Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 11-28-2012, 02:56 PM   #1
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
Default Strange RPM Cut/Rev limit issue
So I'm tuned on Open Source and I'm currently retuning on the Cobb AccessPort. In OS we were able to rev out to 7250 before the car stops revving (seems like a cut/limiter is being hit).
Now fast forward to Cobb Accessport tuning. Same base map, but the car stops revving at 6500rpm Makes no sense. If I have a mechanical problem I can understand not being able to rev past 7250rpm in both OS and Accessport...but what's up with the Accessport not letting me rev past 6500rpm? There's a 750rpm difference, but the base tune is the exact same. I have all of the same limits, dtc turned off, everything matches up with the open source tune.
Tuning
Speed Density
Rev limit set at 7500rpm
Boost limit 32psi
Launch Control turned off
FF Shifting turned off
Mods:
Built SB
Stock heads
Full Race twinscroll kit
I changed and regapped my plugs. Cleaned the Crank sensor. I'm not out of fuel. Heck, when I free rev in neutral it still cuts at 6500rpm. Don't know what else to look for at this point.
***I posted this in the Tuning section as well. I think the 750rpm delta between OS and Cobb AP may possibly be tune related while the hard limit (7250rpm) may be hardware/mechanical issues.***
Old 11-28-2012, 04:44 PM   #2
Leafy
Member#: 330625
2006 WRX
Is it acting like a fuel cut limiter (ie wideband going nuts, not much popping), a spark cut limiter (ie, wideband going nuts, loud popping), or a throttle limiter (wideband stays kind of normal just sounds and acts like you eased off the throttle)?
Old 11-28-2012, 05:02 PM   #3
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
By your explanations it's throttle limiting. Wbo2 is solid until I let off. Load drops of course, feels like it stops making power. It'll overrun up to 7k but stable off at 6500. I'll post a log
Old 11-28-2012, 05:30 PM   #4
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
The only thing I see is on the Y-Axis for RPM on the throttle map that it's scaled to 6800. But I believe the AP will use the last cell for anything past 6800rpm...so it shouldn't matter
Old 11-30-2012, 10:44 AM   #5
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
Update: So the longer than I hold the throttled down the more violent it gets, bucks but no knock!....and afr does go crazy. I logged TPS, APS, Inj pw. Ill look at the log in a bit. Thinking its a fuel/spark cut now
Old 12-01-2012, 05:57 PM   #6
atomicfire
Member#: 136296
2005 STi
might have more luck in the tuning forum
atomicfire is offline   Reply With Quote
Old 12-02-2012, 12:25 PM   #7
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
Thanks. I have a thread there as well
Old 12-02-2012, 04:47 PM   #8
Tripintaz
Member#: 245218
2013 STI Limited
There is another table that has to be adjusted when raising the rev limiter using Cobb ATR. If you go to their site and review the advanced tuning document this is reviewed in detail.
Old 12-03-2012, 03:57 PM   #9
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
Ok thanks, ill check it out.
Old 12-04-2012, 10:35 AM   #10
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
Ive been fighting the exact same problem for awhile now, but im using OS. About a year ago when I had a 20G on the car, I could rev as high as I wanted to. Once I started doing bigger turbo setups, thats where it started. It just doesnt go past 7000rpms whether im in neutral or in gear. All the DBW settings are exactly the same as when I had the 20G. Its starting to get me pretty stumped.
banshee04 is offline   Reply With Quote
Old 12-07-2012, 12:21 PM   #11
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
I have another thread (HERE)
