Old 11-25-2012, 05:45 PM   #126
audiophile21
Member#: 338539
Incredible project, definitely subscribing this one!
audiophile21 is offline   Reply With Quote
Old 11-26-2012, 12:29 AM   #127
RCR46and2
Member#: 331355
2003 Legacy Outback
black and blue
What part of birmingham are you located? I would love to see this in person
RCR46and2 is offline   Reply With Quote
Old 11-26-2012, 01:17 PM   #128
lgt2000
Member#: 140073
2005 LGT
Red
Diff is looking nice in there. Have you figured how you are going to get axles made up. The R200 is one of my options as well
lgt2000 is offline   Reply With Quote
Old 11-27-2012, 04:18 AM   #129
TyConway
Member#: 193189
02 wrx
I live about 20 miles outside of bham.
TyConway is offline   Reply With Quote
Old 11-27-2012, 04:22 AM   #130
TyConway
Member#: 193189
02 wrx
Drive shaft shop quoted me $2k for custom axles and hub upgrades.
Also the 350z R200 is not the same as other r200's found in other cars. The 350z / g35 R200s are larger, and everything inside and out, ( even housing) is larger. I have a R200 out of 240 and the 350z R200 is just a beefed up HD unit. Going tomorrow to dig around my friend salvage yard. An nissan armada has a 9" ring gear diff. May have to see how much larger that differential is physically. But my 350z Diff barely has enough clearance from the axle hubs and the control arms, and it should hold up to the power no problem. Been looking a other v8 swapped 350z's with turbos and they are running mid 10's and acutally ripping the differentials out of the mounting locations and not hurting the differential.
Old 11-27-2012, 06:27 AM   #131
dundunskeert
Member#: 184151
2000 STI RA Limited
Originally Posted by TyConway View Post
1.jpg[/IMG]
That tie rod spacer scares me. I would definitely reinforcing it somehow. A company called 6gun made a roll adjustment kit a few years back and had several break. Their kit was a 50mm drop, yours looks like more than that.
Check out this thread to see what I'm talking about.
http://forums.nasioc.com/forums/show...highlight=6gun
Sick build by the way! I can't wait to see it in action.
dundunskeert is offline   Reply With Quote
Old 11-27-2012, 07:09 AM   #132
dundunskeert
Member#: 184151
2000 STI RA Limited
Something like that would be ideal.
Old 11-27-2012, 10:29 AM   #133
lgt2000
Member#: 140073
2005 LGT
Red
I see, I have been working with Moser as they made the axles for the V8 Miata we are working on. I also have a R200 from an 08 350z from one of my friends cars sitting at the shop and it had the rear cover stud broken off due to wheel hop
Old 11-28-2012, 12:42 AM   #134
RCR46and2
Member#: 331355
2003 Legacy Outback
black and blue
Im located in the trussville/clay/pinson area so if you ever need help just hit me up.
Old 11-28-2012, 04:45 AM   #135
TyConway
Member#: 193189
02 wrx
Its 1.5" solid chromoly drilled out to 5/8" for the grade 8 bolt to go through. I've done several setups on rock crawlers with no issues, and thats bashing off rocks. I promise the steering rack tie rod would break first. pull the dust cover off and check it, the rod tapers down very tiny. That would break first. Actually Id put some money on it that my spacer and bolt is stronger than that factory tie rod that use to be there.
Its only 3/8" thick at the small point, i know the load is applied at a different angle on that, but I still don't have any concerns with my spacer. I saw the thread about the breaking part, I actually bought some similar for my rx7, they are cast and very brittle. More than likely that car that was pictured, was autocross and hit a hole or slid off the track, then you would expect damage like that.
Old 11-28-2012, 04:47 AM   #136
TyConway
Member#: 193189
02 wrx
Probably due to the very soft bushings, Im going to upgrade mine and put another stud on the oppisite side of the cover.
Old 11-29-2012, 04:17 AM   #137
TyConway
Member#: 193189
02 wrx
got 1 turbo manifold semi mocked up.... just to get the turbo placement, also still got 1 runner to add on.
Old 11-29-2012, 01:04 PM   #138
rich045
Member#: 210633
02 wrx
do you have enough space to run the downpipe through there? also it doesnt seem you have much space for a wastegate unless you tuned it down to the bottom. seems like you are gonna have some fun with that =)
rich045 is offline   Reply With Quote
Old 11-29-2012, 01:33 PM   #139
PurdueWRX05
Member#: 283298
2007 STi
UGM
Subscribed!
Could just run the exhaust out of the quarter panel
PurdueWRX05 is offline   Reply With Quote
Old 11-29-2012, 04:37 PM   #140
TyConway
Member#: 193189
02 wrx
yea plenty of room in the back, and wastegate is going in the middle of the 2 merged pipes on top... i'll post pics when i get it mounted.
Pictures just make it look tight, theres actually a lot of room
Old 11-29-2012, 09:02 PM   #141
TyConway
Member#: 193189
02 wrx
Originally Posted by PurdueWRX05 View Post
Subscribed!
actually thought about that or atleast the wastegate... Had a 478whp b-series honda with an open downpipe, at night the flames were nice
Old 11-30-2012, 05:15 PM   #142
TyConway
Member#: 193189
02 wrx
Old 12-01-2012, 09:39 AM   #143
rich045
Member#: 210633
02 wrx
ooooo so you are doing a twin scroll set up, now it makes sense, i thought you were going twin turbo. why not just throw a 42r instead of that precision?
Old 12-01-2012, 12:54 PM   #144
gsrcrxsi
Member#: 236952
2010 WRX
Spark Silver
I thought twin scroll needed equal length headers though? There's no way to have equal length with the available space and the turbo in that location.
Old 12-01-2012, 01:28 PM   #145
Cheveyboy
Member#: 34773
2009 WRX
You're My Hero.
Cheveyboy is offline   Reply With Quote
Old 12-01-2012, 01:38 PM   #146
TyConway
Member#: 193189
02 wrx
no not running twin scroll.
Old 12-01-2012, 02:00 PM   #147
TyConway
Member#: 193189
02 wrx
Old 12-02-2012, 02:51 PM   #148
RallyBot 6.0
Member#: 337195
Maroon/black
lookin good dude. wish i was in the area id totally do grunt work around your shop just to get a chance to help with this and gain some knowledge lol
RallyBot 6.0 is offline   Reply With Quote
Old 12-02-2012, 03:51 PM   #149
05subysti
Member#: 268190
woah i think this is the best subaru ls build. plus you are probably the first to put a turbo on it as well. MOAAARRR.
Old 12-02-2012, 11:58 PM   #150
TyConway
Member#: 193189
02 wrx
Thanks, should be the first turbo ls swap, as far as i know.
Message Board Statistics All times are GMT -4. The time now is 09:41 PM.
