#1 |
Member#: 300551
SCIC
Vehicle:2002 DD wgn 6 spd 2.1 kel 272's meth 2.5xtr |
I am on my 6th motor, 5th turbo and 6th tune. So my question is who has the perfect set up (for you) and what make it so good?
Im running a 2.1 stroker, kelford 272's, modded stock injectors, fp 20g, tomei el header, tvg deletes, meth and a cbe. It pulls hard after 4k and I think i like it. I might even run this one for awhile.
#2 |
Member#: 296277
Vehicle:2002 Impreza WRX Silver |
jeez that's a lot of motors for one chassis to see.... I have yet to find the "perfect setup" =/
#3 |
Member#: 89628
Vehicle:'02 Wagon VF39'd & Quick Racked |
<-- The one that I'm not blowing up motors on.
#4 |
Member#: 300551
SCIC
#5 |
Member#: 112024
NWIC
Vehicle:03 WRX vf34 wagon 6 spd, track & dd duty |
I'm very content with just a vf34 and support mods. It's plenty quick for me, really reliable, and a very usable power band for the street.
There's obviously much faster cars, but for a DD it's tough to beat. I get a little over 20mpg city, 26.5mpg on freeway, and can hold my own on the track. I've run the turbo setup on the car for 80k+ miles with no issues. Sure more power would be fun, but the 6spd does a lot to cover up the lag. It's pretty easy to keep it in the meat of the torque curve. And honestly, triple digits come so quickly it's more than enough power to get in to trouble. |
#6 |
Member#: 329676
E. Canada
Vehicle:1999 GC8 R-STI White |
This is the engine posted on the front page- white STI. Pretty much S$#% mky pants when i saw it!
Dream Mod List: Engine: JE 925SD Custom Forged Pistons 99.75mm Maxwell Power Services Super H-Beam +2mm Long Rods Factory STI 79mm Crankshaft Dan Benson Racing Darton Sleeved Block Engine Fully Blueprinted and Balanced ACL Race Rod and Main Bearings Kelford 276/272 AVCS Cams 5-Angle Intake Valve Job 3-Angle & Radiused Exhaust Valve Job Ferrea +1mm SS Intake Valves Ferrea +1mm Super Alloy Exhaust Valves Supertech Dual Valve Springs Supertech Titanium Retainers ARP Custom Age 625+ Head Studs ARP Case Bolts STI 11mm Oil Pump Gates Racing Timing Belt Gates Racing Alternator/PS Belt Mocal 19 Row Oil Cooler -10AN Fittings Mocal Sandwich Adapter w/ Thermostat Koyo R2704 53mm Racing Radiator Custom Twin-Scroll Header and T4 Up-pipe Custom 3.5" Catless Downpipe Borgwarner S300sx 83-75 .91AR T4 TS Turbo Dual Tial 38mm V-band Wastegates w/ external dump tubes MAC 3-Port Boost Solenoid AEM 3.5Bar MAP Sensor Cobb MAP Adapter Custom 4" Aluminum Intake Boost Logic Turbo Blanket JIC Titanium Exhaust APS DR725 FMIC with Custom Pipes Tial Q BOV TGV Port and Delete Ported Intake Manifold Ported Throttle Body Rotated Intake Manifold A/C System Removed Crawford Performance V2 Air/Oil Separator GrimmSpeed 8mm Phenolic Spacers Walbro 255LPH Fuel Pump Intank Bosch 044 External Fuel Pump Canton Racing 8 micron Fuel Filter Custom Fuel Surge tank Aeroquip -8AN Feed and -6AN Return Fuel Lines Injector Dynamics 1000cc Fuel Injectors Aeromotive Top Feed Fuel Rails Aeromotive A1000-6 Fuel Pressure Regulator Aquamist HFS-5 Meth Injection System 2x1.0mm nozzles Spec C STI 12L Intercooler Spray Tank Vi-Pec V88 Standalone ECU with Anti-Lag and Launch Control Odyssey PC680 Battery |
#7 |
Member#: 856
International
Vehicle:2005 JDM STi Black |
This works for me in my daily driver MY05 JDM STi.
