Old 08-27-2011, 01:22 PM   #1
bboyjohn
Member#: 131024
2006 Impreza WRX STI
Crystal Metallic Gray
Default 06 STI Cylinder #4 Misfire
Seems like cylinder #4 is pretty popular these days . LOL, I kid. But on a more serious note, She just barely hit 100k miles on the odometer and now shes throwing a misfit: Cylinder #4 Misfire. In case I haven't already mentioned, she's an 06 STI Cobb Stage 2 OTS MAP (at stage 2 for 80k miles).
I was able to cure the previous misfire on cyl#4 code with a brand new set of spark plugs. It's only been like 1k or 2k mile SINCE than, and now the code has returned.
When changing the spark plugs I noticed there was a tiny bit of oil inside the TMIC. The oil was around the area where it would mount up to the throttle body. The amount of oil found would be equivalent to less than a tablespoon.
I've already done a couple of data logs. Cylinder #4 roughness looks like it's celebrating independence day every couple seconds. Especially at idle. When idling it feels as if all the motor mounts are just ready to snap.
I'm not exactly a tuner and on top of that it's my first time data logging as well. Hopefully someone with much better credentials can tell me what's going on here exactly. Will be greatly appreciated.
I was told if the culprit were to be the O-Rings, I could just run the motor, remove the oil cap and smoke would appear.
*Even though she's at stage 2. I recently swapped out the 3in CBE back to the stocker. For approximately 20k miles: It has been 3in down-pipe mated to the STOCK exhaust system on Cobb Stage 2 OTS Map.* <--- Just putting that out there; not knowing if it's relevant or not to the issue at hand.*
Will have the data log up this evening. It's work time.
Any inputs/advice would be greatly appreciated.
Thanks again,
John
bboyjohn is offline   Reply With Quote
Old 08-27-2011, 02:44 PM   #2
mackeymx
Member#: 258525
2004 STi-BW7670
R6-Red/White
I HATE to say this, but I bet you have very little compression in cylinder 4. I just experienced the same exact situation you did on my 04, and turns out I only had 60 psi in cylinder 4. Now the motor is in the middle of being pulled. I hate to say it, but I'm sure you have the same exact situation. Sorry man.
mackeymx is offline   Reply With Quote
Old 08-27-2011, 03:12 PM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
its blowed up
Old 08-27-2011, 06:38 PM   #4
Joshwrx04
Member#: 135429
'05 Cornfed CGM STi
94 Legacy SS
about to do a leak down in my 05, leaning to believe i have the same sitsuation:/
never had a misfire, or white smoke out of the filler or exhaust.
but still have a bad feeling its going to be cracked land..
Joshwrx04 is offline   Reply With Quote
Old 08-27-2011, 07:37 PM   #5
Mr. Black Man
Member#: 253148
2006 Subaru STI
Most likely it's done for. Same happened to me sadly, 'cept I had 0psi.. yes 0.. in cylinder #4. Cracked Ringland. All of the other cylinders were 140psi and perfectly fine.
Mr. Black Man is offline   Reply With Quote
Old 08-27-2011, 08:00 PM   #6
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
ringland... and sorry bro
FCmaniac is offline   Reply With Quote
Old 08-27-2011, 08:45 PM   #7
bboyjohn
Member#: 131024
I have the data log uploaded to the computer, but not sure how I would get it up here in the thread. LOL I'm not proficient at using HTML as you can tell. When I open the file on my computer it uses "Free Opener".
Could I get a little assistance please.
Thanks again,
John
Old 08-28-2011, 12:09 AM   #8
Uncle Scotty
OK buy Nates beans
Code:
use the code tags on the advanced page
Old 08-28-2011, 04:37 AM   #9
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
Default some of the other stuff
Thanks again,
John
John,
I just recently got my STi and I have been doing a lot of reading on the forums, and I do not feel qualified to comment on your most important issue, but in case you are still curious I can comment on some of your other issues:
The oil in the top mount is from spirited driving. It can also happen over the course of time with normal driving. The oil gets there from the pcv and the crankcase vents venting to the air intake tract. This is emissions related, and all it does is reduce intercooler effeciency. This is what they make air/oil seperators for. To prevent this from occuring.
Also you should not have any problems with the change in the exhaust piping sizing.
