Old 04-07-2012, 11:32 PM   #1
P_tothe_G
Member#: 311516
2011 wrx hatch
wr blue
Default custom center console dual pod 2011 wrx
Couldn't find anything on the market that fit here. I hate the look of a-pillar mounts, and not a huge fan of the main bezel mount (SMY?). so I made one. Quick details, 16ga #304 s/s (brackets too), with tumbled finish (could paint them, but the tumbled finish works pretty good). Only works with the 52mm size. Pictures should explain.
Heres the hole
card stock
Cut to fit, adjust with good ol duct tape
Scanned my template and CAD'ed it out
Cut it out with waterjet
quick test fit
Back of gauges showing brackets
Close up view of side bracket, will add holes for screw mounts if I make any more, currently attached brackets to console with 3M double sided foam tape that came with the prosport gauges
ran wires through hole in top right of cubby hole (was patient, used a piece of TiG filler rod to help snake through, but taking console out may be easier
installed and running (pic with out flash)
P_tothe_G is offline   Reply With Quote
Old 04-07-2012, 11:35 PM   #2
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
looks good, any plan to put a finish on the panel itself?
looks like you even retain a small cubby for junk to collect in.
aerosaaber is online now   Reply With Quote
Old 04-07-2012, 11:40 PM   #3
P_tothe_G
Member#: 311516
2011 wrx hatch
wr blue
I was thinking about painting it before I put it in, but it comes real close to matching the other silver colored stuff (pics don't show so well). Best match I think to the factory colored accents, I would have to make face from aluminum, sand blast the face and then have it clear anodized. But the tumbled finish is perfect to paint.
there is just enough room in front of the gauges to put a pair moderately large sunglasses...or enough room for junk to collect in
Old 04-08-2012, 12:02 AM   #4
1 sicK gtR33
Member#: 178814
any plans to start selling them?
1 sicK gtR33 is offline   Reply With Quote
Old 04-08-2012, 12:13 AM   #5
Serkan
Member#: 180514
2004 Sti
The work is top notch but location for the boost and oil pressure is no good.
It requires you to completely take your eyes off the road.
Serkan is online now   Reply With Quote
Old 04-08-2012, 12:14 AM   #6
P_tothe_G
Member#: 311516
2011 wrx hatch
wr blue
I totally would make a bunch. But i would need at least 15-20 people to get in on it. that way I can run it through my shop without getting in trouble (and if I do 15-20 of em, the price can stay low). I already have a few minor changes I'd like to make too.
....who's interested?
Old 04-08-2012, 12:18 AM   #7
P_tothe_G
Member#: 311516
2011 wrx hatch
wr blue
It requires you to completely take your eyes of the road.
looking at any gauge takes your eyes off the road. Using peak/recall gauges with warnings allows you not to look at them all the time. If your ride is running right, you don't really need to look all the time. Just mostly used for diagnostic in my opinion.
Old 04-08-2012, 12:19 AM   #8
P_tothe_G
Member#: 311516
2011 wrx hatch
wr blue
And thanks for the one up on the quality
Old 04-08-2012, 12:34 AM   #9
Serkan
Member#: 180514
2004 Sti
I know a lot of people check their gauges time to time especially if they are stock.
I think it is a great place for water temp, oil temp, even oil pressure but not for boost.
With a gauge that is located on dash you still have the road in your sight but with this setup your eyes will be completely of the road.
It's just my opinion. Your setup looks great.
Old 04-10-2012, 06:47 PM   #10
1 sicK gtR33
Member#: 178814
iam down..lmk when 14 more people are..lol
Old 04-10-2012, 07:27 PM   #11
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I was thinking you would stop at the cardboard step! Hahah.
I need to think of another gauge to buy and then I would really want this. Badly. It would be very quick easy to Plasti Dip it, and I think it would look quite good.
Old 11-20-2012, 09:36 PM   #12
Ajd123
Member#: 326915
I know this is an older thread but congratulations man, looks great. I was thinking of utalizing that spot my self with two gauges. Hopefully you can still make them, I'm interested
Ajd123 is offline   Reply With Quote
Old 11-20-2012, 09:38 PM   #13
Ajd123
Member#: 326915
You should somehow angle the gauge direction towards the driver and up, like the ATI clock pod does
Old 11-20-2012, 09:40 PM   #14
tuzzio
Member#: 292532
05 STI
I'd really enjoy a single for a AFR gauge for my 05 sti.
tuzzio is offline   Reply With Quote
Old 11-20-2012, 09:41 PM   #15
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Looks pretty damn good. Any chance you could email me the CAD files for the face and brackets? I have a laser at work and wouldn't mind trying this out. Let me know.
Hmm.. looks like he hasn't been on in over 2 months. When I go stage 2 and pick up an AFR Gauge I will probably make a template for a single pod down there and try it out myself on our laser and press brake.
Old 11-25-2012, 01:02 PM   #16
Bajamedic
Member#: 233360
2003 Baja
Obsedian perl/grey
hey does anyone know where he tapped in to get the boost and oil pressure readings? im curious about that!!!!
Bajamedic is offline   Reply With Quote
Old 11-26-2012, 02:05 AM   #17
Jive Turkey
Member#: 219492
you dont tap for those, the gauges come with senders taht you mount in the appropriate positions. usually boost you t-off from the recirce valve. and oil usually goes on the oil filter/in hte block depending if its temp or pressure.
Jive Turkey is offline   Reply With Quote
Old 11-26-2012, 09:30 AM   #18
WRX2012
Member#: 329725
I would get in on this
WRX2012 is offline   Reply With Quote
Old 11-26-2012, 09:43 AM   #19
tuzzio
Member#: 292532
05 STI
I'm sure you're not down for it, but it'd be in for one for a single gauge that leaves my cigarette lighter for my 05 STI
Old 11-26-2012, 09:44 AM   #20
dhahn1012
Member#: 255578
2005 outback xt
white
Awesome work
dhahn1012 is offline   Reply With Quote
Old 11-26-2012, 08:27 PM   #21
P_tothe_G
Member#: 311516
2011 wrx hatch
wr blue
Thanks guys. Looking to set up vendor account because apparently that is what the Nasioc government demands. Message me if interested.
Thanks.
Old 11-26-2012, 09:41 PM   #22
JSchell1309
Member#: 321321
Tuxedo Black
Thanks.
Well if you are setting up a vendor account I doubt you will send me your CAD files .
When I have the need for the 3rd gauge I'll know where to look. Best of luck with this, looks great.
Old 11-26-2012, 10:38 PM   #23
P_tothe_G
Member#: 311516
2011 wrx hatch
wr blue
Can't give away the keys to the car man! It's bad enough that i've illustrated step by step how to make!
FS: 98-01 Center Console Gauge pod Splinter 1993 - 2001 Impreza Specific Parts 0 08-05-2009 12:10 AM
F.S.--- HEATED LEATHER INTERIOR W/doorcards----ALSO CUSTOM Center console hock3yplay3r20 Interior/Dressup/Audio & Security 16 12-04-2008 12:12 PM
WTShare: OEM GC center console gauge pod RE3Rotor VIC Private Classifieds 2 04-02-2008 01:00 AM
CA: center console gauge pod runwrxrun Private 'For Sale' Classifieds 4 12-01-2005 08:15 PM
FS: Autometer center console gauge pod! subynube Private 'For Sale' Classifieds 4 11-06-2004 05:19 PM
