Old 08-29-2012, 03:36 AM   #26
GrumpyPitbull
Member#: 313311
Originally Posted by JAMM0N View Post
no your wrong. there are a lot of people with stock who has had this problem.
a lot of people suggested flashing before even leaving the lot.
others also recommend forged pistons.
so i saved you from other peoples remarks.
STOCK TUNES SUCK, If your car breaks down and it still has warranty have subaru fix it!
I'll agree the stock tune is not great, but there are not alot of people experiencing broken ringlands who are all stock. 99% of the broken ringland stories are on modded cars ... and many of those were VERY modded.
Some on this forum act like the ringlands are guaranteed to break. Strangely, I'm on my 3rd WRX and have never had a major mechanical failure at all .. and two of those cars were over stage 2.
Am I lucky? Has Baby Jesus smiled upon my car modding endeavors? No .. I simply do proper maintenance, put quality parts in my car, do one mod at a time ensuring all is running good before doing more, and last but not least I do not drive my car like the Duke Boys.
If you buy Chinese knock off parts, install 5 mods at a time, and drive your car like a maniac ... then yes, you will likely have problems.
Old 08-29-2012, 09:53 PM   #27
cruisnhard
Member#: 254408
2008 Impreza WRX
^^^agreed^^^
cruisnhard is offline   Reply With Quote
Old 08-29-2012, 10:09 PM   #28
Jmhm17
Member#: 224097
2012 WRX Hatch - DGM
Stage 1 - Tuned by Bren
If most of you saw stock afr's you would cringe and wonder how the car dosnt blow up at wot on stock tune. If you ask me, it's only a matter of time before the stock tune cracks your pistons. Most of you say your car is stock and never have problems. As long as you dont go into full boost under 4k your fine..
And for the above poster who said they got an STi over a WRX for power your wrong. Stock for stock they can dyno the same and or the wrx could be more than the sti. The 265/305 hp is a marketing scheme. Protune for protune they are very close. The 10k more you pay for the sti is for everything BUT more power. In the US HP numbers do not apply wrx vs sti, thanks to the stupid US DOT regulated econo tree hugging tune..
Jmhm17 is offline   Reply With Quote
Old 08-29-2012, 10:50 PM   #29
damonhimself
Member#: 235835
2011 WRX 5DR
Where is the chase and how do you cut to it?
damonhimself is offline   Reply With Quote
Old 08-30-2012, 04:04 PM   #30
VicsSTi1288
Member#: 323203
2007 Cobalt SS/SC
Suburst Orange
Lol I think it is funny how the STi has a shift light in it and from factory it is set to go off at 4100 rpms.... Could Subaru be saying shift here..
Also from what I herd is the STi's power in the middle of the power band? So anything over 5000 rpms the engine goes flat in power... Correct me if I'm wrong.
VicsSTi1288 is offline   Reply With Quote
Old 08-30-2012, 09:15 PM   #31
MaddMax
Member#: 9264
2016 BMW M235i 6MT
It's a turbocharged motor; therefore, the powerband is very broad (e.g. 90% of the power is delivered by 4500rpms, peaks at ~6000rpms, and doesn't fall of much near fuel cut). It's not like an NA motor that relies solely on rpm to generate power which results in a more peaky powerband. A turbo band isn't as exciting has an NA one in terms of how the power continues to build as the rpms climb, but you can be certain the turbo powerband will deliver far more average power which results in quicker acceleration.
MaddMax is offline   Reply With Quote
Old 11-29-2012, 12:43 AM   #32
RedRaiderWRC
Member#: 326373
I was just curious , because I just ordered a 2013 STi .
Where I live in Colorado , I can only get 91 octane . So that should be ok.
Is there a reason why Colorado does not offer higher octane ?
Due to the lower air density at elevation, the amount of air that the majority of cars (naturally aspirated) will be able to intake is reduced. Since the car is receiving less air, a fuel that burns faster (lower octane, higher heptane) is used in order to keep the average burn rate in proportion. If a higher octane is used on an NA motor at altitude, the burn rate is slowed enough to decrease power due to incomplete combustion (decrease it more, in addition to the decrease in power due to less air in the first place).
RedRaiderWRC is offline   Reply With Quote
Old 11-29-2012, 01:22 AM   #33
elev8
Member#: 207816
Actually very few people, or none, have pointed to a stock wrx post 2008 with failed ring lands. Andecdotes , which is all we have, to me suggest that STI fails much more often in stock form than the wrx. Are the AFR so bad on stock wrx vs known lean on STI? It would be interesting to hear from stock wrx failures. since presumably , at least post 2009, many more wrxs are sold vs STIs one should "hear" about more wrx ringland failures, but i've noticed the failed ringland threads seemingly always entail an STI sometimes in stock form. I'm thinking of ordering a '13 and for this reason (well, speculation) I'm leaning towards wrx.
elev8 is offline   Reply With Quote
Old 10-16-2013, 09:22 AM   #34
kemics
Member#: 371080
I have a 2012 WRX at stock, was talking to a few mechanic buddies of mine and some guys that do AUTOx. From their experience with WRX and their friends they've only failed with mods (not saying that's the only way you'll fail)
However I was told that the Stock A/F ratio is a little lean I looked it up and I find anywhere from 13.7 to 14.7 Air to 1 fuel.
If you go stage 1 with the Access port just by changing your fuel mapping it should take you down to 11.2 or 11.1, from what I've read.
