Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Closed Thread
Old 03-26-2012, 10:29 AM   #1
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Default Killer B Ultimate OIL PICKUP Now for EJ20 Oil pans! PLUS Temperature Sensor Adapter!
Two new products from Killer B Motorsport, coming soon...
1/2NPT to 1/8PT Sensor Adapter will allow the use of aftermarket oil temperature sensors with the 1/2NPT port on our oil pan instead of having to use an OEM plug adapter. Made in the USA from solid 304 Stainless Steel. $18.90
Garrett GTX Compressor Housing 4" to 3" Inlet Adapter for confined spaces where a 4" inlet just won't fit. Maintains surge ports function/performance and inlet flow capacity. Special thanks to Garrett for working with us on this design! Requires inlet lip to be machined and bolt pattern added. Made in the USA from solid 6061-T6 Aluminum, includes o-ring and stainless bolts. $68.90
__________________
- Highly Advanced and Full of Awesomeness - Patent Pending
vs.
V2 High Performance Aluminum
Brushed & Polished Delrin Shift knobs!
KillerBMotorsport is offline
Old 03-26-2012, 11:10 AM   #2
Boston Motorsports
Vendor Sales Rating: (626)
Member#: 214025
Keep up the high quality work Chris!
__________________
OPEN EARLY | OPEN LATE | OPEN 7 DAYS A WEEK!
Phone: 1.877.6000.BMS | E-Mail:
| Paypal:
WE WANT TO EARN YOUR BUSINESS!!
| WE WILL BEAT ANY ADVERTISED PRICE GUARANTEED!!
Boston Motorsports is offline
Old 03-26-2012, 07:13 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Will do!
__________________
vs.
Old 04-05-2012, 09:06 PM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Picture of sender adapter mounted in pan, turbo inlet, and prices added to OP.
__________________
vs.
Old 04-09-2012, 08:38 AM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the orders guys!
__________________
vs.
Old 04-17-2012, 09:34 AM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
First batch of sender adapters almost sold out. We got a lot of PMs/emails asking about OEM thread to BP so we'll be making a small first batch of those as well to test demand. That will work with an OEM pan, or ours, and made from solid 304 stainless steel.
Also, we've had many inquiries on our low mount turbo kit that is still in development. Along with the compressor inlet reducer we will start putting feelers out there for other components we've made to go with the kit for the low mount DIYers out there.
For example...
Low mount turbo sump machined from solid 304 stainless steel. We've gone through a few iternations to assure proper operation, and allow access to a very cramped area, before finalizing the design as you see it here. This 'mini' sump provides a clear obstruction free gravity drain for the turbo and includes a female NPT port for a scavenge pump.
__________________
vs.
Old 04-24-2012, 09:09 AM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Sender adapters added to website!
Also we now have EJ20 OEM "flat bottom" oil pan, Ultimate Oil Pickups in stock. The OEM oil pan no longer needs to be changed to the newer 'STi' style oil pan as in the past. We've always recommended those that do any 'performance' type driving to upgrade to an STi oil pan to protect against oil starvation under severe cornering, but for those EJ20 owners that don't drive like a lunatic, there's no point in changing the OEM oil pan.
Now the faulty OEM oil pickups can be replaced without replacing the OEM oil pan, baffle, dipstick, dipstick tube, on EJ20 engines!
If you own a Lagacy, Forester, or Outback and are considering this upgrade please visually verify your oil pan before ordering, since part number changes do not always follow model year changes. LINK HERE
Same robust design, now made for the EJ20 Also available through you local retailer/shop
__________________
vs.
Old 04-30-2012, 10:39 AM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Adapters going out at a pretty good pace. Thanks for the orders!!
__________________
vs.
Old 04-30-2012, 11:16 AM   #9
SubieEngineer
Member Sales Rating: (53)
Member#: 208152
2004 350Zed Base
Sold: 07 STI LTD #576
Waiting patiently for this right here. My new oil temperature gauge needs a place for its sensor in the pan of my STi. :-)
SubieEngineer is offline
Old 05-05-2012, 11:56 AM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Having a heck of a time sourcing a die for the OEM threads. I really wanted to make these from solid stainless. May have to make them from an OEM plug to help control costs. Either way will work well though
__________________
vs.
Old 11-29-2012, 09:33 AM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
OEM to 1/8BP adapters are made using OEM oil plugs.
__________________
vs.
Closed Thread
FS : 2002 WRX Front O2 Sensor CHEAP! Stock Uppipe w/ex temp sensor and OEM spare tire stlspeed Engine/Power/Exhaust 22 07-25-2010 02:18 AM
98 Legacy Outback - Temp Sensor Overheats and No More Cabin Heat??? thenexlevel Service & Maintenance 11 10-12-2009 03:22 AM
'06 Sti Stage II - comparision adding uppipe and turbo inlet hose alfriedesq Proven Power Bragging 7 07-28-2009 11:45 PM
Turbo SVX is coming soon KEVINL SVX Forum Archive 6 03-07-2001 08:01 AM
