Old 11-25-2012, 08:54 PM   #51
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Anything could be made to work if you throw enough money and time at it. Running AVCS heads and cams without AVCS control is sub optimal since your intake cam centerline will be more retarded than normal. Modify the cams and run non-AVCS cam gears solves that problem.
Old 11-26-2012, 03:30 PM   #52
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
So running the cam without AVCS (retarded position) would make the engine work better up high or down low?
renhoek is offline   Reply With Quote
Old 11-26-2012, 06:09 PM   #53
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Up top.
On AVCS car you advance the cam in low rpm and bring it back to 0 ( full retard ) in higher rpms
bswilmington is offline   Reply With Quote
Old 11-26-2012, 06:10 PM   #54
. o 69 o .
Member#: 124938
if you use can non avcs cam gears they would be center, you could adjust them manually with adjustable aftermarket cam gears
. o 69 o . is offline   Reply With Quote
Old 11-27-2012, 03:43 AM   #55
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Thanks guys. I have a race only car that I am building a hybrid for, so it sounds like the 2005 AVCS heads I have will work just fine. Rarely do we get below 3000rpm.
Old 11-27-2012, 10:41 AM   #56
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Does anyone know if you can put ej205 cams in ej257 heads? I ask because that would be a good fix for the lazy cam profile of the ej257 cams running without AVCS.
Soarer is offline   Reply With Quote
Old 11-27-2012, 12:03 PM   #57
kellygnsd
Member#: 32669
LINK G4 hybrid STi
From what I was told the cam profile is the same as the STi cams but the lift is less so it would probably be better to just modify the STi cams to work with non-AVCS cam gears. I've sold a few STi cams to WRX folk who did just that.
Old 11-27-2012, 12:13 PM   #58
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
I've got a set of Kelford 272 cams in my ej205 heads right now. I'm wondering if I can use ej257 heads and put in the Kelford cams with the ej205 cam gears. That way I could avoid having to send out my ej205 heads to be chamber matched and I'd end up with a set of heads that are less prone to cracking between the spark plug hole and valve hole. Thoughts?
Old 11-27-2012, 12:30 PM   #59
kellygnsd
Member#: 32669
LINK G4 hybrid STi
You can if you use the right parts. You can swap WRX and STi cams and cam gears all day in either head just use the correct cam seals for each application.
Old 11-27-2012, 06:22 PM   #60
. o 69 o .
Member#: 124938
I have been looking at exactly this right now and from what I have found, the answer is yes. I am still trying to figure out what oil ports need to be blocked. I believe a cam sensor also needs to be added to the head. This is a part that can be reused off your other motor, and apparently a bracket is available for the mounting.. you just need to drill and tap a hole to secure it to the motor
Old 01-28-2014, 03:01 PM   #61
Bcboywrx
Member#: 379982
Anyone know of a capable machine shop in vancouver bc
Bcboywrx is offline   Reply With Quote
Old 01-28-2014, 05:41 PM   #62
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
I shipped my heads to ASF Machine in Colorado because they do exceptional work. I'm located in Massachusetts so it wasn't cheap. Might be something to look into.
03SubyWRX is offline   Reply With Quote
Old 01-31-2014, 05:34 PM   #63
cueballsi
Member#: 202736
2002 WRX- 6spd - MBP
1992 Civic VX 40MPG
is 5/8" the correct size hose ??
nm found it ... :-)
cueballsi is offline   Reply With Quote
Old 01-31-2014, 06:08 PM   #64
pawelzak98
Member#: 277662
2006 impreza wrx sti
UGM
very helpful
pawelzak98 is offline   Reply With Quote
Old 02-09-2014, 03:22 PM   #65
WrXwAgOnWrB
Member#: 269631
05 9-2x
Dark Blue Metallic
I have a 2.5 06 short block. And the 05 Saab 9-2x Aero 5 speed 2.0l motor.. I am going to do the build in the spring...
My question is. I planned on using most of my original parts. I am using the ej205 heads from my car. And changing to the 6 speed transmission with STI cluster. I was hoping to do new STI head gaskets and timing belt kit ect.. The block has the oil pan and oil pump and water pump on it.
I was hoping I do not need to change ECU or wiring harness?? My car is custom tuned at stage1 right now and runs great. Any chance of me not gaining much from doing a hybrid build..
I have a ported polished turbo, cold air intake w/inlet hose, Aluminium radiator, cat back exhaust. Or do I do an uppipe only and tune to stage2
Thanks for the help..