#8 |
Vehicle:OK Houston we have an Uncle |
#9 |
Member#: 300551
SCIC
^^^thats pretty awsome!
#10 |
Member#: 246813
NWIC
Vehicle:'02 WRX WRB :: |
What's your build John?
incredible powerband. |
#11 |
Member#: 166005
MWSOC
Vehicle:2005 Saab 92x Beaten Silver |
#12 |
Member#: 856
International
It's a JDM STi built as a forged 2.1 with an Owen Developments Bolt on Twin Scroll Turbo, now running 2.0BAR peak, 1.7BAR at 7000rpm. It will pull over 2.2BAR, but 2.0BAR is a safe peak to use long term. Engine is mostly stock JDM, no mods to the heads or cams, stock exhaust headers. EcuTek 800cc injectors, Stock ECU using EcuTek MegaRom mapped by Bob Rawle. Still using the stock MAF in a large bore inlet with K&N filter. Still on a TMIC, made by Chevron Motorsport from F1 spec heat exchanger material.
Car is a full weight 1460Kg JDM STi, 4th gear acceleration shows 40 - 60mph = 1.7 seconds 50 - 70mph = 1.5 seconds 60 - 80mph = 1.6 seconds 70 - 90mph = 1.9 seconds |
#13 |
Member#: 300551
SCIC
800cc injectors at 100% duty makes less than 475chp using witchhunters calculator. So what am I missing?
#14 | |
Member#: 89628
#15 |
Member#: 300551
SCIC
^that must be it.
#16 | |
Member#: 856
International
I am using 84% injector duty when running 20% methanol mix at circa 490BHP, and you need 8% more fuel flow compared to the equivilent pump fuel only, when running with a 20% Methanol mix. 99RON fuel is the equivilent of the USA 95PON fuel, it's nothing special, normal everyday super unleaded pump fuel over here. These are well tested injectors and have been used to produce 600BHP on normal pump fuel. |
#17 |
Member#: 300551
SCIC
I was hoping more people would like the combos and post up what they have and why they like it. It doesn't have to be the fastest or the most powerful. Just fun dd's.
#18 |
Member#: 178426
Vehicle:2010 Evo X MRt Silver |
I've had multiple set ups on my 02 wrx. Tdo4 full bolt ons and E85, 16g full bolt ons E85, 68hta built motor full bolt ons E85, dom3 xtr built motor full bolt ons e85. All with brake upgrades, built tranny, coilovers, sway bars, etc.
My fave setup so far? Evo X stage 2. By far, hands down, the best set up I've ever had. Last edited by rexblake; 12-02-2012 at 09:34 AM. |
#19 |
Member#: 856
International
Well thats helpfull on a Subaru BBS
LOL |
#20 |
Member#: 178426
Lol he asked favorite setup! Never said it had to be a Subaru. Quite frankly, after all the cars I drive before I bout the X, I'll prolly never own another soobie. Unless the BRZ STI is just amazing, as in, significantly better than a boss mustang 302 or Porsche cayman. At least on par with those two and significantly cheaper.
#21 |
Member#: 330606
SCIC
Vehicle:2003 wrx WRB |
The ESX 1000hp build:P
#22 |
Member#: 300551
SCIC
Not alot of ideas being posted?
#23 |
Member#: 340271
Wow I only dream
#24 | |
Member#: 283663
NESIC
Vehicle:2004 WRX WRB |
You aren't married are you… My dream setup is what I'll be running shortly 04 WRX Strong 2.0 motor, Tomei UEL STi oil pan 3" DP Totally Catless STI exhaust VF39 STI pink injectors Just enough to have fun with. Ok, it's not my dream setup but it's what I got and it makes me happy. |
#25 |
Member#: 300551
SCIC
[quote=claythrow;38679466]You aren't married are you…
Yes I am married but I own a shop. |
