Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 11-28-2012, 06:01 PM   #576
danisfake
Member#: 194663
2003 Cobra
Sonic Blue
Anyone know of any good muffler shops around that don't charge an arm and a leg for service? Looking to get a new midpipe without a resonator in it or a relatively smaller one. I would have them use my current mid pipe but the flex joint has a small hole in it.
danisfake is offline   Reply With Quote
Old 11-28-2012, 06:54 PM   #577
SubyRS03
Member#: 245297
2004 WRX vf48 93 oct
My wrx threw a p0303/0302 cyclinder misfire on 2 and 3. she ran beautiful earlier today and right before i filled up at the new sphinx on 14 and 29 in greer now shes bogged down when i get on the throttle im still making boost and idles perfect. also a week or two a ago the tgv code came up the sensor by the turbo i wiggled it and made sure it was tight and the code went away. but if you guys can help that would be awesome im scanning the forums now. thanks!!!
SubyRS03 is offline   Reply With Quote
Old 11-29-2012, 08:36 AM   #578
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Are you running E85? if so misfire codes are normal.
If not it could be your plugs, injectors or bad gas. Can you pull a learning view?
Old 11-29-2012, 08:28 PM   #579
SubyRS03
Member#: 245297
jaun i put some lucas injector cleaner and she runs fine but now i have a pin hole leak some where near the turbo because it was dripping onto the down pipe i could see the drips where they landed but not from. but i could hear it. im not sure if it was oil or coolant didnt get a good smell. its a new turbo under warranty still so most likely isnt it im thinking maybe a line to the turbo or a line near the turbo any thoughts or expiernce with this problem before?
Old 11-29-2012, 08:36 PM   #580
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
If it's dripping onto the downpipe it should be burning. If it's sweet it's antifreeze. Keep an eye on your oil and water levels/ gauges in the mean time. You'll have to pull the turbo heat shield to really see anything. on the leak. Also if you get any more blinking CELs post back.
340Duster is online now   Reply With Quote
Old 11-29-2012, 08:47 PM   #581
SubyRS03
Member#: 245297
yea i got a lil smoke from the drips and ill keep an eye i havent had any blinking cel's yet. the L pipe under the intercooler has what seems to be a lil oil spray im not to sure i just recently bought this car about a month ago im in the middle of fixing odds and ends. and i know the sweet smell from coolant i could pick up some liquid silver to add to the coolant and fix the pin hole. but if its oil idk saterday ill run it and then jack it up and see if i can see anything. thanks for the tips
_allen
Old 12-01-2012, 02:20 PM   #582
SubyRS03
Member#: 245297
Now i have a a misfire on cyclinder 1 2 3 p0303/302/301 they keep developing. but i have found that the hose to turbo to the intercooler isnt tight and all the way on there and the MAF hose connecting to the intercooler as well isnt all the way on there. ugh!!! im taking off the intercooler to see for a better look.
any comment and tips would be awesome!
Old 12-01-2012, 04:41 PM   #583
SubyRS03
Member#: 245297
ok it is DEFF OIL. The L hose needs to be replaced along with the MAF hose there just worn down i hope that explains my oil leak now for these darn misfire codes.
Old 12-01-2012, 10:55 PM   #584
juanmedina
Member#: 133146
Is the car smoking at all from the exhaust? how about from the oil filler cap?
Old 12-02-2012, 10:02 AM   #585
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Get the intake leak issues fixed ASAP. The pre-turbo leaks are hard to track down sometimes, but they will make the car run lean.
Old 12-02-2012, 08:10 PM   #586
SubyRS03
Member#: 245297
@jaun no the exhaust doesnt smoke at all. i havent checked the oil cap yet but i will if you guys want to get together and help me scope out everything that would be awesome!! do beer n burgers at someones place.
@340duster i will i plan on getting the L hose first because of my lack of funds im gonna call some junkyards and see if they have it for cheap untill the one comes in from boxer4.
do you guys think after the hoses get replaced itll help fix the misfires?
Old 12-02-2012, 09:06 PM   #587
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
If you have a boost leak (after the turbo) the car basically won't run at all when it boosts. Do you know who tuned the car?
Old 12-02-2012, 09:40 PM   #588
danisfake
Member#: 194663
2003 Cobra
Sonic Blue
I thought post turbo leaks (exhaust leaks) were not detrimental to the car and pre turbo leaks would cause maf issues which are bad for the car since metered air is not correctly being measured.