Good luck on the diagnosis, and maybe it is now time to build up the motor.
CTSparky is offline   Reply With Quote
Old 08-28-2011, 11:58 AM   #10
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
These engines are junk.
Spenk is offline   Reply With Quote
Old 08-30-2011, 08:55 PM   #11
Cheese13
Member#: 272366
2003 Evo 8 gsr
Bby
Just finishing putting mine back together, had 30 psi in number 3. Had a hammered out exhaust valve, cost me about 900 to fix
Cheese13 is offline   Reply With Quote
Old 08-31-2011, 10:45 AM   #12
20SilverSti05
Member#: 188916
2005 WRX STI
switch the coilpacks and put new sparkplugs in...if its still on #4 then get a compression test and if the cylinder is fine...then it could be the fuel injector
20SilverSti05 is offline   Reply With Quote
Old 08-31-2011, 10:58 AM   #13
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I would suggest doing these things in this order:
1. Check the compression on cylinder 4.
2. Swap coil packs as he said ^^. See if the misfire moves
3. Swap injectors from 2 to 4, again see if the misfire moves
I've seen several misfire issues that were caused by injectors being stuck open.
Take a look at the spark plug from that cylinder and see if it is coated in a unburnt fuel
WRXt4cy is offline   Reply With Quote
Old 08-31-2011, 12:26 PM   #14
daseca07
Member#: 277630
2007 WRX TR
man what is up with all these expensive horror stories. stock daily driven motors losing compression, modded motors losing compression . im on my first wrx had it for 5 months daily driver its got 67k miles STOCK and this is making me nervous. sorry about your troubles man i hope you get it taken care of quickly
daseca07 is offline   Reply With Quote
Old 08-31-2011, 01:44 PM   #15
mackeymx
Member#: 258525
2004 STi-BW7670
R6-Red/White
Like I said, mine also went. I got a cylinder #4 misfire just like you did, and had VERY little white smoke from the exhaust and oil fill cap. I then kept throwing EVAP codes, not sure why, but turned out cylinder 4 only had 60psi. The car has only been stage 2 for 20k, with a total of 74k on it.
Old 02-02-2012, 02:55 AM   #16
bboyjohn
Member#: 131024
Sorry if this thread is past over due but I finally came around to doing the compression test. Unfortunately, by the time I had everything pulled apart the motor had already cooled off. Cold motor: Cylinders #1 through #3; 140psi. Cylinder #4; 25psi.
Old 02-02-2012, 07:50 AM   #17
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
Man that sucks. Time for a built motor
SpongeBobSquarePants is offline   Reply With Quote
Old 02-02-2012, 11:08 AM   #18
ehiddenidentity01
Member#: 279169
2004 impreza wrx sti
wrb
I'm suprised #4 went first it's normally #3
ehiddenidentity01 is offline   Reply With Quote
Old 02-02-2012, 03:46 PM   #19
bboyjohn
Member#: 131024
guess i should be a little bit more optimistic. She was at stage 2 for 80k ; gave her all that mileage within 3 years
Old 11-29-2012, 03:28 PM   #20
HastySpartacus
Member#: 311032
I've got the same problem
......but im staged 2 145k LMAO! cylinder 4 misfire PFFF code, idle is shaking the car damn near apart.
I have a warranty tho :-D
I.honestly hope it lost compression in cylinder 4
HastySpartacus is offline   Reply With Quote
Old 11-29-2012, 06:23 PM   #21
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
the rubber on the coil pack often goes bad..... make sure you aren't arching because of bad rubber.
DHRDAN is offline   Reply With Quote
Old 11-29-2012, 06:24 PM   #22
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
I take issue with this.
Owners are bad.
FS : Stock 06 STi Parts bluewrxtr06 Engine/Power/Exhaust 5 08-31-2011 02:12 PM
2005 STi cylinder 1 misfire krypt951 Service & Maintenance 4 05-10-2009 11:39 PM
FS (pa) 06 sti cylinder heads [email protected] Engine/Power/Exhaust 12 02-22-2009 10:53 AM
Help...Cylinder #4 Misfire!!! ChickBee21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-11-2006 12:04 AM
Please Help Cylinder #4 misfire agterlik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-04-2005 07:24 PM
