Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 11-25-2012, 07:40 PM   #1
WiechWRX
Member#: 249659
2012 WRX Limited
Default 2012 WRX oil leak
Where is this oil coming from? I know it's hard to see on the second picture but its running down that spotty black hose. I'm looking at it underneath and from above,and can't find the culprit. Any ideas to look would be good. I didn't do anything to cause a leak. Only parts I have installed on the car is a short ram and pitch stop. Obviously neither of those would do it. But would removing the top mount have stirred something up? Thanks guys!
WiechWRX is offline   Reply With Quote
Old 11-25-2012, 07:45 PM   #2
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
Check the tmic to throttle body hose.
ERL2011wrx is offline   Reply With Quote
Old 11-25-2012, 07:52 PM   #3
WiechWRX
Member#: 249659
2012 WRX Limited
Throttle body to top mount was sealed tight but if you look hard enough in the picture, there's some oil down in the valley. Getting closer! Sorry for iPhone pictures too.
Old 11-25-2012, 07:58 PM   #4
WiechWRX
Member#: 249659
2012 WRX Limited
Pretty sure I found it. I can twist the throttle body hose. Now I'm just trying to get to the hose clamp without taking 50 things off
Old 11-25-2012, 08:03 PM   #5
WiechWRX
Member#: 249659
2012 WRX Limited
There we go! So is this common? Why would this have happened? Fill me in guys
Old 11-25-2012, 08:18 PM   #6
garudatwo
Member#: 322385
Remove that black condom from both end of the hose, spray some hairspray to help it seal before reattaching, use t clamps, and it won't happen again. It's common enough for there to be multiple threads about it. Happened to me as well.
garudatwo is offline   Reply With Quote
Old 11-25-2012, 09:50 PM   #7
424wrx
Member#: 171948
08 wrx prem sedan
vf52 swap. bilstein susp
op, go to the dealer. you have a warranty. that much oil there isnt normal. stop taking it apart and go to the dealer.
Old 11-26-2012, 01:29 AM   #8
WiechWRX
Member#: 249659
2012 WRX Limited
I'm stage 2 with a dp and intake. Pretty sure I'm screwed on that end. Or is it worth a shot?
Old 11-26-2012, 07:01 AM   #9
424wrx
Member#: 171948
08 wrx prem sedan
whats the worst they can say, no. i had a smaller oil issue on my 08. higher boost pressures make this issue worse. i installed a grimmspeed aos system and my tb hose and tmic are free of oil again. my car is also almost 5 years old come january. your is much newer. try the dealer id say.
Old 11-26-2012, 07:20 AM   #10
WiechWRX
Member#: 249659
2012 WRX Limited
Very true. I'm taking it there this week
Old 11-26-2012, 10:01 PM   #11
Zaklowery
Member#: 339007
Is it just me, or do 12 wrx's have alot of issues with seals? Taking my 12 in again soon with boost leaks....
Zaklowery is offline   Reply With Quote
Old 11-27-2012, 06:51 AM   #12
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
This means almost nothing. But if you want to continue to think because you modded your car in any way, that you no longer have any sort of dealer support, then go ahead.
Old 11-27-2012, 03:51 PM   #13
1sickSubie42
Member#: 204321
2004 WRX/08 Bmw 335i
WR Blue
just remove your mods and go to dealer with is that a days work vs losing your warranty no brainer in my mind.
1sickSubie42 is offline   Reply With Quote
Old 11-28-2012, 09:39 AM   #14
matigas_TT
Member#: 322775
2012 WRX
Same problem I had! Bring it to the dealer and get that warranty to work! Remove your mods though
matigas_TT is offline   Reply With Quote
Old 11-29-2012, 02:02 AM   #15
jackassofalltrades
Member#: 309550
2012 WRX HATCH
WRB AKA Scooter
Same problem I had. Installed grimmspeed AOS, and problem solved.
I noticed a boost leak before installing the AOS and that added to the oil leak problem as well. Running 19.5 psi now.
After AOS and boost leak fix= NO oil Leaks. Happened in the same area with close to the same, if not more oil.
Screw taking your mods off.
Current setup:
2012 WRX
CNT TBE
AEM CAI
Stage "2" Protune - Covert Tuning Dynamics - Cbus, OH
Cobb AP
Cobb Short Throw
jackassofalltrades is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 03:54 AM.
