Old 11-28-2012, 09:54 AM   #26
sexyyrex
Member#: 128022
2015 Mustang GT
Originally Posted by grabera7 View Post
I did some datalogs. Would anyone care to look at them?
If its a stuck injector, the only thing that would tell you it was a stuck injector would be a wide band. If its stuck closed, you'd be way lean, if its stuck open, it'd be way rich.
If you get your injectors flow tested, and they come back fine. Which is my bet that they will. Do a boost leak test, if no boost leaks found it can literally only point to one thing.
The calibration.
sexyyrex is offline   Reply With Quote
Old 11-29-2012, 09:23 PM   #27
grabera7
Member#: 307316
2011 STI
Plasma Blue
The calibration.
I'm attempting to make a boost leak tester. I'll get back with results
grabera7 is offline   Reply With Quote
