Welcome to the North American Subaru Impreza Owners Club Tuesday November 25, 2014
Old 04-21-2012, 11:11 PM   #76
cdurand
Member#: 261682
I just noticed you have the new MachV wheels, I live 5 minutes from that shop that's where I get everything done, now I actually remember your car featured on Mach V facebook.
cdurand is offline   Reply With Quote
Old 04-21-2012, 11:27 PM   #77
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Yes, I was on their Facebook page! I love the wheels!
Old 04-21-2012, 11:44 PM   #78
cdurand
Member#: 261682
I just added your dyno graph as a comment, it's funny to think that you can smoke 90% of all STI's out there with your stock looking wrx
Old 04-22-2012, 01:00 PM   #79
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by xluben
My car has always looked kind of stealthy and I get literally no one trying to play with me on the street.
....oh you just wait.... when i roll up you know wassup!
Old 05-30-2012, 11:23 PM   #80
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
Awesome build and great numbers.
Stupid question, is the boost gauge obstructed by the wiper lever, and does it obstruct the speedometer at all? I noticed it in the second video and really like the placement.
Old 05-31-2012, 01:39 AM   #81
djc1827
Member#: 238618
455whp/480tq 2.5xt-r
Nice numbers now get her to the track and be the first in the 10s with a 20g!
djc1827 is offline   Reply With Quote
Old 05-31-2012, 01:56 AM   #82
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Real nice numbers! I'm hitting 400 hp on the airboy spreadsheet for me at 24 psi. I know I have a safe and reliable tune for my stock block at the moment... but, I kinda want to up the boost to 26 psi now... I just wanna keep it safe and I know i'm pushing it.
Old 05-31-2012, 03:04 AM   #83
rexblake
Member#: 178426
2010 Audi S4
I'm curious what this car would put down on either RS Motors dyno or DB's. Any plans on doing some pulls on either of theirs for comparison sake?
Old 05-31-2012, 09:54 AM   #84
Nuke209
Member#: 108089
NF Performance
Prob 415-420
Old 05-31-2012, 11:00 AM   #85
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
This is a pretty accurate photo of what I see from the driver's seat.
I a little bit of the boost gauge is blocked, but only the part that doesn't matter. The oil pressure gauge is blocked quite a bit. I can see it if I lean forward and look. It blocks a minimal amount of the OEM coolant temp gauge.
Doubt it. I'd like to keep the tranny in one piece as long as possible.
This tune did 438WHP on Airboy at 26psi.
I was on RS's dyno when I had the 20G XTR, stock motor and lower boost. It did 390WHP at 22psi. Same tune did 366WHP on Airboy. The new tune does 438WHP @ 26psi on Airboy. So, 438-366=72. And 72+390=462. Haha. I am not making this up. Very odd coincidence. In reality, I think it would probably do low/mid 400's at RS.
Old 11-27-2012, 03:12 PM   #86
tank the ek
Member#: 295911
Don't mean to wake up an older thread, but was the choice of the stock cat-back for the sake of noise, or was there another determining factor? Kind of curious if there could be anymore power pulled out of this with a larger/aftermarket catback, and how much.
tank the ek is offline   Reply With Quote
Old 11-27-2012, 03:21 PM   #87
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Yes, it was simply to keep it quiet. I switched to the GReddy Ti-C exhaust (3.15" piping, N1 style muffler) and Virtual Dyno showed that it gained around 20WHP, but it was a little loud for me.
Since then I switched to the GReddy SP Elite (quad tip, much quieter) and the Invidia EL header. Recent logs still show me about 20-25WHP higher than when I dyno'd with the stock header and stock exhaust.
From what I've seen, the stock cat back is pretty decent, but at 400+ WHP it does start taking a little power away. Most all of the 3" options will do fine at that point. An N1 style can is going to be best, but it's not a huge difference.
Old 11-27-2012, 03:25 PM   #88
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
There's no way your making more power than me and I have a Dom2.5xtr making shy over 400 with an aggressive tune on a built block. But then again... could it be possible?
Old 11-27-2012, 03:28 PM   #89
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Depends on dyno and tuning. I think Phatron usually uses Airboy, which reads a little lower than a Dynojet (more like a Mustang). What is your boost pressure at peak power? Changes in boost can have a pretty significant impact on power output.
Old 11-27-2012, 03:33 PM   #90
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Here is an example of that, which I did a few days ago:
I did back to back pulls on the same stretch of road at varying boost levels and then plotted out the results in Virtual Dyno (reads very similar to the Dynojet that I was on for the original post). I did pulls at 20psi, 24psi (really more like 23.5psi) and then 27psi. The back to back results at each boost level were consistent withing a couple HP, and each increase in boost changed the peak power by about 40WHP.
Old 11-27-2012, 03:36 PM   #91
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Sorry for another post, but I was just thinking that another good way to compare actual power output is 50-100mph time. If you post a speedo video to this thread (HERE) I can calculate the 50-100mph time.
Old 11-27-2012, 03:46 PM   #92
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Last time I logged I peak right at 25 psi and taper to 23 psi. I noticed a bit of boost loss due to my fmic. When I had my tmic I would lose 1.5 psi. I'm searching for more power, and i eventually will find it in a Dom4xtr. Lol!!! I started MMA again so my priorities shifted a slight bit.
Old 11-27-2012, 03:50 PM   #93
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
I recently moved and I don't have good roads to log close by. Next time I hit up the canyons I will log and try to get some footage.
Old 11-27-2012, 03:52 PM   #94
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
This is pretty close to my log that did 440WHP in Virtual Dyno. That should be around 400WHP on Airboy, so that seems to be in the ballpark for what you have. Do you have full bolt ons (header, EWG, etc)? Are you running E85?
Old 11-27-2012, 04:05 PM   #95
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You wanna run?
That man was neck and neck with me driving another setup similar; MAP EF3 turbo.
Old 11-27-2012, 04:51 PM   #96
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Lets see my mods are dom2.5xtr, el headers, up pipe, tbe, tsudo N1, 3" custom cai, fmic, forge bpv, ebcs, 1200cc fiveo's, walbro fp. Can't think of anything else. Built block with jp pistons, arp head studs, crower rods, clevite bearings, new crank new pump... Phatbotti tuned.
Stage 3 6 puck clutch. 25 mm sways f/r, 1.5 " lowered progressive springs. Bridgestone 050a rft's.
That's about it... I enjoy smoking v8's!
Old 11-27-2012, 04:55 PM   #97
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Is this on E85 or pump? Overall pretty similar build to mine.
Old 11-27-2012, 06:28 PM   #98
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
E85 of course. I dont think I'm ever going back to gas. LOL!
Old 11-27-2012, 10:32 PM   #99
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Originally Posted by FuJi K View Post
You wanna run?
It did pretty well against the Dom3 the previous year too
Sounds very, very similar to mine. I am externally gated and have the slightly smaller turbo, though. I think if you turned up the boost a little and hopped on a Dynojet it would probably make the same numbers as mine.
Old 11-28-2012, 07:54 PM   #100
PROcede
Member#: 293500
11' WiderBody Hatch
xluben how is that wideband mounted down in the cubby hole? Is it just hanging there or?
PROcede is offline   Reply With Quote
FP Green vs. Blouch 20g xt-r fbi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 11-28-2011 11:56 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket SCIC Private Classifieds 1 02-08-2007 01:02 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket Private Vehicle 'For Sale' Classifieds 2 02-08-2007 01:01 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket SCIC Private Classifieds 31 02-07-2007 02:01 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket Private Vehicle 'For Sale' Classifieds 32 02-07-2007 02:00 AM
