Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 11-25-2012, 07:15 PM   #1
RancerEvorution
Member#: 235190
2011 STi
Default Stage 2 STi 93oct MPH record?
Over the summer I ran a best of [email protected]
http://forums.nasioc.com/forums/show....php?t=2398063
I figured I could go a little faster once it got colder out so I gave it another go today at Evo vs STi day at raceway park. it was 40 degrees and the car felt real strong. Traction turned out to be an issue but I did manage to net a pretty impressive trap speed.
[email protected]
Im pretty sure this is the highest trap speed for a stage 2 93oct STi. If I didn't spin through 1st an 2nd, the car could have gone into the 11's on 93 pump! Let me know what you guys think!
RancerEvorution is offline   Reply With Quote
Old 11-26-2012, 12:00 PM   #2
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
The highest trap on 93 I've seen prior to this was 112.1. Almost 115 is crazy for 93.
FCmaniac is offline   Reply With Quote
Old 11-26-2012, 12:27 PM   #3
mtarr07
Member#: 246990
2010 Wrx
http://forums.nasioc.com/forums/show...hlight=4warned
This is the guy that trapped 112 mph. In the bottom link however, he added some things and got retuned on 93 as well as e85. It doesn't seem like he's been to the track since, but I'd imagine he'd be around your trap, if not a little higher if he had the same conditions as you (On 93 that is. Obviously on e85 he'll be even faster).
mtarr07 is offline   Reply With Quote
Old 11-26-2012, 12:34 PM   #4
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Gold chains & meatballs
I did 111+ mph back in 2006 with only 19.5psi on 93.
Evil STI is offline   Reply With Quote
Old 11-26-2012, 01:26 PM   #5
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
Damn, thats a fast stock turbo. Any changes to your setup from the last time? Picking up 4mph is pretty substantial.
wrxtremeWGN is online now   Reply With Quote
Old 11-26-2012, 01:49 PM   #6
4Warned
Member#: 66092
2011 STi sedan
COBB 20g [email protected]
NICE mph looks like I have a contender here
Should be fun in the spring.....
What was you race weight?
4Warned is offline   Reply With Quote
Old 11-26-2012, 02:06 PM   #7
RancerEvorution
Member#: 235190
2011 STi
I got the car weighed in once when I got a corner balance and the full weight was 3300lbs. Im coming for your record 4Warned With these traps this car will go 11.80-11.90 if I can find some traction!
Relevant Mods are:
335whp and 420wtq on TheShopCT's dyno
Cobb Access Port (STiMikey Pro Tune)
Invidia Q300 Cat Back Exhaust
Invidia Downpipe Divorced Wastegate
IAG Performance External 44mm V-Band Wastegate Uppipe Kit
GTSpec GEN II equal length headers
Tial MV-R Wastegate 44mm
KStech 73mm Cold Air Intake
Cobb BOV
Perrin FMIC w. custom IC piping
Hallman PRO Boost Controller Kit
Walboro 255 fuel pump
NGK Iridium "1-Step Colder" Spark Plugs
Old 11-26-2012, 02:07 PM   #8
FCmaniac
Member#: 142029
2013 Forester
OP, did you log your IDC's during those runs? Still have stock injectors? I wonder what they were. I put down 314/360 on TheShopCT's dyno and I'm maxing mine in 40 degree weather.
Old 11-26-2012, 02:26 PM   #9
RancerEvorution
Member#: 235190
2011 STi
my IDC is at 99% via cobb ap. they are maxed out
Old 11-26-2012, 02:43 PM   #10
everdying55
Member#: 112651
2011 Corn Fed WRX
DGM Hatch
"Stage 2" is a bit of an understatement. lol
everdying55 is offline   Reply With Quote
Old 11-26-2012, 03:15 PM   #11
ArkansasDave
Member#: 234363
2015 Katie Em 250 XC
Dirty bike
I always thought stage 2 was just a tbe and a tune. Not every Bolt on besides a turbo and injectors. Still congrats in the great trap speeds and times.