Old 12-02-2012, 09:55 PM   #589
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
I'm talking about a boost leak between the compressor outlet and the throttle body. If you have a bad enough boost leak the car won't run at all under any real load. Pre turbo (compressor housing) will cause MAF (lean) issues.
A pre turbo exhaust leak will just keep you from hitting target boost, and make your car smell like exhaust.
Old 12-02-2012, 10:04 PM   #590
danisfake
Member#: 194663
2003 Cobra
Sonic Blue
Ah okay thanks for the clarification!
Old 12-05-2012, 02:19 PM   #591
calebtharrell
Member#: 242113
2004 STi, 2008 STi
The stock hard oil feed line to the turbo is known to get a hairline crack in them. I had to replace mine with a SS line about a month ago because of the crack. So, the oil leak may be coming from that area.
calebtharrell is offline   Reply With Quote
Old 12-06-2012, 09:38 PM   #592
SubyRS03
Member#: 245297
ok thanks for the tip!! ill check it out!
Old 12-06-2012, 10:28 PM   #593
Coppertop8705
Member#: 235044
06 WRX
That feed line is a bugger, mine cracked on me twice. First time was a quick braise job, 2nd time I braised that thing real gooooood. If it is cracked you'll see oil pooling up on the center section of the turbo and it will smoke constantly out of the hood scoop.
I'm no expert but I'm happy to look at it if you need another set of eyes on it.
Coppertop8705 is offline   Reply With Quote
Old 12-06-2012, 10:39 PM   #594
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
That's news to me. I've luckily never ran into that *finds wood to knock on*
Old 12-07-2012, 06:35 PM   #595
SubyRS03
Member#: 245297
Deffinatly! that way we can scope it out and see if anything else needs done. i have my L hose and intake manifold hose coming either tomorrow or monday. my rs didnt have coil packs so this is the first im dealing with them id like to take them off and check em out to see if there ok but dont know what bad ones look like. because my car still has the misfire cel and its bugging the heck out of me!!lol if anyone else would like to join ill buy a case! lol incentive maybe turn this into a work on your subaru meet lol just pm me your number and we'll set something up i really appreciate it!
Old 12-08-2012, 06:00 PM   #596
SubyRS03
Member#: 245297
today was the first day i got a blinking check engine and now cobb reads p0303/302/301 and TWO PFFE which i belive are misfires. ive almost got the gas tank drained then to fill up and add some seafoam and see if it helps! *crosses fingers*
Old 12-11-2012, 09:46 PM   #597
CTS-Vz
Member#: 321671
Hey Guys --- Just picked up a new-to-me 07 STI. This is my third STI (04, 06, now 07) and I'm glad to be back on the Subby sauce! I will probably do a formal member page when I have more time but wanted to give a basic 'hello' to the SC/NC guys...I live in S Charlotte.
07 STI (picked up from FL Subby dealer with 17,896 on odo). Took the car the Motion Lab to get Stage 2 mods plus tune and I pick it up Thurs. look forward to being Subscribed to the thread!
Vz
CTS-Vz is offline   Reply With Quote
Old 12-11-2012, 09:52 PM   #598
snowboarder2587
Member#: 322407
2012 WRX Limited
Plasma Blue Pearl
Vz
Awesome man!! Welcome back
snowboarder2587 is offline   Reply With Quote
Old 12-14-2012, 01:31 PM   #599
danisfake
Member#: 194663
2003 Cobra
Sonic Blue
Vz
Congrats!
How'd the tune go?
Old 12-26-2012, 06:23 PM   #600
CTS-Vz
Member#: 321671
Went great!! The guys at ML do amazing work. 320 HP and 340 ish Torque I think? Been a couple weeks since I picked it up. The car had weird boost spike before which they fixed and the car feels a lot more reliable. They even heard an exhaust leak and fixed it with a new gasket to the midpipe without me asking for free.
Subies in Greenville SC meet? LanceGantry South East Region Forum 33 05-25-2009 07:21 PM
Greenville, SC Meet Feb 21st @ 4 PM Noeladams South East Region Forum 98 02-25-2009 07:01 PM
Greenville, SC meet & then eat?? Silver_04_WRX_SC South East Region Forum 45 10-21-2006 07:50 PM
Greenville SCCA meet Mon night Porter South East Region Forum 4 02-13-2001 12:03 AM
