Old 11-27-2012, 03:29 PM   #1
chinojl7
Member#: 334584
2004 WRX
blue
Impreza GC8 where is the flasher relay WRX 04??
hi i want to know wich of the six relay I see under the dash near the fuse box is the signal flasher relay. thanks
chinojl7 is offline   Reply With Quote
Old 11-27-2012, 04:15 PM   #2
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
just check the diagram sticker on the inside of the fuse box cover?
Old 11-27-2012, 04:21 PM   #3
SpamBot
Member#: 287534
It's not located in the fuse box. It's called a "Turn signal & Hazard Module" and connects to a black, 3 pole connector near the steering column (looks like it's in that area). The wires going to it should be Brown/red trace, Black/yellow trace, and Black.
SpamBot is offline   Reply With Quote
Old 11-27-2012, 05:03 PM   #4
Mach V Dan
Member#: 12029
Turn on the hazard lights. Stick your head in the passenger footwell, under the steering column. Listen for the clicking.
--Dan
Mach V
FastWRX.com
Message Board Statistics All times are GMT -4. The time now is 08:23 PM.
