Old 11-05-2012, 07:57 PM   #676
FrankWhizzite
Member#: 317178
2009 Impreza
Spark Silver Metallic
I would like to order one as well, but im having trouble finding your email from the mobile app
FrankWhizzite is offline   Reply With Quote
Old 11-12-2012, 09:06 PM   #677
wagon_lover
Member#: 308081
Any write ups on an aux hook up into an 08 sti with factory nav. Just saw the 3 inputs for video and audio. I want to hook up my iPhone for music using an aux cable. Did some searching and didn't find anything.
wagon_lover is offline   Reply With Quote
Old 11-27-2012, 08:01 PM   #678
luan87us
Member#: 335013
2013 Premium WRX 5dr
Hi SVXdc. I don't know if you have an opportunity to work with a 2013 WRX HU yet. But I'm planning to upgrade the speakers and add an infinity ref475a amplifer to my 2013 WRX Premium (5drs) once it arrives. I want to keep the stock HU (which I heard is the same with 2012) so I was wondering if you or anyone here can give me some pointer on how to do this? So far from my research I know I need to get one of your adapter and a LOC to make all this possible. But I have one noobie question: Is it possible to use the factory wiring at all with new speakers and an amp?
Old 11-27-2012, 08:42 PM   #679
dsn112
Member#: 332561
2016 WRX LTD
Yep, I always use stock wiring.
I have his breakout harness on my 2013 and I am using the LC2i LOC. run the speaker out wires off the breakout harness side that you plug into to the headunit down to the loc and then the speaker wire from the amp back to the speaker wires on the breakout harness.
It's pretty easy, I did most of it in the dark and it was 40 degrees. I did wire my breakout harness ahead of time at my workbench though. I guess that helped with time
Old 11-27-2012, 09:05 PM   #680
luan87us
Member#: 335013
That's great to hear. I haven't look into too much about the LC2i as it's a bit costy. I was planning to use an average LOC around $30 or so to convert to the amp. I think I would just run wires from the new speakers to the amp.
Edit: Found out that the amplifier I'm planning to use actually takes High-level input directly from factory HU with the included adapter so I think I definitely don't need a LOC. Now if I can just figure out a way to use the factory speaker some how.
Old 11-27-2012, 09:27 PM   #681
alexrud
Member#: 164195
2013 XV Crosstrek
Ice Silver Metallic
New guy here...
I have a 2013 XV Crosstrek Premium with the standard head unit. I can get a 2013 factory navigation unit from a BRZ for relatively cheap. From the photos I have seen it looks identical to the one in the Impreza/Crosstrek. Does anyone know if it is a direct swap-in replacement for my stock head unit?
alexrud is offline   Reply With Quote
Old 11-27-2012, 11:19 PM   #682
Lv4toys
Member#: 338495
2013 XV Crosstrek
Tangerine Orange Pearl
Originally Posted by alexrud View Post
New guy here...
I have no idea. I own a 2013 Crosstrek premium and swapped out the HU for the one found in he Limited (non-Nav). It was a simple plug & play. However, my Crosstrek did not have the cable for the rear camera. What other wiring would you need for a NAv unit - antenna ???
Lv4toys is offline   Reply With Quote
Old 11-28-2012, 06:08 AM   #683
alexrud
Member#: 164195
2013 XV Crosstrek
Ice Silver Metallic
I'm just wondering if the harnesses/connectors at the head unit location are the same across all of Subaru's vehicles, assuming they all use the same model nav headunit. That would mean there is a good chance of interoperability.
From what I can see, just the antenna. That's what I'm also wondering - did/does Subaru have separate wiring harnesses for their trim levels that do not have wiring for extra equipment, like the rear camera, GPS antenna, etc?
Old 11-28-2012, 10:21 AM   #684
dsn112
Member#: 332561
2016 WRX LTD
A cheap loc or using the high level inputs will work, but with the terrible output of these headunits, you will benefit greatly from
Something like an lc2i or better. It electronically restores lost signal and makes it much more in line with what your amp should be receiving. I hooked up my amp with high level inputs first, the difference now is night and day. I have the gains way down and it's so much better than before with the gains maxed.
IMO do it right the first time and you won't have to waste time doing it twice like I did.
As far as running new speaker wire to all 4 doors, do what you want, but you are going to be wasting a ton of time and money on speaker wire that is not needed. Running to the doors is a big pain in the ass and is not going to make it sound better. Unless you are running a really high number of watts at a constant basis it's purely for show.