The richer fuel mixture can help prevent knock and the other issues. I'm still under warranty, I will not flash or change anything until I'm out of warranty, I don't want to risk blowing anything and not having them cover it. Once its out, I'll probably go to Stage 1 for the richer fuel mix even if it's just better for the car. I'm not doing AutoX on it and I drive it pretty straight.
kemics is offline   Reply With Quote
Old 10-16-2013, 08:59 PM   #35
byun
Member#: 258046
2011 Impreza WRX
I think it's only a matter of time with any modded car. Just rebuild and don't look back
byun is offline   Reply With Quote
Old 10-16-2013, 10:51 PM   #36
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Originally Posted by kemics View Post
I have a 2012 WRX at stock, was talking to a few mechanic buddies of mine and some guys that do AUTOx. From their experience with WRX and their friends they've only failed with mods (not saying that's the only way you'll fail) However I was told that the Stock A/F ratio is a little lean I looked it up and I find anywhere from 13.7 to 14.7 Air to 1 fuel. If you go stage 1 with the Access port just by changing your fuel mapping it should take you down to 11.2 or 11.1, from what I've read. The richer fuel mixture can help prevent knock and the other issues. I'm still under warranty, I will not flash or change anything until I'm out of warranty, I don't want to risk blowing anything and not having them cover it. Once its out, I'll probably go to Stage 1 for the richer fuel mix even if it's just better for the car. I'm not doing AutoX on it and I drive it pretty straight.
You're half right, it's ~13s at tip-in, piggy rich further in the powerband. If it was 13s throughout the powerband they'd all explode first trip to redline. Aftermarket em addresses the tip in issue and leans it out approaching redline.
SlimJim8804 is offline   Reply With Quote
Old 10-16-2013, 11:45 PM   #37
adosdrummer
Member#: 348773
06 LGT and Mr-s
Ill just leave this here... stock 2013 wrx
adosdrummer is offline   Reply With Quote
Old 10-16-2013, 11:54 PM   #38
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Gasp.
That's leaner than I thought. Other graphs I had seen showed it being less dramatic, and being richer (low 10's) approaching redline.
Old 10-16-2013, 11:58 PM   #39
Kirby10
Member#: 300139
2010 STi
Spark Silver
I have a 2010 STi with zero issues and already at 57k miles. 30k of those miles on upgraded turbo with supporting mods and 370whp on E85
Kirby10 is offline   Reply With Quote
Old 10-17-2013, 11:00 AM   #40
themaus
Member#: 321211
Originally Posted by SlimJim8804 View Post
Gasp.
That reading is clearly not from a wideband o2, therefore the AFRs on that graph are garbage.
themaus is offline   Reply With Quote
Old 10-17-2013, 11:59 AM   #41
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Where would those figures come from? If it's a VD, I doubt it's a tailpipe sniffer.
Factory oxy sensor?
Old 10-17-2013, 01:16 PM   #42
themaus
Member#: 321211
Factory oxy sensor?
Yes. Hence why it flatlines at 11.1 cause it can't read below that.
Old 10-17-2013, 01:40 PM   #43
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
torqued performance stage 2 flatlines at 11.1 before 3000 rpms..pretty much as soon as the boost starts climbing. The wideband shows 10.7-10.9
Celery GT-5 is offline   Reply With Quote
Old 10-19-2013, 01:25 AM   #44
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
Just read every single post in this thread. I don't want to lose this information in case I ever need to recall it(maybe Subaru should recall their engines). Judging by the amount of views, it sounds like all of us are at least a bit worried.
At this point my 2012 WRX is 100% stock with an extended warranty. Just touched 14,000 miles today.
gunny11218 is offline   Reply With Quote
Old 10-23-2013, 02:33 AM   #45
Apollo Creed
Member#: 352748
2012 wrx wagon
blue
I'd say tune it as soon as possible so you are not running it lean while under warranty. Then you have done minor damage already so when you do mod it will not be beat up already. Just imho
Apollo Creed is offline   Reply With Quote
Old 10-23-2013, 10:49 AM   #46
chriskarel
Member#: 287176
chriskarel is offline   Reply With Quote
Old 10-23-2013, 11:37 AM   #47
Never Summer
Member#: 349361
2013 STi
Originally Posted by chriskarel View Post
this is upsetting....I was thinking about a newer WRX sedan as my next car, but apparently this ringland issue is still a thing. I'm not taking that chance.
Pistons bro!
Never Summer is offline   Reply With Quote
Old 10-23-2013, 11:48 AM   #48
Celery GT-5
Member#: 98210
2002 WRX SRP
I don't think its as widespread as people make it out to be
Old 10-23-2013, 12:52 PM   #49
jt subie
Member#: 364962
a lot of people spreading this around dont even own the car! from what I've seen this was more of a issue with the "08" STI. I have not read about very many 3rd gen WRX's having this problem. I have however read a lot of comments by people "who have never owned one" spread this around. I dont even pay attention to it no more. I havent had any problems with my 12 and dont expect to. I take care of it, I know how to mod correctly and dont drive like a lunatic.
jt subie is offline   Reply With Quote
Old 10-23-2013, 01:37 PM   #50
Celery GT-5
Member#: 98210
2002 WRX SRP
I expect to have lots of problems lol
so far just a phantom misfire
2008+ STI Piston Ring Land Failure List Mach V Dan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 508 01-31-2016 11:05 PM
my 2009 wrx has 3 broken ring lands WRrexu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 225 03-09-2012 11:47 PM
Possible blown ring land? 2004 wrx street carp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-18-2010 10:44 AM
What's causing ring lands to fail? Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 08-25-2004 05:27 PM
Problems with piston #4 ring land QA Guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-28-2003 07:27 PM
