Old 11-23-2012, 04:55 AM   #1
JMW803
Member#: 272407
2007 Impreza sti
Pearl White
Default ID2000 injector fitment question?
Hi, I am currently building my engine for my 07 sti, and I went to install the injectors and the fuel rails and I noticed that the injectors don't sit down as far as the stock ones did because of the connector on the injector hitting the tvg. Is the injector supposed to sit like that, or is the connector supposed to be suspended in between the tvg and the fuel rail like the stock ones? Because the injector doesn't seem to sit flat in the hole and it seems crooked a slight bit so I'm just wondering if anyone has dealt with ID injectors before. Thanks
JMW803 is offline   Reply With Quote
Old 11-23-2012, 08:16 AM   #2
berdugo
Member#: 163108
07 EuroDM STi 2.5L
I had a slight problem with my ID2000, it didn't sit well with the tgv and my aeromotive fuel rail. I needed to add some spacer to the aeromotive to make it fit nicely.
berdugo is offline   Reply With Quote
Old 11-23-2012, 02:11 PM   #3
JMW803
Member#: 272407
2007 Impreza sti
Pearl White
Where can I find those spacers?
Old 11-23-2012, 07:06 PM   #4
berdugo
Member#: 163108
07 EuroDM STi 2.5L
It's a custom made spacers, the machinist compared the lenght of my old DW injector and made spacers using the lenght difference.
Without the spacers the ID fits but not securely. It was moving up and down during dyno session until the upper o-ring got teared leaking fuel. Good thing my engine didn't blow up nor catched fire on the dyno then spacers were made. With the spacers, there is absolutely no vertical movement of the spacers.
Old 11-27-2012, 04:12 AM   #5
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
It's a secret LOL
spoolinsti05 is offline   Reply With Quote
Old 11-27-2012, 09:32 AM   #6
Ballistic1350
Member#: 156877
04 sti
Is this a common issue? I'm waiting on my topfeed tgvs to come in and would love to know if I'm going to have a problem as well
Ballistic1350 is offline   Reply With Quote
Old 11-27-2012, 12:49 PM   #7
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
To date it seem's. But I'm sure they are working on new top hat adapter's. And with any luck some kinda extended lower cushions.
This is how I have mine setup. Wrx lower cushions and wrx lower cushions up top the injector. under the lower cushion on top you will need to add a o-ring of some sort to stop you cushion from pushing down.
They do seem close to the TGV still but it seems to seal and sit properly without hitting. I may add another nitrile o-ring on the lower cushions.
Whats everyone using as a better fit option five-o injectors? do the FIC have the same issues?
Message Board Statistics All times are GMT -4. The time now is 04:32 AM.