Old 11-28-2012, 10:54 AM   #685
luan87us
Member#: 335013
Thanks for the inputs. The amplifier I'm using is the MS-A1004 that has a built in digital sound processor so using high-level input with it shouldn't be a problem. I wouldn't mind using the factory wirings but if it isn't sufficient for the speakers I'm planning to use I rather do it right the first time like you said. I'm planning to use a pair for Kappa perfect 6.1 in front, and a pair of Kappa 63.9I in the rear. Do you think those factory wires are good enough for those speakers? Do you think they'll produce white noises?
I'm also not sure on how to use the factory wires with the stock HU. I am planing to use SVX's 20pin combined adapter to connect the HU to the amp. But I don't know how I can go about getting the amp signals send to the speakers factory wires.
Old 11-28-2012, 12:57 PM   #686
dsn112
Member#: 332561
2016 WRX LTD
That amp is pretty cool! As far as white noise, how would that happen?
The amp pushes 100w RMS however how often does that full 100w actually get to the speakers. Do you listen at max volume at all times? Probably never will you do that.
As far as how you do it, the breakout harness has the colored White, Grey, Purple and Green for the speakers. These are single wires so you cut them in the middle run the side that now runs to the male connector(side that connects to the headunit) to the amp input. Then run the amp out wires back up to the breakout and connect to the other side of the wires you cut that run to the female connecter (the one that connects to the factory harness)
Use speed wire to make this extremely easy.
http://www.sonicelectronix.com/item_...y-Scosche.html
Old 11-28-2012, 01:17 PM   #687
Lv4toys
Member#: 338495
2013 XV Crosstrek
The premium XV Crosstrek has the following HU connectors / wires
Motorola Antenna jack
USB connector
16 pin (microphone, etc)
20 pin (power, speakers, SWC, etc)
Checkout ae64.com. Svxdc rules when it comes to Subaru wiring harnesses.
Good Luck
Old 11-28-2012, 02:16 PM   #688
luan87us
Member#: 335013
I never max out my radio and usually only listen to music at medium-medium high level. At first I didn't really understand what cutting the wires then run it back to the other side mean but now that you show me those wires I understand what you guys were talking about now lol. So from the HU I cut the harnesses in half the end connected to the HU go to the amp then from the amp you connect the speakers out to the end going to the speakers!!! Now I'm fully understand this haha. Any recommendation on what Amp wiring kit I should use for that amp? I was thinking Rockford.
Old 11-28-2012, 03:39 PM   #689
dsn112
Member#: 332561
2016 WRX LTD
Nice, now that you get it, just make sure you don't cut any stock harness, ONLY cut the breakout harness you buy from David.
As far as amp kit, i like kicker because its high copper ct, but honestly just get something with good quality copper wire and you are fine.
Old 11-28-2012, 05:03 PM   #690
luan87us
Member#: 335013
Yea I am planning to use the 20pin combined harness to reduce the pain of slicing the factory wires. Can someone comfirm 2013 HU still has the same pin?
And from what I read the rockford kit I was looking at is 100% pure copper and true 4 AWG. These kits usually come with the patch/rca cable that I don't need since I'm just using the harness on the 20pin harness.
Old 11-28-2012, 06:02 PM   #691
dsn112
Member#: 332561
2016 WRX LTD
Yea I can confirm it has the same 20 pin.
Im sure the Rockford kit is fine. Could just buy 4g wire and an inline fuse and save a much of money vs a kit
Old 11-28-2012, 08:33 PM   #692
luan87us
Member#: 335013
I was thinking about buying the 4awg wires and the fuse and just cut and trim them myself but couldn't really find anywhere I can get just that. All that pulls up is the kit.
Old 11-28-2012, 09:35 PM   #693
dsn112
Member#: 332561
2016 WRX LTD
Sonic electronics sells everything by itself
Old 11-28-2012, 10:41 PM   #694
luan87us
Member#: 335013
Oh sweet. Thanks a lot for all the info. Now if my damn car would arrive already. Speakers and amp ordered.
Old 11-29-2012, 11:18 PM   #695
alexrud
Member#: 164195
2013 XV Crosstrek
Ice Silver Metallic
USB connector
Good Luck
Thanks for the info!
