#1 |
Member#: 303092
Vehicle:2002 Impreza WRX WRB |
Does anyone know how to set launch control on the XPT map with LC? Been trying to figure out how to but no luck, xpt hasn't emailed me back either. If you know how to set it, I would appreciate the help. Thanks!
#2 |
Member#: 303092
tttttttttt
#3 |
Member#: 167739
Vehicle:04 WRX |
There should be two settings with the XPT stage 2 LC.
Something about RPM And something about Speed. The RPM is your redline minus the number. So if your redline is 7k, and you put in 2k for the value, it will rev to 5k. If you put it at 3k, it will rev to 4k. The Speed value in MPH will be when it turns off. Set it to like 3mph, so when your car reaches that point, the LC will turn off. Setting it high like 30, means until you reach 30mph, you will not be able to go higher than the RPM set by you. |
#4 |
Member#: 312339
BAIC
Vehicle:03 wrx PSM |
Seems to me you need the XPT Defs that are provided in osecuroms, but even I have trouble getting my account activated. I also have the stage 2 map for my 2003 wrx.
If ANYONE has these defs, it would really be appreciated. |
#5 |
Member#: 167739
Vehicle:04 WRX |
#6 |
Member#: 312339
BAIC
#7 |
Member#: 299368
Vehicle:2002 WRX WR Blue |
How is the xpt stage 2? And what mods do you have and fuel do you use?
Curious because I have an invidia TBE and grim speed up pipe in the mail and was wondering if they have good tunes. |
#8 |
Member#: 167739
Vehicle:04 WRX |
#9 |
Member#: 167739
Vehicle:04 WRX |
#10 |
Member#: 312339
BAIC
Thanks, you are the man!
And @ Danthrax High flow catted DP/stock catback, gutted UP, drop-in panel (spectre) filter. No issues so far. So much smoother over stock. But it's only been a few days, so I am still learning about the new tune. |
#11 |
Member#: 299368
Did you have to do the resistor mod to clear the CEL?
#12 |
Member#: 312339
BAIC
Found from a different source(http://forums.nasioc.com/forums/show....php?t=1559011 [post 4].
#13 |
Member#: 197301
TXIC
Vehicle:2002 WRX Wagon W R Blue (02C) |
I just bought an XPT tune. I got my account activated within 2 days of submitting the order number to him (PM him on osecuroms).