WrXwAgOnWrB is offline   Reply With Quote
Old 02-10-2014, 12:52 PM   #66
gfx2043
Member#: 205174
I'm running a built 257 with 8.5:1 pistons, ED's CNC heads, stock STI head gasket, 272 cams, full supporting mods and a Blouch DOM 1.5 xt-r. I made just over 350AWHP on 93 and 437 ON E85. The timing that I can run with these heads is awesome. Just over 22K miles with no issues.
gfx2043 is offline   Reply With Quote
Old 02-10-2014, 02:49 PM   #67
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
And you think alot of timing adds up to alot of hp? Or that being able to run alot of timing is the way to go? Nvm, I just remembered this is nasioc.
fastblueufo is offline   Reply With Quote
Old 02-10-2014, 03:12 PM   #68
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Lol. There's a point of too much timing true. But in most regards the more timing you can safely run the better. Especially when your talking about hybrid setups that in some cases can't even run a stock timing map without knocking
cowboy_Rob is offline   Reply With Quote
Old 02-10-2014, 04:01 PM   #69
fastblueufo
Member#: 212154
02 billet crank
Thats because static cr and quench play a large roll in affective cr with different octane fuels and also combustion chamber design. And not to leave out cam design that affects dynamic cr. An engine doesnt have to run alot of timing to make alot of hp. Ive seen cars run as little as a few * of timing and make lots ofpower
Old 02-13-2014, 01:30 PM   #70
gfx2043
Member#: 205174
I have tuned my share of hybrids, some are dissapointing and some not so. But when you have to retard the timing so much that the timing map doesn't look any where near what a 205 or 257 map is you can be certain that the combustion efficiency just isn't quite there. Timing also plays a large roll in telling how a motor behaving. Any time the timing can be advanced toward TDC you stand a good change to make more Hp, but by far the biggest gain is that you have a larger safety margin against detonation. Better ignition timing is a sign of more efficient / controlled combustion. This efficient combustion goes hand in hand with better fuel economy, more knock control, and better driveability. Since most hybrids struggle with detonation I feel that being able to run better timing is a big sign that the motor will not have to deal with detonation issues as much at any given power level.
Old 02-13-2014, 03:30 PM   #71
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I built my ej 257 block with the je hybrid pistons. I used my ej205 heads with no chamber work. I installed bc 272 cams to help move the air and installed meth injection to cool the chamber. On a 20g it is making 371 awhp without meth and 398 awhp with the meth. Car runs great with no tuning problems.
Old 02-27-2014, 06:48 PM   #72
cueballsi
Member#: 202736
1992 Civic VX 40MPG
any one know what right idle pulley (the small one) should be used on my 2005 sti block ( 701 casting) and my 2002 wrx 2.0L heads for the timing belt???
I heard something about a double row idler????
Old 02-27-2014, 08:49 PM   #73
subi400
Member#: 216984
1996 Impreza outback
Green
It is the updated subaru double bearing small idler that bolts to the timing belt tensioner. You should use that one not the single bearing roller designed one.
subi400 is offline   Reply With Quote
Old 02-27-2014, 09:00 PM   #74
cueballsi
Member#: 202736
1992 Civic VX 40MPG
Does gates make a double bearing idler? Or do I need to go to the factory??? Any part numbers???
Anything else I should be watching for???
Old 07-09-2014, 09:49 PM   #75
turbo_dreams
Member#: 348721
Before starting a new thread, I figured I'd post up here.
I bought my car with the hybrid swap already done. The PO spun a bearing and was on a bit of a budget with the rebuild. This was my first dip into Subarus and obviously hybrid swaps. I didn't ask one of the most important questions: Were the heads chambered to match the 2.5l block?
I was satisfied with the power levels at the time, but have since developed the itch to go a bit bigger. I talked to the shop that did the swap and they weren't entirely sure if the heads were chambered. I also contacted the PO and he wasn't sure either.
From what I've read, the heads being chambered is a major contributor to knock and essentially not chambering the heads can lead to hotspots and is generally bad news if you want to make power.
So now I'm coming to you guys. Short of ripping the motor apart, is there any definitive way to tell if the heads were chambered?
turbo_dreams is offline   Reply With Quote
WTB 2.5l Shortblock or 2.0 Longblock 97gtguy Private 'Wanted' Classifieds 54 02-15-2010 12:27 PM
2.0L to 2.5L Shortblock Build/ Turbo Options? csmithwrx'05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-08-2008 10:50 AM
wtb 2.5 shortblock & 2.2 heads kylemcspecial RMIC Private Classifieds 0 06-20-2006 01:59 PM
jdm sti v8 2.0l or usdm 2.5l shortblock? WSSBOARD18 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 03-06-2005 03:48 PM
STI 2,0L vs STI 2,5L shortblock - need help calvin434 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-30-2005 10:02 AM