ArkansasDave is online now   Reply With Quote
Old 11-26-2012, 03:24 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
pretty much all stage2 07+ STI run 90-100% IDC, variations are mostly due to the WOT AFR
04-06 STi's are 100-110% since they have smaller injectors.
Old 11-26-2012, 03:29 PM   #13
mtarr07
Member#: 246990
2010 Wrx
This is where it is debateable. I usually go by:
Stage One is tune ONLY.
Stage Two is anything short of a turbo swap.
Stage Three is turbo swap.
Old 11-26-2012, 03:31 PM   #14
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Good **** dude, that is some serious MPH on 93.
Aside from Mikey when I tuned his old 07, I don't remember anyone trapping that high on straight 93. 112-113 is a "fast 93/vf car" your almost at 115!
Pretty close to my best on 93/vf(XTi) but I had a built motor at the time.
Congrats!
Old 11-26-2012, 03:49 PM   #15
ArkansasDave
Member#: 234363
Dirty bike
So if the op went to e85 then he is still stage 2 just on e85? Same with adding meth? Or race gas. I guess that's fair just always thought stg 2 wasn't everything short of turbo.
Sorry for the thread jack. OP hope you find that traction you're looking for and get down into the 11's.
Old 11-26-2012, 03:52 PM   #16
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Good work.
wrxsubiemod is offline   Reply With Quote
Old 11-26-2012, 04:24 PM   #17
4Warned
Member#: 66092
2011 STi sedan
Relevant Mods are:
Cobb BOV
Awesome man! I too hope to hit that 11.8 mark in the spring.
Our mod lists, weight, and power levels are very comparable. Should be good for some friendly track rivalry
I would be very careful at those power levels on stock injectors....
Old 11-26-2012, 04:39 PM   #18
RancerEvorution
Member#: 235190
2011 STi
Injectors and a clutch is next on the list. What injectors are you running?
I plan on going back out before the season is over, I have a plan to get the traction that I need
Nothing better then some good old competition at the strip!
Old 11-26-2012, 04:50 PM   #19
4Warned
Member#: 66092
2011 STi sedan
Heck yes!
Injector Dynamics 1000 injectors & DW65C drop in pump (highly recommended)
I run a South Bend Stage 2 "endurance" clutch at the moment but it will be swapped for a stage 3 over the winter as it won't hold the new torque numbers I am making now
I am also in the market for a set of hoosiers
Old 11-26-2012, 04:58 PM   #20
RancerEvorution
Member#: 235190
2011 STi
Im running a walbro 255 for fuel pump. Oh boy this is exciting.
Hoosiers will deffinatley give you the traction you need to go 11's on 93. Best of luck to you 4Warned. You're track times were motivation at the strip my man. We will see what our cars ultimate potential is soon enough!
Old 11-26-2012, 06:32 PM   #21
4Warned
Member#: 66092
2011 STi sedan
Best of luck to you as well sir!
Old 11-26-2012, 08:46 PM   #22
Phatron
Member#: 36033
CEO PhatBottiTuning
i believe the stages actually started with Vishnu way back in the day...
some companies use it to sell packages....so "stages" from different companies dont always include the same mods. sometimes a "stage 4" was a stock turbo with headers and fmic....sometimes once you're past staged2 that means an upgraded turbo.
when not referencing a specific companies packages, stage2 basically covers any setup/octane utilizing a stock turbo.
Old 11-26-2012, 09:13 PM   #23
Badler
Member#: 133597
Which is kinda funny because there is a stock turbo record too. Are forged pistons still stage 2? Stages were/are just marketing.
Badler is online now   Reply With Quote
Old 11-26-2012, 09:24 PM   #24
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
IMO
st1 is intake/tbe/tune
stg2 fmic/tmic/injectors/pistons /// basically anything with a VF
stg3 stock location upgrade
stg4 30-42r rotated cars
stg5 broken
Old 11-26-2012, 09:59 PM   #25
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
Originally Posted by Junior2JZ View Post
stg5 broken
