Old 11-02-2012, 02:44 PM   #26
cmiovino
Member#: 134005
2004 WRX Premium
Originally Posted by Pandasaurus_rex View Post
I have a simple "cheat" to fix this problem. Get a tactrix cable, download romraider, turn off the code.
Another simple cheat: Fill up car, turn off code, keep car filled up above 3/4 tank on the highway. Code will never come on, trust me. It won't run the 'test' for it.
You can drive city all day long down to E.
Old 11-02-2012, 03:19 PM   #27
MIKE DD
Member#: 106818
2003 Truck
Only problem with that is, if you turn off the code and it's actually something else, you'll never know.
MIKE DD is offline   Reply With Quote
Old 11-09-2012, 01:49 PM   #28
goeast542baker
Member#: 264644
I've had this code pop up now and again. I looked at the filler hose, looks brand new, replaced the gas cap still nothing. Through searching this and other Subaru forums I just found out about the blue T fitting. I called my local stealership and its a $35-37 part. Gonna try that this weekend.
goeast542baker is offline   Reply With Quote
Old 11-10-2012, 08:26 AM   #29
goeast542baker
Member#: 264644
The blue T fitting is Subaru part number 42084FE010. Hope that helps someone
Old 11-11-2012, 10:39 AM   #30
subynube
Member#: 63442
Ok thanks for the reply folks!
Update: Had a new program downloaded to the ECU and the code came back. I have brought it back to the dealership again, and they fixed a wire leading to the vent valve near the canister. Not sure if they replaced the harness, or just fixed a wire. They say the wire was broken causing the valve to stay open. I will drive the car today on the highway to see if it will come back.
The good news, is that the dealership has not asked me to pay a single penny after they replaced the fuel filler neck. They have spent hours on my car trying to diagnose it, and have not had me pay additional. I'll update once I drive it on the highway today. I guess this is the one case the dealership has stood behind their work!
subynube is offline   Reply With Quote
Old 11-26-2012, 01:42 PM   #31
pimpsterrr
Member#: 230100
haha had my check engine light some on the other day went to autozone to pull the code bought a new gas cap nothing.......found this thread and after reading looked around and the blue T-fitting is broken after recently installing turbo inlet and intercooler hoses and ancillary hose kit hahah i can see the little hose portion that broke off just hanging down in there! so i called subaru for the part cause i couldn't find it any wehre esle and mand that little tiny part is $36! any wehre else you can get the T fitting from for less $? they should have it in by friday so i can finally be done with this damn code i hate seeing the check engine light on!
pimpsterrr is offline   Reply With Quote
Old 01-23-2014, 08:22 AM   #32
twinturbomeow
Member#: 315546
03 wrx
Originally Posted by CrashTestRacer View Post
Sorry to bump such an old post. But I have a check engine code for evap small fuel leak. I looked around, and I also found that I have this same exact hose damaged the same exact way. For the life of me, I COULD NOT find where this hose connects to, I looked all over with no luck. Does the inlet pipe need to removed ? My car has a heavy smell of fuel everywhere I go because of this damaged part, can anyone please help me ?
twinturbomeow is offline   Reply With Quote
Old 01-29-2014, 10:48 PM   #33
thatsilver2.5rs
Member#: 142268
2015 GTI pp
bye WRX & 2.5rs ;(
Ugh. I'm about to start diagnosing this on my car. Replaced the PS pump, it came on. Thinking I touched one of the brittle lines behind it or a brittle connector is loose.
Any easier way to get to those hoses without removing the PS pump? Maybe an intake hose?
thatsilver2.5rs is offline   Reply With Quote
