Old 11-25-2012, 02:13 AM   #1
91legacyawdturbo
Member#: 177706
Default obd-2 q's
I'm in the process of wiring in an jdm v7 sti into a 97 legacy outback, I'm trying to figure out why the obd-2 port isn't working. I have the powers and grounds working properly, There's a few wires I'm not sure when it
comes to wiring. what I can figure out because the fsm and other diagrams are wrong when it comes to pin 8 is actually pin 9 which is the ignition power.
pin# 1: not used
pin# 2: ssm/gst communications A134 pin 21 ecu side
pin# 3: not used
pin# 4: Ground
pin# 5: ground
pin# 6: not used
pin# 7: not used
pin# 8: not used
pin # 9: ignition power (jdm harness black/ red stripe)
pin# 10: not used
pin# 11: not used
pin# 12: brown/ white stripe ?
pin# 13: Green/red stripe ?
pin# 14: red/ white stripe ?
pin# 15: not used
Pin# 16: battery power
So pin 12/13/14 where do these land at the ecu side? and which is the k-line and l-line?
Any help please Thanks, Brian.
91legacyawdturbo is offline   Reply With Quote
Old 11-25-2012, 02:00 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
My data shows the following:
OBD-2 Pin ECU pin
4-----------92
5-----------91
10----------93
12 gnd
13 gnd
Cougar4 is offline   Reply With Quote
Old 11-27-2012, 10:24 PM   #3
91legacyawdturbo
Member#: 177706
OBD-2 Pin ECU pin
4-----------92
5-----------91
10----------93
12 gnd
13 gnd
Can you tell me what the 91-92 pins are? end check connector? signal 1 & 2??
Old 11-28-2012, 04:11 AM   #4
Cougar4
Member#: 53443
Winestone
The info doesn't show there function, just where they go.
Old 11-28-2012, 05:59 PM   #5
91legacyawdturbo
Member#: 177706
Yeah that's where I'm getting to, I realized inwas looking at the connector wrong and upside down, I have everything but those two wired in. The biggest problem is that I'm wiring the v7 connector to the v7 harness/Ecu, some how the wires got cut
While strippig the bulk head harness away from the engine harness . 4-5 on the v7 fsm doesn't show up as 4-5 neither or in the 02/03 fsm. The 97 ecu wiring diagram doesn't even show 91/92/93 on the pin diagram. I tried to trace them on a 03 wrx and they correspond with the grounds if you use a 6 volt battery plugged into the obd connector and take a volt meter to the ecu connectors. With the ecu disconnected.
Old 11-30-2012, 09:40 PM   #6
jose_a_v31
Member#: 280138
2006 Impreza STi
Default Android app
There is an app for Android, its Electrodriod. It has every pinout for almost all connectors. OBD-II is in the list.
jose_a_v31 is offline   Reply With Quote
