the service guy says the fuse(?) is bad. I sure hope they're not outright lying...
SoA called back and said they'll go 50% on the bill. I didn't wanna sound like an ungrateful jerk so I thanked him, but I still feel the whole situation is messed up
Old 01-25-2013, 11:43 AM   #193
veener79
Member#: 204304
2008 WRX 4D Stage 2
Try playing with your wire first and see if it pinched against the fender. I was able to loosed the batter with out taking it out and reached in there and fixed it that way if yours is the drivers side.
Old 01-25-2013, 12:11 PM   #194
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
The headlamp assembly has all of the wiring, sockets, and bulbs in place before it is installed onto the vehicle.
The way the car is designed is that there is a metal bracket/support that the headlamp assembly effectively sits against when it is installed. The wire for the marker/signal socket is effectively pinched between this support and the headlamp assembly.
You would want to remove the nuts/bolts that hold the headlamp assembly to the vehicle so that you can move the socket/wire through/between the assembly and support so that the socket/wire can now go over/inside the support/vehicle and then back into the opening in the assembly.
This is the fix.
The same goes for the tail-lamps. The wiring is in place and is effectively pinched between the lamp and the vehicle.
This is the quick-and-easy way for the factory to assemble the lamps to the vehicle. Otherwise, the lamps would not have any wiring/sockets on them and would be installed 'naked'. Then when being installed to the vehicle, the assembly-person would then have to insert the correct socket/connector position from the car into the lamp. If this were the way it was done, then there would be no pinching of the wires, but it takes more time to do so.
Big-E is offline   Reply With Quote
Old 01-25-2013, 01:27 PM   #195
Knotsure
Member#: 41730
0910 Leggy3.0/Impr
BLU Leg/BLK Imp
They may not be covering it under your warranty extension because it doesn't cover 'lights'. But, the prob. Is actually the wiring which should be listed as covered. Maybe check the wording in your contract and fight it out with them a bit? At least for the other 50%?
Knotsure is online now   Reply With Quote
Old 02-13-2013, 03:53 PM   #196
BUANG
Member#: 285233
2011 impreza premium
spark silver metallic
Originally Posted by f1speeder View Post
1) Year and Model of your car
2) How many miles when it started
3) Left or right turn signal
5) Resolved at Dealer or fixed it yourself
My Car:
1) 2011 WRX
2) 1956 miles
3) Left
4) Apple Subaru said never heard of the problem
5) Dealer said it was a bulb/ Warranty repair (will see if it happens again)
ADDITIONAL THREADS ON THIS PROBLEM & FIXES:
patricksmith04 : http://forums.nasioc.com/forums/show...1+fast+blinker
genny_1 : http://forums.nasioc.com/forums/show...ht=turn+signal
Sideways : http://forums.nasioc.com/forums/show...rn+signal+fast
xabre1200 : http://forums.nasioc.com/forums/show...1+fast+blinker
Anxiouz : http://www.clubwrx.net/forums/genera...-signal-2.html
Tesh : http://forums.nasioc.com/forums/show...1+fast+blinker
2011 impreza 2.5i
38,900 miles
Right
I still have to report it to the dealer.
BUANG is offline   Reply With Quote
Old 06-05-2014, 10:55 AM   #197
Mayamar44
Member#: 366921
Smile Turn Signal Blinking Quickly
My friends, my 2012 WRX drivers side turn signal started blinking very quickly. Owners manual says it's a bulb. Took it to dealer, for another issue, it's the wiring harness NOT A BULB. Fixed for no dolla since under warranty. Please take them to the dealers if under warranty. I think this should be a recall.
Mayamar44 is offline   Reply With Quote
Old 06-06-2014, 09:38 PM   #198
Sti_chick
Member#: 392540
12 Impreza Sti
pearl white
2012 Sti
30,000 Miles
Passenger-Right
just Got The Car So Not Sure How Long It's Been Happening, But Mine Comes And Goes As Well, Guess I'll Have To Call Somewhere....
Sti_chick is offline   Reply With Quote
turn signal problem 08 wrx !kid Electrical & Lighting 21 01-17-2013 01:59 PM
FS : 08-11 STi LED Turn Signal Mirrors WRX Conversion bustedstuff210 Exterior/Styling 9 02-21-2012 12:24 AM
2001 Outback Fast Driver's Side Turn Signal steelheadbum Newbies & FAQs 1 11-03-2010 05:22 AM
Fast Turn Signal Handsdown Electrical & Lighting 15 12-03-2008 11:03 AM
Help: Right turn signal flashing twice as fast... Silver04DE Electrical & Lighting 10 09-09-2004 09:06 AM