Old 11-30-2012, 03:48 PM   #696
Slacktron
Member#: 339342
2009 Impreza 2.5i
I was planning on purchasing an OEM sub with the old style harness for my car ('97 Legacy OBW) and noticed the following in the information thread:
This subwoofer and T-harness will work with any 1995-up stock Subaru radio (except SVX). It will also work with any after-market head unit (that has speaker-level outputs), as long as you don't cut off the factory radio plug and do use a wiring adaptor (AKA a "forward" harness). Simply connect the OEM sub's T-harness between the car's harness and your new HU, just like how it was with the stock radio
I have an aftermarket head unit (Pioneer DEH-4000UB) that has a sub preamp out I would like to use. Is there any reason that I can't separate the +/- L/R wires before the harness and run them to the preamp outputs, while leaving the power and other wires connected in the T-Harness? The main reason for this is I want a true crossover, as my reason for getting this sub is to get the bass frequencies out of my door speakers and the stock harness/setup does not allow for this.
Thanks in advance!
Slacktron is offline   Reply With Quote
Old 11-30-2012, 06:52 PM   #697
makikogi
Member#: 192990
2012 Impreza WRX
You would have to to get some inline crossover with separate high and low outputs. Tap into your existing t harness speaker wires to feed the lows and tap into you existing harness foe the highs. What are the frequency range of your door speakers? I'd imagine it wouldn't really pick up any say below 50hz or so but that's just my assumption.
makikogi is offline   Reply With Quote
Old 11-30-2012, 09:29 PM   #698
Slacktron
Member#: 339342
2009 Impreza 2.5i
The speakers I have supposedly go down to 30hz, but they don't do it very well, which I figure is a mix of them not being designed to hit that low and the bass echoing in the doors.
My head unit actually has a built in and adjustable two-way crossover for the sub preamp, which is why I want to use it of possible.
Old 12-01-2012, 01:17 AM   #699
makikogi
Member#: 192990
2012 Impreza WRX
I wonder which frequency your head unit separates the bass adjustment from the sub out level. If pioneer did it by the book 80hz and below is defined as subharmonic frequencies so perhaps the bass knob adjusts say somewhere between 60hz-100hz? And the sub out at 80hz and below?? IF that's the case than just turning the bass knob all the way down should get those sub harmonic frequencies out of your door speakers and you can compensate by turning up the sub out. Getting an OEM sub won't get you what you're looking for as it just taps the main speaker wire and won't get those frequencies out of your door speakers.
Old 12-01-2012, 01:36 AM   #700
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
I have a 2013 XV Crosstrek Premium with the standard head unit. [model CM621UB, Clarion PF-3386A-A, same as in some 2012-up Imprezas]
I can get a 2013 factory navigation unit [Fujitsu Ten] from a BRZ for relatively cheap. From the photos I have seen it looks identical to the one in the Impreza/Crosstrek. Does anyone know if it is a direct swap-in replacement for my stock head unit?
The BRZ and Impreza/Forester versions of the FT nav are very similar to each other, but they have some subtle differences (e.g., model numbers, and BRZ has a pin for amp remote turn-on).
Physical size on the FT nav HUs is the same as your CM621UB, but all of the harness connections on the nav HU are different. See this post for the pin-outs (#9 in lateral's '2012 nav' thread). Post #4 there has pictures of the back of the HU and harnesses.
I could put together several of the harnesses you would need to transplant the FT nav into your XV (or into an Impreza or Forester). A few parts I have a very limited supply of currently, or in the case of the nav's USB socket, nothing that fits.
I haven't checked whether the FT nav's XM antenna socket is the same as on Subaru's accessory sat radio tuner boxes (in any case, I don't have anything that fits that or the GPS antenna socket).
Given all that, how serious are you about wanting to do this?
If you go forward with it, you should try to get the seller to include the OEM GPS antenna and all of its cable (Subaru still puts it above the instrument cluster and it's not too difficult to remove).
Stock head unit information -- pin-outs, aux inputs, and more SVXdc Car Audio, Video & Security 60 12-06-2015 02:11 PM
Question about factory head units nsnguyen Car Audio, Video & Security 7 04-30-2004 02:26 PM
Question about using head unit to power back speakers STI-o-MY Car Audio, Video & Security 0 12-01-2003 03:06 PM
question about my head unit creature546 Car Audio, Video & Security 1 10-03-2002 07:48 PM
